    4. [Erledigt]Yahka Adapter unter Proxmox Debian
    UNSOLVED [Erledigt]Yahka Adapter unter Proxmox Debian
    • sluma
      sluma last edited by sluma
      Ich bin dabei ein NUC6 mit ioBroker einzurichten.
      Es läuft auf dem NUC Proxmox mit einer Debian9-VM.
      Bekomme den Yahka Adapter nicht zum laufen.
      undefined2019-03-05 08:55:32.957 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856
      2019-03-05 08:55:32.958 - error: Caught by controller[0]: CommunityTypes.InputVoltageAC.UUID = UUID.generate('CommunityTypes:usagedevice:InputVoltageAC');
      2019-03-05 08:55:32.958 - error: Caught by controller[0]: ^
      2019-03-05 08:55:32.958 - error: Caught by controller[0]: TypeError: Cannot read property 'generate' of undefined
      2019-03-05 08:55:32.958 - error: Caught by controller[0]: at module.exports (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856:45)
      2019-03-05 08:55:32.958 - error: Caught by controller[0]: at Object.importHAPCommunityTypesAndFixes (/opt/iobroker/node_modules/iobroker.yahka/main.js:382:26)
      2019-03-05 08:55:32.959 - error: Caught by controller[0]: at Object../yahka.homekit-bridge.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:1764:25)
      2019-03-05 08:55:32.959 - error: Caught by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
      2019-03-05 08:55:32.959 - error: Caught by controller[0]: at Object../yahka.ioBroker-adapter.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:2326:16)
      2019-03-05 08:55:32.959 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.yahka/main.js:271:17)
      2019-03-05 08:55:32.959 - error: Caught by controller[0]: at Object../main.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:290:30)
      2019-03-05 08:55:32.959 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.yahka/main.js:84:18
      2019-03-05 08:55:32.959 - error: host.ioBrokerStable instance system.adapter.yahka.0 terminated with code 1 ()
      2019-03-05 08:55:32.959 - info: host.ioBrokerStable Do not restart adapter system.adapter.yahka.0 because disabled or deleted
      2019-03-05 08:55:33.843 - info: host.ioBrokerStable object change system.adapter.yahka.0
      2019-03-05 08:55:33.856 - info: host.ioBrokerStable instance system.adapter.yahka.0 started with pid 9709
      2019-03-05 08:55:34.318 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856
      2019-03-05 08:55:34.319 - error: Caught by controller[0]: CommunityTypes.InputVoltageAC.UUID = UUID.generate('CommunityTypes:usagedevice:InputVoltageAC');
      2019-03-05 08:55:34.319 - error: Caught by controller[0]: ^
      2019-03-05 08:55:34.319 - error: Caught by controller[0]: TypeError: Cannot read property 'generate' of undefined
      2019-03-05 08:55:34.319 - error: Caught by controller[0]: at module.exports (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856:45)
      2019-03-05 08:55:34.319 - error: Caught by controller[0]: at Object.importHAPCommunityTypesAndFixes (/opt/iobroker/node_modules/iobroker.yahka/main.js:382:26)
      2019-03-05 08:55:34.319 - error: Caught by controller[0]: at Object../yahka.homekit-bridge.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:1764:25)
      2019-03-05 08:55:34.319 - error: Caught by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
      2019-03-05 08:55:34.319 - error: Caught by controller[0]: at Object../yahka.ioBroker-adapter.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:2326:16)
      2019-03-05 08:55:34.320 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.yahka/main.js:271:17)
      2019-03-05 08:55:34.320 - error: Caught by controller[0]: at Object../main.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:290:30)
      2019-03-05 08:55:34.320 - error: Caught by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
      2019-03-05 08:55:34.320 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.yahka/main.js:84:18
      2019-03-05 08:55:34.320 - error: host.ioBrokerStable instance system.adapter.yahka.0 terminated with code 1 ()
      2019-03-05 08:55:34.320 - info: host.ioBrokerStable Restart adapter system.adapter.yahka.0 because enabled
      EDIT: Ich konnte "material - Material widgets for ioBroker.vis." auch nicht über Admin installieren. Es war gar nicht aufgeführt. Habe es dann über den Terminal (Konsole) installiert.
      btw: Wo finde ich via FTP auf dem NUC den ioBroker Ordner ? 🙄
      • apollon77
        apollon77 last edited by
        Kann es sein das DU gerade Stable nutzt und früher "Latest" als Repo genutzt hast? vismaterial ist nur in ltest und denke ahka im Stable vllt auch nicht aktuell.
        • sluma
          Bin nun vom Raspi mit einem Total Backup über den backitup Adapter umgezogen.
          Mit der Anleitung 👍
          Funktioniert alles bis auf den Yahka Adapter 😤
          • apollon77
            Und was meckert er jetzt? Nochmal neu von Github installiert?
            • sluma
              Es kamen die gleichen Fehler !
              Bin jetzt runter auf 0.8.2 und siehe da, alles löppt 👍
              Ich hatte vorher aber auch 0.9.x installiert gehabt.
              81.1k
              error proxmox yahka
