    4. Iobroker.js-controller error
    • G
      gogohome last edited by
      Hallo liebes Forum,
      habe seit kurzem diesen folgenden iobroker.js-controller Error.
      Ich habe keine Ahnung was die Ursache sein kann
      Ich vermute das es etwas mit dem vis fancyswitch zutun hat.
      Wird zumindest am Ende der Meldung angezeigt, kann mir aber keine reim draus machen.
      Zur Info das System läuft auf dem Raspberry pi 2
      Hat jemand eine Idee?
      ! 2016-02-27 07:28:27 error at Client.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/client.js:193:14)
      ! 2016-02-27 07:28:27 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/socket.js:295:12)
      ! 2016-02-27 07:28:27 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/socket.js:335:8)
      ! 2016-02-27 07:28:27 error at Socket.emit (events.js:118:17)
      ! 2016-02-27 07:28:27 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2447:27)
      ! 2016-02-27 07:28:27 error at ObjectsInMemServer.readFile (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1408:13)
      ! 2016-02-27 07:28:27 error at checkFileRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1009:18)
      ! 2016-02-27 07:28:27 error at ObjectsInMemServer.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1297:29)
      ! 2016-02-27 07:28:27 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1013:17)
      ! 2016-02-27 07:28:27 error at checkFileRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1040:38)
      ! 2016-02-27 07:28:27 error TypeError: Cannot read property 'fancyswitch.png' of undefined
      ! Cannot 2016-02-27 07:28:27 error parse /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/vis-fancyswitch.admin/_data.json: SyntaxError: Unexpected end of input
