    5. Markise AUF / ZU Regen / Wind
      muckel last edited by
      Könnt ihr mir über dieses Skript kurz drüberschauen, ob ich was vergessen habe oder einen Logikfehler eingebaut habe.
      Ich möchte nicht, dass mir die Markise davon fliegt. 🙂
      <variables>
      <variable type="undefined" id="timeout3">timeout3</variable>
      <variable type="undefined" id="timeout4">timeout4</variable>
      <variable type="undefined" id="timeout2">timeout2</variable>
      </variables>
      <block type="on_ext" id="0.Tcg.|FVV@zWgm#c9X" x="-1237" y="-12"> <mutation items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="9N:~4[Ubr[Pfw%7Tajp]"> <field name="oid">javascript.0.Regen</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id=".ajiR}(6tHBbQsIR2cq5"> <field name="oid">javascript.0.Wind</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="6z?G6LOhk.*pUJ[3nBly"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_operation" id="(^1Ymf._%Znb7+8yh+e}"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="o@j/1V#|3=UD.RzQXy^b"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="{7Is|D.,kxItJ_bK:XS}"> <field name="ATTR">val</field> <field name="OID">javascript.0.Regen</field> </block> </value> <value name="B"> <block type="text" id="hKsfoH1S)-VE8mUk}s9E"> <field name="TEXT">Regen</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="q{}FDHOXk|3qg60S7d~f"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="+4ri0UBGpu}1+(exICSj"> <field name="ATTR">val</field> <field name="OID">javascript.0.Wind</field> </block> </value> <value name="B"> <block type="text" id="Y2AjZ@=8MJbx=sIv0Rm_"> <field name="TEXT">Kein Wind</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control_ex" id="GdxLk(H{J[(l__d%L,H6"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="%IFjtn9qKJn,YBezkIDY"> <field name="oid">rflink.0.channels.BrelMotor_1.BLIND_41_ZU</field> </shadow> </value> <value name="VALUE"> <shadow type="logic_boolean" id="*PgLQuJ;/Mr9o2f8fOn5"> <field name="BOOL">TRUE</field> </shadow> </value> <value name="DELAY_MS"> <shadow type="math_number" id="LFl|NmeM_88bD8OIA36q"> <field name="NUM">0</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="YjN-x-csaPd%9hP5*IKP"> <field name="NAME">timeout3</field> <field name="DELAY">12</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="control_ex" id="7s)UtVK|j%@NjiE(r/zY"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="^]EYt7Zl1p3l/+RsIa;f"> <field name="oid">rflink.0.channels.BrelMotor_1.BLIND_STOP_41</field> </shadow> </value> <value name="VALUE"> <shadow type="logic_boolean" id="T*MgSZ@sN5[ibKyI?eR5"> <field name="BOOL">TRUE</field> </shadow> </value> <value name="DELAY_MS"> <shadow type="math_number" id=".sncOg3vAp=[t8V#f]Q2"> <field name="NUM">0</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="DiT0F9C}Ev9G_O0e6ua">
      <field name="NAME">timeout4</field>
      <field name="DELAY">2</field>
      <block type="control_ex" id="gzg8CYe2fG^vmEm!;Nr"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="ex!lvTl2{*B*]Xu8BO=w"> <field name="oid">rflink.0.channels.BrelMotor_1.BLIND_41_ZU</field> </shadow> </value> <value name="VALUE"> <shadow type="logic_boolean" id="(cj2/qjmlKjapXj[y_KR"> <field name="BOOL">FALSE</field> </shadow> </value> <value name="DELAY_MS"> <shadow type="math_number" id="liocXn#BgYb}tUsh=f"> <field name="NUM">0</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="tx+r[H8n+2nJPu8;f%8O"> <field name="NAME">timeout2</field> <field name="DELAY">11</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="control_ex" id="v6XZ7R]C?p#Un~qC=9)|"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="MLOp|OOOIkE88~whqu=N"> <field name="oid">rflink.0.channels.BrelMotor_1.BLIND_STOP_41</field> </shadow> </value> <value name="VALUE"> <shadow type="logic_boolean" id="dnflsA}ChFCd|Wvd}75Q"> <field name="BOOL">TRUE</field> </shadow> </value> <value name="DELAY_MS"> <shadow type="math_number" id="HLVbLCvvMb;]hHV2@+5">
      <value name="IF1">
      <block type="logic_operation" id="85j@T+LZ@9dr59_keRkx">
      <field name="OP">OR</field>
      <block type="logic_compare" id=")BO7rPDr#8rm~4U)vQ!0">
      <block type="get_value" id="haKIKct]1#g)?*^7^o">
      <block type="text" id="B;S~4QTF/q_P2z,BmG|M">
      <field name="TEXT">Kein Regen</field>
      <block type="logic_compare" id="(bt03@z2e*GRAMVY3KZE">
      <field name="OP">NEQ</field>
      <block type="get_value" id="*0D1F=!/}W%8SdanndJt">
      <block type="text" id="ji{=p|J#/Nu8bg[c.h!n">
      <statement name="DO1">
      <block type="control_ex" id="9rwMgpV4e~|-r@geH1GZ">
      <value name="OID">
      <shadow type="field_oid" id="y1fi!C@DTn{^Bk@Z={e!">
      <shadow type="logic_boolean" id="xNQ`_}Lc2drcpyj%+Nu8">
      <shadow type="math_number" id="L6H)tzc+x3nzvRiUJ0Pz">
      Regen:
      Zuerst muss ich die Markise zu fahren ca.20 Sekunden (ich weiß ja nicht wo sie steht)
      2 Sekunden Wartezeit mit STOP
      11 Sekunden Auffahren
      STOP
      Wind:
      Sofort Zufahren und alle anderen Ausführungen Stoppen, bis 1 Stunde lang "kein Wind".
      Wie Verzögere ich das vernünftig?
      Änderung zu "kein Regen":
      Zufahren (Regenabfrage "kein Regen") ist in einem anderen Script mit Netatmo "one hour no rain" verzögert.
      Bitte um Ratschläge und Ideen
      Liebe Grüße
      blockly
