    5. [Gelöst]Fehler Skript für CCU2
    SOLVED [Gelöst]Fehler Skript für CCU2
    • sigi234
      sigi234 Forum Testing Most Active last edited by sigi234
      Hallo, ich bekomme eine Meldung mit der ich nichts anfangen kann, das Skript funktioniert aber.
      6.3.2019, 11:55:00.057	[info ]: javascript.0 Stop script script.js.Sigi.DP_in_SV_schreiben_Duty
      6.3.2019, 11:55:00.071	[info ]: javascript.0 Start javascript script.js.Sigi.DP_in_SV_schreiben_Duty
      6.3.2019, 11:55:00.071	[warn ]: javascript.0     at script.js.Sigi.DP_in_SV_schreiben_Duty:5:1
      6.3.2019, 11:55:00.071	[info ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: registered 1 subscription and 0 schedules
      6.3.2019, 11:57:31.404	[info ]: javascript.0 Stop script script.js.Sigi.DP_in_SV_schreiben_Duty
      6.3.2019, 11:57:31.412	[info ]: javascript.0 Start javascript script.js.Sigi.DP_in_SV_schreiben_Duty
      6.3.2019, 11:57:31.413	[warn ]: javascript.0     at script.js.Sigi.DP_in_SV_schreiben_Duty:5:1
      6.3.2019, 11:57:31.413	[warn ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: setForeignState(id=hm-rega.0.30785, state="0") - was not executed, while debug mode is active
      6.3.2019, 11:57:31.413	[info ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: registered 1 subscription and 0 schedules
      6.3.2019, 11:57:55.636	[info ]: javascript.0 Stop script script.js.Sigi.DP_in_SV_schreiben_Duty
      6.3.2019, 11:57:55.642	[info ]: javascript.0 Start javascript script.js.Sigi.DP_in_SV_schreiben_Duty
      6.3.2019, 11:57:55.642	[warn ]: javascript.0     at script.js.Sigi.DP_in_SV_schreiben_Duty:5:1
      6.3.2019, 11:57:55.642	[warn ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: setForeignState(id=hm-rega.0.30785, state="0") - was not executed, while debug mode is active
      6.3.2019, 11:57:55.642	[info ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: registered 1 subscription and 0 schedules
      SKRIPT:
      // DP in SV schreiben
      const idDP = "hm-rega.0.NEQ1531999.0.DUTY_CYCLE";
      const idSV = "hm-rega.0.30785";
      setState("hm-rega.0.30785", getState("hm-rega.0.NEQ1531999.0.DUTY_CYCLE").val); // Skriptstart
      on("hm-rega.0.NEQ1531999.0.DUTY_CYCLE","hm-rega.0.30785");  // Wertänderung
      Das Skript schreib den Duty_Cycle aus HM Rega.0 in eine System-Variabel in die CCU2.
      Kann mir wer helfen?
        paul53 @Dutchman last edited by paul53
        @Dutchman sagte in Fehler Skript für CCU2:
        der falsche type wird verwendet so wie ich es verstehe
        So ist es. Wandle es in eine Zahl um.
        setState(idSV, parseFloat(getState(idDP).val)); // Skriptstart
        on(idDP, function(dp) {  // Wertänderung
           setState(idSV, parseFloat(dp.state.val));
        sigi234 1 Reply Last reply Reply Quote 1
          paul53 @sigi234 last edited by
          @sigi234 Den Debug-Mode des JS-Adapters ausschalten !
          • sigi234
            Danke, habe ich gemacht.
            javascript.0	2019-03-06 12:15:22.284	warn	at script.js.Sigi.DP_in_SV_schreiben_Duty:5:1
            javascript.0	2019-03-06 12:15:22.284	warn	at setState (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:1258:20)
            javascript.0	2019-03-06 12:15:22.283	warn	Wrong type of hm-rega.0.30785: "string". Please fix, while deprecated and will not work in next versions.
            RAW:
              "from": "system.adapter.hm-rega.0",
              "user": "system.user.admin",
              "ts": 1551862739325,
              "common": {
                "name": "Duty_Cycle",
                "type": "number",
                "role": "state",
                "unit": "%",
                "desc": "CCU Duty_Cycle",
                "min": 0,
                "max": 65000,
                "read": true,
                "write": true
              "native": {
                "Name": "Duty_Cycle",
                "TypeName": "VARDP",
                "DPInfo": "CCU Duty_Cycle",
                "ValueUnit": "%",
                "ValueList": "",
                "ValueMin": 0,
                "ValueMax": 100,
                "ValueType": 4,
                "ValueSubType": 0
              "acl": {
                "object": 1636,
                "owner": "system.user.admin",
                "ownerGroup": "system.group.administrator",
                "state": 1636
              "_id": "hm-rega.0.30785",
              "type": "state"
            • sigi234
              Aha, ich glaube es ist ein STRING-ZAHL Problem?
              Dutchman 1 Reply Last reply Reply Quote 0
              • Dutchman
                Dutchman Developer Most Active Administrators @sigi234 last edited by
                @sigi234 sagte in Fehler Skript für CCU2:
                jup,
                also es funktioniert Gerde bestimmt aber der falsche type wird verwendet so wie ich es verstehe
                  • sigi234
                    sigi234 Forum Testing Most Active @paul53 last edited by sigi234
                    DANKE! Gelöst......
                    Nur zur Verständnis, der parseFloat macht dies:
                    The parseFloat() function parses a string and returns a floating point number.
                    Dann importiert der HM Adapter die Sys-Variable von der CCU2 nicht Richtig? Diese ist ja als ZAHL eingestellt.
                    javascript
