    5. *gelöst* wrong type of "number"
      SoerenKaiser99 last edited by SoerenKaiser99
      Hallo Zs,
      ich habe ein problem mit einem Script für ein Wetterupload.
      Es produziert bei jedem Durchlauf folgenden Fehler:
      javascript.0	2019-03-08 15:08:50.681	warn	at TCP.onread (net.js:601:20)
      javascript.0	2019-03-08 15:08:50.681	warn	at Socket.Readable.push (_stream_readable.js:208:10)
      javascript.0	2019-03-08 15:08:50.681	warn	at readableAddChunk (_stream_readable.js:250:11)
      javascript.0	2019-03-08 15:08:50.681	warn	at addChunk (_stream_readable.js:263:12)
      javascript.0	2019-03-08 15:08:50.681	warn	at Socket.emit (events.js:211:7)
      javascript.0	2019-03-08 15:08:50.681	warn	at emitOne (events.js:116:13)
      javascript.0	2019-03-08 15:08:50.681	warn	at Socket._ultron.on (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:138:22)
      javascript.0	2019-03-08 15:08:50.681	warn	at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:139:10)
      javascript.0	2019-03-08 15:08:50.681	warn	at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:165:16)
      javascript.0	2019-03-08 15:08:50.681	warn	at Receiver.getData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:330:12)
      javascript.0	2019-03-08 15:08:50.681	warn	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
      javascript.0	2019-03-08 15:08:50.681	warn	at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
      javascript.0	2019-03-08 15:08:50.680	warn	at WebSocket.emit (events.js:211:7)
      javascript.0	2019-03-08 15:08:50.680	warn	at emitOne (events.js:116:13)
      javascript.0	2019-03-08 15:08:50.680	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
      javascript.0	2019-03-08 15:08:50.680	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
      javascript.0	2019-03-08 15:08:50.680	warn	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2019-03-08 15:08:50.680	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2019-03-08 15:08:50.680	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-08 15:08:50.680	warn	at WS.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
      javascript.0	2019-03-08 15:08:50.680	warn	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
      javascript.0	2019-03-08 15:08:50.680	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-08 15:08:50.680	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-08 15:08:50.680	warn	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
      javascript.0	2019-03-08 15:08:50.680	warn	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
      javascript.0	2019-03-08 15:08:50.680	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-08 15:08:50.680	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-08 15:08:50.680	warn	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
      javascript.0	2019-03-08 15:08:50.680	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-08 15:08:50.680	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-08 15:08:50.680	warn	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-03-08 15:08:50.680	warn	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-03-08 15:08:50.680	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-03-08 15:08:50.680	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-03-08 15:08:50.680	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-03-08 15:08:50.680	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:756:38)
      javascript.0	2019-03-08 15:08:50.680	warn	at Object.<anonymous> (script.js.Schalter.wetterupload:9:3)
      javascript.0	2019-03-08 15:08:50.679	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
      javascript.0	2019-03-08 15:08:50.679	warn	Wrong type of mqtt.0.Wetterstation.Wetter.Fahrenheit: "number". Please fix, while deprecated and will not work in next versions.
      Das script schaut so aus:
      <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id=";|^#zEAG3eOW*X~.5RQ." x="38" y="-263">
        <value name="OID0">
          <shadow type="field_oid" id="_@px^Xq@{e^JtFJBE1x9">
            <field name="oid">mqtt.0.Wetterstation.Wetter.Temperatur</field>
          <block type="controls_if" id="EZVIxR{GacCGF89[vp%?">
              <block type="get_value" id="m*`#(rIK;e2n:LuE}O7H">
                <field name="OID">mqtt.0.Wetterstation.Wetter.Temperatur</field>
              <block type="variables_set" id="bP|8b60*bXdqM}hJSk*v">
                <field name="VAR">TempC</field>
                  <block type="get_value" id="}vFMoYXzWKiWs}Dlbe-w">
                  <block type="update" id="R0ROgqA^P[Y-HV^?su!J">
                    <field name="OID">mqtt.0.Wetterstation.Wetter.Fahrenheit</field>
                      <block type="math_arithmetic" id="gD9[c}G/~8,L?8|IBdBA">
                        <field name="OP">ADD</field>
                          <shadow type="math_number" id="o0RBo.MAL,O4onRazsgt">
                            <field name="NUM">1</field>
                          <block type="math_arithmetic" id="hF0OQP9?@p#-U+%Ro-!L">
                              <block type="variables_get" id="seB8D689)e+P;@eyy:L_">
                              <shadow type="math_number" id="{zlvMLIeWAL%xBgRiS,@">
                                <field name="NUM">1.8</field>
                          <shadow type="math_number" id="dKtE?RYei+4iSI+uL;yz">
                            <field name="NUM">32</field>
        <value name="OID0">
      Es rechnet einen Wert in Celsius in Fahrenheit um den ich für einen upload zu einem Wetterservice benötige.
      Ich habe schon versucht den Matheblock hinter einen "erstelle Text aus " zu hängen, klappt aber auch nicht. Hat jemand einen Tipp für mich?
      Dank Euch!
      Dr. Bakterius 1 Reply Last reply Reply Quote 0
      • Dr. Bakterius
        Dr. Bakterius Most Active @SoerenKaiser99 last edited by
        @SoerenKaiser99 Wie ist denn der Datenpunkt formatiert (Zeichenkette, Zahl, Feld,...)? Entweder diesen richtig stellen, oder den Wert vor dem Schreiben konvertieren.
          dank dir! Hab den Datenpunkt auf "gemischt" umgestellt und der Fehler ist weg!
          blockly climate
