    4. Web Adapter Maximum call stack size exceeded
    UNSOLVED Web Adapter Maximum call stack size exceeded
      arteck Developer Most Active last edited by Negalein
      ich hätte da ein Problem
      host.iobroker	2019-03-12 15:47:36.742	error	instance system.adapter.web.0 terminated with code 0 (OK)
      Caught	2019-03-12 15:47:36.742	error	by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
      Caught	2019-03-12 15:47:36.742	error	by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      Caught	2019-03-12 15:47:36.742	error	by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      Caught	2019-03-12 15:47:36.742	error	by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      Caught	2019-03-12 15:47:36.741	error	by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      Caught	2019-03-12 15:47:36.741	error	by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2019-03-12 15:47:36.741	error	by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      Caught	2019-03-12 15:47:36.741	error	by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
      Caught	2019-03-12 15:47:36.741	error	by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
      Caught	2019-03-12 15:47:36.741	error	by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
      Caught	2019-03-12 15:47:36.741	error	by controller[0]: RangeError: Maximum call stack size exceeded
      web.0	2019-03-12 15:47:36.698	error	uncaught exception: Maximum call stack size exceeded
      js-controller 1.5.3
      web 2.4.1
        amnesia106 last edited by amnesia106
        Genau das gleiche Problem habe ich auch nach der installation von Grafana in Verbindung mit dem Proxy Adapter. Deaktiviere ich den Proxy, läuft der Web.0 wieder. Es ist auch so, dass der Web.0 nicht sofort nach aktivieren des Proxy adapters abstürzt, sondern eher sporadisch.
        Flot scheint davon auch betroffen zu sein. Wenn ich flot aufrufe, stürzt auch alles ab. Mittlerweile trotz deaktivierten Proxy adapter
          @arteck sagte in Web Adapter Maximum call stack size exceeded:
          xceeded
          socket io ist der übeltäter..
          web adapter
