    4. JS Adapter? heap out of memory
    UNSOLVED JS Adapter? heap out of memory
    • kmxak
      Moin, hatte gestern Abend die erste Meldung darauf hin hatte ich den ioBroker neu gestartet ohne Erfolg.
      Dann alle JavaScripte gestoppt und den Adapter neu gestartet und die Scripte einzeln wieder eingeschaltet.
      Seit dem lief es wieder bis gerade eben.
      Folgende Fehlermeldung bekomme ich:
      host.ioBroker	2019-03-09 13:06:07.989	error	instance system.adapter.admin.0 terminated with code null ()
      host.ioBroker	2019-03-09 13:06:07.989	warn	instance system.adapter.admin.0 terminated due to SIGABRT
      Caught	2019-03-09 13:06:07.989	error	by controller[13]: 12: 0x1f763431b2e7
      Caught	2019-03-09 13:06:07.989	error	by controller[13]: [io.admin.0]
      Caught	2019-03-09 13:06:07.989	error	by controller[12]: 0x8e9444
      Caught	2019-03-09 13:06:07.989	error	by controller[11]: 11:
      Caught	2019-03-09 13:06:07.989	error	by controller[11]: node::Buffer::New(v8::Isolate*, v8::Local<v8::String>, node::encoding) [io.admin.0]
      Caught	2019-03-09 13:06:07.989	error	by controller[10]: 10:
      Caught	2019-03-09 13:06:07.989	error	by controller[10]: node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local<v8::Value>, node::encoding, int*) [io.admin.0]
      Caught	2019-03-09 13:06:07.989	error	by controller[9]: 9:
      Caught	2019-03-09 13:06:07.989	error	by controller[9]: v8::String::WriteUtf8(char*, int, int*, int) const [io.admin.0]
      Caught	2019-03-09 13:06:07.989	error	by controller[8]: 8:
      Caught	2019-03-09 13:06:07.989	error	by controller[8]: v8::internal::String::Flatten(v8::internal::Handle<v8::internal::String>, v8::internal::PretenureFlag) [io.admin.0]
      Caught	2019-03-09 13:06:07.989	error	by controller[7]: 7:
      Caught	2019-03-09 13:06:07.989	error	by controller[7]: v8::internal::String::SlowFlatten(v8::internal::Handle<v8::internal::ConsString>, v8::internal::PretenureFlag) [io.admin.0]
      Caught	2019-03-09 13:06:07.989	error	by controller[6]: 6:
      Caught	2019-03-09 13:06:07.989	error	by controller[6]: v8::internal::Factory::NewRawTwoByteString(int, v8::internal::PretenureFlag) [io.admin.0]
      Caught	2019-03-09 13:06:07.989	error	by controller[5]: 5:
      Caught	2019-03-09 13:06:07.989	error	by controller[5]: v8::internal::V8::FatalProcessOutOfMemory(char const*, bool) [io.admin.0]
      Caught	2019-03-09 13:06:07.989	error	by controller[4]: 4:
      Caught	2019-03-09 13:06:07.988	error	by controller[4]: v8::Utils::ReportOOMFailure(char const*, bool) [io.admin.0]
      Caught	2019-03-09 13:06:07.988	error	by controller[3]: 3:
      Caught	2019-03-09 13:06:07.988	error	by controller[3]: 0x8ccf9c [io.admin.0]
      Caught	2019-03-09 13:06:07.988	error	by controller[2]: 2:
      Caught	2019-03-09 13:06:07.988	error	by controller[2]: node::Abort() [io.admin.0]
      Caught	2019-03-09 13:06:07.988	error	by controller[1]: 1:
      Caught	2019-03-09 13:06:07.988	error	by controller[0]: FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
      root@ioBroker:/home/alex# free -m
      Mem:           5829        3236        1939          50         653        2310
      Swap:          5996         328        5668
      Im Error steht auch der Admin Adapter. Sehe ich das ggf. falsch und der verursacher ist der Admin Adapter?
      Dieser ist teilweise auch echt langsam.
      Hat einer eine Idee?
      • apollon77
        apollon77 last edited by
        Welche nodejs Version ist im Einsatz? Welche js-controller Version? Welche javascript Adapter Version?
        Ein paar mehr Infos wären schon schön 😉
          Homoran Global Moderator Administrators @kmxak last edited by
          @kmxak sagte in JS Adapter? heap out of memory:
          Swap:          5996         328        5668
          Der Speicher ist knapp - der Swap wird schon benutzt
          Segway 1 Reply Last reply Reply Quote 0
          • Segway
            Segway @Homoran last edited by
            @Homoran sagte in JS Adapter? heap out of memory:
            Ist das so? Available ist ja noch über 2000 !
              Homoran Global Moderator Administrators @Segway last edited by
              @Segway
              bessere Formulierung?:
              Der Speicher ist knapp gewesen - der Swap wurde schon benutzt
                paul53 @kmxak last edited by paul53
                @kmxak Vielleicht hilft das hier ?
                Es hat nichts mit dem JS-Adapter zu tun, sondern mit Node.js.
                • kmxak
                  Node.js
                  v8.15.0
                  NPM
                  6.4.1
                  JS Controller
                  1.4.2
                  Alle Adapter auf latest aktuell.
                  Der Fehler ist seit dem auch nicht mehr aufgetreten. An dem Tag ging nix...
                  War sehr komisch.
                  Danke paul53 werde ich mal testen falls es mal wieder auftritt
                  • apollon77
                    Ok, also die nodejs version sollte nicht vom memory leak betroffen sein.
                    Was mir da noch so in den Sinn kommt: Was laufen denn da so für Skripte? Haben die alle gescheites Fehlerhandling? Vllt ist an dem tag ne externe Seite oder irgendwas abhängiggen nicht erreichbar gewesen und daher ein Skript wegen mangelndem Fehler-Handling amok gelaufen?
                    (zB externe URL wird per setInterval regelmässig abgefragt und hatte Timeouts und es haben sich daher laufende requests angestaut weil setInterval halt immer weiter neue requests macht ohne darauf zu achten ob der letzte beendet ist oder sowas)
                    81.1k
                    heap out of memory
