    4. [gelöst] tr-064 mehrere Telefonbücher
    SOLVED [gelöst] tr-064 mehrere Telefonbücher
    • 0
      0018 last edited by 0018
      habe gestern bei meiner 7490 ein FritzFon hinzugefügt. Dieses hat auch ein eigenes Telefonbuch bekommen. Habe dadurch nun 3 Telefonbücher, anstatt vorher 2 in der Box hinterlegt. Bekomme dadruch jetzt folgende Fehlermeldung:
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:322:31)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at Parser.emit (events.js:211:7)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at emitOne (events.js:116:13)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
      Caught	2019-03-08 09:00:27.405	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/lib/phonebook.js:144:83
      Caught	2019-03-08 09:00:27.404	error	by controller[0]: TypeError: Cannot read property 'length' of undefined
      tr-064.0	2019-03-08 09:00:27.384	error	at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:322:31)
      tr-064.0	2019-03-08 09:00:27.384	error	at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
      tr-064.0	2019-03-08 09:00:27.384	error	at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
      tr-064.0	2019-03-08 09:00:27.384	error	at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
      tr-064.0	2019-03-08 09:00:27.384	error	at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
      tr-064.0	2019-03-08 09:00:27.384	error	at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
      tr-064.0	2019-03-08 09:00:27.384	error	at Parser.emit (events.js:211:7)
      tr-064.0	2019-03-08 09:00:27.384	error	at emitOne (events.js:116:13)
      tr-064.0	2019-03-08 09:00:27.384	error	at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
      tr-064.0	2019-03-08 09:00:27.384	error	at /opt/iobroker/node_modules/iobroker.tr-064/lib/phonebook.js:144:83
      tr-064.0	2019-03-08 09:00:27.384	error	TypeError: Cannot read property 'length' of undefined
      tr-064.0	2019-03-08 09:00:27.383	error	uncaught exception: Cannot read property 'length' of undefined
      Vorher lief der Adapter ohne Probleme. Wenn ich jetzt in der Adapterkonfig "Verwende Telefonbuch (Namensauflösung)" deaktivierte, läuft der Adapter wieder. Benötige allerdings die Telefonbücher zur Anrufanzeige.
      Gibt es eine Grenze an Telefonbüchern? Oder woran kann es liegen?
      Systemdaten:
      node 08.15.0
      npm 6.8.0
      tr-064: 0.4.18
      admin 3.6.0
      • 0
        0018 last edited by
        Stimmt, das neue angelegte ist noch leer. Werde es nachher mal füttern. Klingt aber logisch das es daran liegen könnte. Werde berichten....
        • SBorg
          SBorg Forum Testing Most Active @0018 last edited by
          @0018 sagte in tr-064 mehrere Telefonbücher:
          Zumindest nicht die 3, denn ich habe auch mehrere und läuft.
          Hat das neue Telefonbuch ev. Sonderzeichen oder Umlaute und ggf. wenigstens einen Eintrag?
          • 0
            0018 last edited by
            • 0
              0018 last edited by
              Jup das wars, jetzt geht es.
              • SBorg
                SBorg Forum Testing Most Active last edited by
                81.1k
                tr-064.0
