    4. Strom Weg - Iobroker startet nicht mehr
    UNSOLVED Strom Weg - Iobroker startet nicht mehr
      DavidFD last edited by
      Hab aktuell ein Problem mit meiner IObroker Installation.
      Kurz war der Storm weg (hab bisschen umverkabelt ;)) und seitdem startet der Broker nicht mehr.
      Log sagt folgendes:
      root@odroidxu4:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js --logs
      2019-02-23 12:12:00.225  - info: host.xu4 iobroker.js-controller version 1.4.2 js-controller starting
      2019-02-23 12:12:00.232  - info: host.xu4 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2019-02-23 12:12:00.233  - info: host.xu4 hostname: xu4, node: v8.15.0
      2019-02-23 12:12:00.237  - info: host.xu4 ip addresses: 192.168.188.10 2003:e0:c3e4:c500:20a3:d49e:eded:53d3 fe80::c139:b5a4:d6cb:669
      2019-02-23 12:12:00.358  - info: host.xu4  inMem-objects listening on port 9001
      2019-02-23 12:12:00.378  - error: Another instance is running or some application uses port!
      2019-02-23 12:12:00.378  - error: uncaught exception: listen EADDRINUSE 127.0.0.1:9001
      2019-02-23 12:12:00.390  - info: iobroker _restart
      2019-02-23 12:12:00.434  - info: host.xu4 States connected to redis: 127.0.0.1:6379
      2019-02-23 12:12:00.436  - info: host.xu4 InMemoryDB connected
      2019-02-23 12:12:00.453  - info: host.xu4 no instances found
      2019-02-23 12:12:00.503  - info: host.xu4 terminated
      Cannot read property 'callback' of undefined
      TypeError: Cannot read property 'callback' of undefined
          at normal_reply (/opt/iobroker/node_modules/redis/index.js:722:28)
          at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:824:9)
          at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
          at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
          at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
          at emitOne (events.js:116:13)
          at Socket.emit (events.js:211:7)
          at addChunk (_stream_readable.js:263:12)
          at readableAddChunk (_stream_readable.js:250:11)
          at Socket.Readable.push (_stream_readable.js:208:10)
      objects und states bak datei hab ich schon getestet.
      Was hab ich noch für möglichkeiten?
      • sigi234
        sigi234 Forum Testing Most Active @DavidFD last edited by sigi234
        @DavidFD
        Link Text
        Erst anschauen, ob admin aktiviert ist:
        cd /opt/iobroker
        iobroker list instances
        es muss so eine Zeile zu sehen sein:
        system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        Falls da “disabled” statt “enabled” steht, man kann Adapter so aktivieren:
        iobroker start admin
        • wendy2702
          wendy2702 last edited by
          @DavidFD sagte in Strom Weg - Iobroker startet nicht mehr:
          Scheinbar nutzt irgendetwas anderes schon diesen Port oder läuft bereits.
            list instances bleibt vollständig leer.
            Kein lebenszeichen im Iobroker
            • wendy2702
              Was kommt denn hier:
              netstat -a |grep 9001
              • apollon77
                apollon77 last edited by
                ich tippe das es durch den Stromausfall die objects.json zerschossen hat und daher jetzt" alles weg" ist.
                Bitte im ioBroker-Verzeichnis in iobroker-data mal schauen. Es gibt eine objects.bak und auch weitere Backups in einem Unterverzeichnis. In so einem Fall hilft es meistens die File-Größe zu vergleichen.
                  DavidFD @wendy2702 last edited by
                  @wendy2702 said in Strom Weg - Iobroker startet nicht mehr:
                  tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN
                  bekomme ich da. leider nicht so aussagekräftig
                    DavidFD @apollon77 last edited by
                    @apollon77
                    die bak hab ich schon ersetzt, leider ohne erfolg.
                    liest sich eigentlich nach einem redisfehler für mich.
                    Kann man das irgendwie wieder zum laufen bringen?
                      Problem konnt ich leider nicht ausfindig machen. Aber bin zumindest wieder Einsatzbereit.
                      Hab via setup custom die Ports 9001 und 9000 abgeändert und kann iobroker wieder normal nutzen
                      81.1k
                      boot error stromausfall boot error
