    5. Seit JS 4.1.6 läuft bestimmtes Blockly nicht mehr (auch nicht in 4.1.7) - gelöst
      jf62 last edited by jf62
      Bis 4.05 lief das folgende Blockly einwandfrei:
        <block type="procedures_defcustomreturn" id="]^61Plj!Mn:=T#0aqA~)" x="-387" y="-362">
          <mutation statements="false">
            <arg name="strobjektname"></arg>
          </mutation>
          <field name="NAME">IPauslesen</field>
          <field name="SCRIPT">dmFyIGlwPWdldFN0YXRlKHN0cm9iamVrdG5hbWUpLnZhbDsKcmV0dXJuIGlwOw==</field>
          <comment pinned="false" h="80" w="160">IP auslesen</comment>
        <block type="schedule" id="_+?83h_Fn{/-=dF)t4TY" x="-388" y="-311">
          <field name="SCHEDULE">15 3 * * *</field>
            <block type="variables_set" id="ax1wnXnRpcC;5Hp*6jEZ">
              <field name="VAR">posKomma</field>
                <block type="math_number" id="fy%u8AoQI{4LK#/KTn{l">
                  <field name="NUM">0</field>
                <block type="variables_set" id="78=.L17.k4D0*]%q;Goq">
                  <field name="VAR">ListeSonoffs</field>
                    <block type="text_join" id="a~)ZvIAhU=f2uf)2ApUX">
                      <value name="ADD0">
                        <block type="get_value" id="Wfo}1(IaiwlY.DvMW#hq">
                          <field name="OID">sonoff.0.info.connection</field>
                      <value name="ADD1">
                        <block type="text" id="J_61GFpx9XjNxm=.~zDn">
                          <field name="TEXT">,</field>
                    <block type="variables_set" id="^-{cZ%`Yl@inN6%iFV_1">
                      <field name="VAR">Schleifenende</field>
                        <block type="logic_boolean" id="-(BAfc?GO`spC5!wpYsY">
                        <block type="controls_whileUntil" id="6Ew3x5fxV4FcyJQwL{1S">
                          <field name="MODE">WHILE</field>
                          <value name="BOOL">
                            <block type="logic_compare" id=")x[%vlw.*8rF#42(B-@t">
                              <field name="OP">EQ</field>
                                <block type="variables_get" id="Qj@F}ndW?Ga`t?P)]Xu_">
                                <block type="logic_boolean" id="L9^f5j)})B@U7e8hVr=Q">
                          <statement name="DO">
                            <block type="comment" id="M0kHyANF{r4imLFfM1]f">
                              <field name="COMMENT">Suche nächstes Komma in der Sonoff-Liste</field>
                                <block type="variables_set" id="onHAj,}EN=0ptY80mvuZ">
                                    <block type="text_indexOf" id="|)T;kdpR(/_8cpAgy-8]">
                                      <field name="END">FIRST</field>
                                        <block type="variables_get" id="q?/(-sqx:p%yl6]5]U;)">
                                      <value name="FIND">
                                        <shadow type="text" id="i97+FP(ai8zMxC??|TGh">
                                    <block type="controls_if" id="zaLa8Ye+4ifsEG1{xT*.">
                                        <block type="logic_compare" id="d#!2R.]me[E}D7:+zd)c">
                                            <block type="variables_get" id=",vZZJ8HVHbq1*4[)~c6J">
                                            <block type="math_number" id="]8QHGi2yDY!zyl@0r.G@">
                                        <block type="comment" id="Lu]hq0`*I|}3F~k1@jpr">
                                          <field name="COMMENT">kein Komma mehr gefunden</field>
                                            <block type="variables_set" id="`3Qc_7Yb_YFTv*5b-bJl">
                                                <block type="logic_boolean" id="v21Pm[OLs?K8MfRd3|=i">
                                      <statement name="ELSE">
                                        <block type="comment" id="VDR33}Sn|7UW6](RM{/v">
                                          <field name="COMMENT">Sonoff-Name aus Sonoff-Liste vom ersten Zeichen</field>
                                            <block type="comment" id="x#F+r^5O.SR]c;EI?Uau">
                                              <field name="COMMENT">bis zum Zeichen vor dem Komma kopieren</field>
                                                <block type="variables_set" id="%j/hlYKZv=KLa83TyTo+">
                                                  <field name="VAR">NameSonoff</field>
                                                    <block type="text_join" id="C82GcH}BOx1MBU%/j|f1">
                                                      <value name="ADD0">
                                                        <block type="text" id="rRpM+n,B3GU`/4)j1*Xe">
                                                          <field name="TEXT">sonoff.0.</field>
                                                      <value name="ADD1">
                                                        <block type="text_getSubstring" id="X;{yx;N@ojxN9@sM%;aX">
                                                          <mutation at1="false" at2="true"></mutation>
                                                          <field name="WHERE1">FIRST</field>
                                                          <field name="WHERE2">FROM_START</field>
                                                          <value name="STRING">
                                                            <block type="variables_get" id="3n8g+)M//kcMfLC~t,;)">
                                                          <value name="AT2">
                                                            <block type="math_arithmetic" id="F%ckJ0YR!61f5+tEKD]n">
        <shadow type="math_number" id="g[e*s0*:|X3uK~aaUSM6">
        <field name="NUM">1</field>
        <block type="variables_get" id="DajtIuOth{hV/t`|Vp-^">
        <shadow type="math_number" id="J##.!2+}ZK_;,n*UTUQU">
                                                      <value name="ADD2">
                                                        <block type="text" id="C%z8iR}NQZ{BLCTdL@Tj">
                                                          <field name="TEXT">.INFO.IPAddress</field>
                                                    <block type="comment" id="cCRoZ]K(_9ab[96os0GH">
                                                      <field name="COMMENT">IP-Adresse des Sonoffs über Javascript auslesen</field>
                                                        <block type="variables_set" id="5SZsG?NI(67[QgaWFE3:">
                                                          <field name="VAR">IPAdresse</field>
                                                            <block type="procedures_callcustomreturn" id="wnzJ8,(}k(ap=;!FD^2@">
                                                              <mutation name="IPauslesen">
                                                              </mutation>
                                                              <value name="ARG0">
        <block type="variables_get" id="0SX]Z}^wDSM`0N-p_^,r">
                                                            <block type="comment" id="|-!dskn/KBcDAtd,`9Gy">
                                                              <field name="COMMENT">Ersten Eintrag in der Sonoff-Liste entfernen</field>
        <block type="variables_set" id="m{,#zBp1=o)_x92.wkB1">
        <block type="text_getSubstring" id="vSrOkB@+y5-t=@wGbX?i">
        <mutation at1="true" at2="false"></mutation>
        <field name="WHERE1">FROM_START</field>
        <field name="WHERE2">LAST</field>
        <block type="variables_get" id="/*koR(^kCg!(*h1;(!OF">
        <value name="AT1">
        <block type="math_arithmetic" id="Snf@1(NV3O2-/Q{s[zw.">
        <field name="OP">ADD</field>
        <block type="variables_get" id="!A?Mo*(l#k7F-?iyoKaX">
        <shadow type="math_number" id=";YA6SY`7(NgEZ_SK`0KT">
        <block type="comment" id="p8LNBz*i-[5@L=lVUp|@">
        <field name="COMMENT">URL für Restart des aktuellen Sonoffs erstellen</field>
        <block type="variables_set" id="|tQ6q%T:bkRT;dgGX-)H">
        <field name="VAR">RestartURL</field>
        <block type="text_join" id="hmg4gkUD=wn9`m8k=Wip">
        <value name="ADD0">
        <block type="text" id="04;`,wWz7RWByQ=U|e|)">
        <field name="TEXT">http://</field>
        <value name="ADD1">
        <block type="variables_get" id="b_hVl/#*k,2)rYQmj!_!">
        <value name="ADD2">
        <block type="text" id="hyR19y=59s!H4{MQKCvY">
        <field name="TEXT">/rb?</field>
        <block type="comment" id="@w.yP6,ZV-}*3_Tku:+~">
        <field name="COMMENT">URL aufrufen = Sonoff-Restart</field>
        <block type="request" id="J7gk1(S*UXJ/i@;hB)w3">
        <mutation with_statement="false"></mutation>
        <field name="WITH_STATEMENT">FALSE</field>
        <field name="LOG">log</field>
        <value name="URL">
        <shadow type="text" id="[NA{ZA?sj2%RB-}9Z)nc">
        <block type="variables_get" id="UW3^#=kl!}iNdKV5RiaJ">
        <block type="comment" id="pC8M(DYgPmpC:04Q0Uuh">
        <field name="COMMENT">Zusätzlichen Eintrag im Log erstellen (kann entfallen)</field>
        <block type="debug" id="kDTrzP7)K6eNZfJ{V7E{">
        <value name="TEXT">
        <shadow type="text" id="=AZlVJqJ8Bdv2^hc2b3h">
        <block type="text_join" id="]pH=D,b%GPW`V1ReS-YC">
        <mutation items="4"></mutation>
        <value name="ADD0">
        <block type="variables_get" id="T69`T0[y6p53v~7jylp2">
        <value name="ADD1">
        <block type="text" id="OMb=Q/9BSV)OuE3F_lgg">
        <field name="TEXT">(IP: </field>
        <value name="ADD2">
        <block type="variables_get" id="m1M=RGrmi)Qo}x;/q{]m">
        <value name="ADD3">
        <block type="text" id="?P(.~ss]U(BdMy0b^io4">
        <field name="TEXT">) wurde neu gestartet</field>
      Nun bekomme ich folgenden Fehler:
      1.3.2019, 10:15:06.787 [info ]: javascript.0 Stop script script.js.Neustart_Tasmota
      1.3.2019, 10:15:12.370 [info ]: javascript.0 Start javascript script.js.Neustart_Tasmota
      1.3.2019, 10:15:12.370 [info ]: javascript.0 script.js.Neustart_Tasmota: registered 0 subscriptions and 1 schedule
      1.3.2019, 10:16:00.074 [warn ]: javascript.0 at Object.<anonymous> (script.js.Neustart_Tasmota:14:25)
      1.3.2019, 10:16:00.075 [warn ]: javascript.0 at IPauslesen (script.js.Neustart_Tasmota:7:12)
      1.3.2019, 10:16:00.075 [warn ]: javascript.0 at Object.<anonymous> (script.js.Neustart_Tasmota:27:19)
      1.3.2019, 10:16:00.076 [error]: javascript.0 script.js.Neustart_Tasmota: Error: Invalid URI "http:///rb?"
      1.3.2019, 10:16:00.076 [info ]: javascript.0 script.js.Neustart_Tasmota: request: http:///rb?
      Was läuft hier falsch?
      • thewhobox
        thewhobox last edited by
        ich hab mir gerade mal dein Script importiert und wie es scheint kann er die IP nicht auslesen weswegen die Restart URL "http://[hier fehlt die ip]/rb?" falsch ist und es abstürzt.
        Du könntest ja mal ein paar Debug ausgaben einbauen wo du den Namen zusammen setzt und wo er die IP abruft.
          jf62 @thewhobox last edited by jf62
          @thewhobox das dies der Fall ist weiß ich ja. Nur, das Blockly lief über 1 Jahr ohne Fehler und nun nicht mehr ...
          Hier muss ja der Fehler im JS Adapter liegen und nicht im Script.
          Wenn ich als pures JS umbaue sieht es so aus und läuft:
          var strobjektname, posKomma, ListeSonoffs, Schleifenende, NameSonoff, IPAdresse, RestartURL;
           * IP auslesen
          function IPauslesen(strobjektname) {
              var ip=getState(strobjektname).val;
              return ip;
          // Start per Scheduler
          schedule("10 16 * * *", function () {
            // posKomma = Position nächstes Komma in der Liste
            posKomma = 0;
            // Liste aller Sonoffs in Textform, kommasepariert
            ListeSonoffs = String(getState("sonoff.0.info.connection").val) + String(',');
            Schleifenende = false;
            while (Schleifenende == false) {
              // Suche nächstes Komma in der Sonoff-Liste
              posKomma = ListeSonoffs.indexOf(',') + 1;
              if (posKomma == 0) {
                // kein Komma mehr gefunden
                Schleifenende = true;
              } else {
                // Sonoff-Name aus Sonoff-Liste vom ersten Zeichen
                // bis zum Zeichen vor dem Komma kopieren
                NameSonoff = ['sonoff.0.',ListeSonoffs.slice(0, posKomma - 1),'.INFO.IPAddress'].join('');
                // IP-Adresse des Sonoffs über Javascript auslesen
                IPAdresse = IPauslesen(NameSonoff);
                // Ersten Eintrag in der Sonoff-Liste entfernen
                ListeSonoffs = ListeSonoffs.slice(((posKomma + 1) - 1), ListeSonoffs.length);
                // URL für Restart des aktuellen Sonoffs erstellen
                RestartURL = ['http://',IPAdresse,'/cm?cmnd=Restart%201'].join('');
                // URL aufrufen = Sonoff-Restart
                try {
                  require("request")(RestartURL).on("error", function (e) {console.error(e);});
                } catch (e) { console.error(e); }
                console.log("request: " + RestartURL);
                // Zusätzlichen Eintrag im Log erstellen (kann entfallen)
            jf62 last edited by
            Geht natürlich auch so, ist aber trotzdem unbefriedigend, dass es als pures Blockly nicht mehr läuft.
              Homoran Global Moderator Administrators @jf62 last edited by
              @jf62
              Bitte 4.1.7 installieren
                jf62 last edited by
                habe ich eben gemacht - keine Änderung
                  jf62 last edited by
                  Fehler bei Debug:
                  etState "List of connected clients" not found (3)
                  getState "sonoff.0.null.INFO.IPAddress" not found (3)
                  daher ObjectID neu zugeiesen - nun geht's
