    4. IoBroker startet nicht mehr
      Phantomio last edited by
      ich hoffe mir kann jemand helfen….
      vor einigen Tagen habe ich mal den rega 0.3.1 Adapter installiert .... Keine Ahnung ob es damit etwas zu tun hat.
      Mit den gleichen Effekten wie hier beschrieben:
      http://forum.iobroker.net/viewtopic.php?f=22&t=2370
      Fakt ist: Gerade habe ich den Raspberry neu gestartet und bekomme den ioBroker nicht mehr zum laufen:
      ` > at Module.require (module.js:364:17)
      at require (module.js:380:17)
      at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/node_modules/http-signature/lib/utils.js:4:13)
      at Module._compile (module.js:456:26)
      2016-03-06 12:09:39.040 - error: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 6 (uncaught exception)
      2016-03-06 12:09:39.041 - info: host.raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled
      2016-03-06 12:09:54.280 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2412
      2016-03-06 12:09:55.269 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 8 (node.js: Cannot find module)
      2016-03-06 12:09:55.270 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2016-03-06 12:09:56.072 - info: host.raspberrypi instance system.adapter.web.0 started with pid 2414
      2016-03-06 12:09:56.572 - error: host.raspberrypi instance system.adapter.web.0 terminated with code 8 (node.js: Cannot find module)
      2016-03-06 12:09:56.573 - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
      2016-03-06 12:10:09.059 - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 2416
      2016-03-06 12:10:11.016 - info: hm-rega.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.hm-rega
      2016-03-06 12:10:11.056 - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
      2016-03-06 12:10:12.472 - error: uncaught exception: Error parsing /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/node_modules/http-signature/node_modules/sshpk/package.$
      2016-03-06 12:10:12.487 - error: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/node_modules/http-signature/node_modules/sshpk/package.json: U$
      at Object.parse (native)
      at readPackage (module.js:113:48)
      at tryPackage (module.js:123:13)
      at Function.Module._findPath (module.js:190:18)
      at Function.Module._resolveFilename (module.js:336:25)
      at Function.Module._load (module.js:280:25)
      2016-03-06 12:10:12.812 - error: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 6 (uncaught exception)
      2016-03-06 12:10:12.813 - info: host.raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled
      2016-03-06 12:10:25.294 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2422
      2016-03-06 12:10:26.281 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 8 (node.js: Cannot find module)
      2016-03-06 12:10:26.281 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2016-03-06 12:10:26.591 - info: host.raspberrypi instance system.adapter.web.0 started with pid 2424
      2016-03-06 12:10:27.064 - error: host.raspberrypi instance system.adapter.web.0 terminated with code 8 (node.js: Cannot find module)
      2016-03-06 12:10:27.065 - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
      2016-03-06 12:10:42.836 - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 2427
      2016-03-06 12:10:44.875 - info: hm-rega.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.hm-rega
      2016-03-06 12:10:44.915 - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
      2016-03-06 12:10:46.299 - error: uncaught exception: Error parsing /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/node_modules/http-signature/node_modules/sshpk/package.$
      2016-03-06 12:10:46.313 - error: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/node_modules/http-signature/node_modules/sshpk/package.json: U$
      at Function.Module._findPath (module.js:190:18)</anonymous></anonymous> `
      Ist eine endlos Schleife … immer wieder die gleichen Meldungen.
      Folgendes habe ich bereits probiert:
      apt-get update
      apt-get upgrade -y
      sudo apt-get install build-essential
      sudo apt-get install python2.7
      node war 10.022 oder so
      apt-get remove nodejs
      wget http://download.iobroker.net/nodejs0_12_6_armhf.deb
      dpkg -i nodejs0_12_6_armhf.deb
      rm nodejs0_12_6_armhf.deb
      node -v ist 0.12.6
      jetzt kommt beim start von iobroker:
      root@raspberrypi:/opt/iobroker# iobroker start
      module.js:338
          throw err;
      Error: Cannot find module 'camelcase'
          at Function.Module._resolveFilename (module.js:336:15)
          at Function.Module._load (module.js:278:25)
          at Module.require (module.js:365:17)
          at require (module.js:384:17)
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/lib/parser.js:3:17)
          at Module._compile (module.js:460:26)
          at Object.Module._extensions..js (module.js:478:10)
          at Module.load (module.js:355:32)
          at Function.Module._load (module.js:310:12)
          at Module.require (module.js:365:17)</anonymous>
      npm install iobroker.js-controller
      bring folgende Meldung:
      root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller
      npm ERR! tar.unpack unzip error /root/.npm/benchmark/1.0.0/package.tgz
      bringt diese:
      npm ERR! not a package /opt/iobroker/iobroker
      npm ERR! addLocal Could not install /opt/iobroker/iobroker
      npm ERR! Linux 4.1.13-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker"
      npm ERR! node v0.12.6
      npm ERR! npm  v2.11.2
      npm ERR! path /tmp/npm-2362-87139f40/unpack-4dfda8d37338/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! enoent ENOENT, open '/tmp/npm-2362-87139f40/unpack-4dfda8d37338/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log
      den raspberry habe ich auch schon neu gestartet (nach jeder Installation).
      hier noch das npm debug log:
      0 info it worked if it ends with ok
      1 verbose cli [ '/usr/local/bin/node',
      1 verbose cli   '/usr/local/bin/npm',
      1 verbose cli   'install',
      1 verbose cli   'iobroker' ]
      2 info using npm@2.11.2
      3 info using node@v0.12.6
      4 verbose install initial load of /opt/iobroker/package.json
      5 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker/package.json
      6 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.admin/package.json
      7 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.email/package.json
      8 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.flot/package.json
      9 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.fritzbox/package.json
      10 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.history/package.json
      11 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.hm-rega/package.json
      12 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.hm-rpc/package.json
      13 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png/package.json
      14 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.javascript/package.json
      15 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.js-controller/package.json
      16 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.rickshaw/package.json
      17 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.samsung/package.json
      18 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.sayit/package.json
      19 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.scenes/package.json
      20 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.socketio/package.json
      21 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis/package.json
      22 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-bars/package.json
      23 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-fancyswitch/package.json
      24 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-hqwidgets/package.json
      25 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/package.json
      26 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-justgage/package.json
      27 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-lcars/package.json
      28 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-metro/package.json
      29 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-rgraph/package.json
      30 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.vis-timeandweather/package.json
      31 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker.web/package.json
      32 info package.json iobroker.vis-fancyswitch@0.1.0 license should be a valid SPDX license expression
      33 verbose readDependencies loading dependencies from /opt/iobroker/package.json
      34 verbose install iobroker is installed as 0.5.6
      35 silly cache add args [ 'iobroker', null ]
      36 verbose cache add spec iobroker
      37 silly cache add parsed spec { raw: 'iobroker',
      37 silly cache add   scope: null,
      37 silly cache add   name: null,
      37 silly cache add   rawSpec: 'iobroker',
      37 silly cache add   spec: '/opt/iobroker/iobroker',
      37 silly cache add   type: 'local' }
      38 silly addLocalTarball shasum (computed) 172d89ea6df6ab508c7b69dc0540b583db07e40c
      39 verbose addTmpTarball /opt/iobroker/iobroker not in flight; adding
      40 verbose addTmpTarball validating metadata from /opt/iobroker/iobroker
      41 verbose tar unpack /opt/iobroker/iobroker
      42 verbose tar unpacking to /tmp/npm-2362-87139f40/unpack-4dfda8d37338
      43 silly gentlyRm /tmp/npm-2362-87139f40/unpack-4dfda8d37338 is being purged
      44 verbose gentlyRm don't care about contents; nuking /tmp/npm-2362-87139f40/unpack-4dfda8d37338
      45 silly gunzTarPerm modes [ '755', '644' ]
      46 error not a package /opt/iobroker/iobroker
      47 error addLocal Could not install /opt/iobroker/iobroker
      48 verbose stack Error: ENOENT, open '/tmp/npm-2362-87139f40/unpack-4dfda8d37338/package.json'
      48 verbose stack     at Error (native)
      49 verbose cwd /opt/iobroker
      50 error Linux 4.1.13-v7+
      51 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker"
      52 error node v0.12.6
      53 error npm  v2.11.2
      54 error path /tmp/npm-2362-87139f40/unpack-4dfda8d37338/package.json
      55 error code ENOENT
      56 error errno -2
      57 error enoent ENOENT, open '/tmp/npm-2362-87139f40/unpack-4dfda8d37338/package.json'
      57 error enoent This is most likely not a problem with npm itself
      57 error enoent and is related to npm not being able to find a file.
      58 verbose exit [ -2, true ]
      Ich hoffe einer von euch kann mir schnell weiter helfen…. am besten ohne Datenverlust 🙂
      seit dem letzten Backup sind leider schon wieder einige Stunden Gehirnschmalz ins Scripting geflossen.
      Auf iobroker.net unter Tipps und Tricks solle auch eine Hilfe sein:
      In diesem Foreneintrag verweist pix auf diese Seite (http://forum.iobroker.net/viewtopic.php … all#p19278)
      Diese Seite ist aber aktuell nicht erreichbar (Fehler …404 — Wow, nicht gedacht dich hier zu sehen.).
      #Update von 14:40 Uhr:
      ich habe mal im /tmp alle npm Ordner gelöscht.
      npm cache clean durchgeführt
      npm install iobroker.js-controller ging wieder ... die endlos Schleife wie oben beschrieben bleibt aber
      #Update 2 16:40 Uhr:
      Ich habe mal diverse adapter mit iobroker stop "Adaptername" deaktiviert.
      Den Admin Adapter habe ich ein zweites mal hinzugefügt:
      cd /opt/iobroker
      sudo iobroker stop
      sudo iobroker add admin --enabled --port 808X <- X durch eigenen
      so komme ich mittlerweile wenigestens wieder auf die Adminoberfläche
      Sobald ich aber den web oder den rega Adapter aktiviere kommen folgende Meldungen:
      REGA:
      2016-03-06 16:41:56.875  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 4577
      2016-03-06 16:41:59.708  - info: hm-rega.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.hm-rega
      2016-03-06 16:41:59.739  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
      2016-03-06 16:42:01.039  - error: uncaught exception: Error parsing /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/node_modules/http-signature/node_modules/sshpk/package.json: Unexpected token s
      2016-03-06 16:42:01.060  - error: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/node_modules/http-signature/node_modules/sshpk/package.json: Unexpected token s
          at readPackage (module.js:107:52)
          at tryPackage (module.js:117:13)
          at Function.Module._findPath (module.js:183:18)
          at Function.Module._resolveFilename (module.js:334:25)
      2016-03-06 16:42:01.390  - error: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 6 (uncaught exception)
      2016-03-06 16:42:01.393  - info: host.raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled</anonymous>
      WEB:
      2016-03-06 16:47:02.576  - info: host.raspberrypi object change system.adapter.web.0
      2016-03-06 16:47:02.658  - info: host.raspberrypi instance system.adapter.web.0 started with pid 4660
      2016-03-06 16:47:04.237  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 ()
      2016-03-06 16:47:04.238  - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
      2016-03-06 16:47:12.016  - error: adapter disabled
      2016-03-06 16:47:12.132  - error: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 3 (Adapter disabled or invalid config)
      2016-03-06 16:47:12.133  - info: host.raspberrypi Do not restart adapter system.adapter.hm-rega.0 because disabled or deleted
      2016-03-06 16:47:34.352  - info: host.raspberrypi instance system.adapter.web.0 started with pid 4675
      2016-03-06 16:47:35.934  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 ()
      2016-03-06 16:47:35.935  - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
      liegt das an einem Update?
      Ich bin mit meinem Latein mehr als am Ende ….
      Phantomio
        Hey,
        nachdem ich von Github die rega Version 0.3.3 installiert habe, läuft diese auch wieder.
        Der Web Adapter hat aber immer noch das oben beschriebene Problem.
        D.H. aktuell noch keine Tab Bedienung möglich 😞
        Neustart habe ich mich noch nicht wieder getraut.
        #Update 21:30 Uhr
        Ich habe letztendlich node wieder in Version 0.10.22-1 installiert.
        Kann es wirklich daran liegen???
        Nach zich Versuchen kann ich schon gar nicht mehr sagen was ich alles neu installiert habe.
        Definitiv aber den Vis und den Web Adapter.
        Nach dem ging dann auch wieder der Webadapter. (Zugriff auf vis).
        Währe trotzdem schön wenn noch jemand eine Idee hat was der Auslöser für diese Odysee war.
        Ungutes Gefühl beim Reboot bleibt. Habe ich noch nicht wieder gemacht.
        Phantomio
          @Phantomio:
          Hey,
          #Update 21:30 Uhr
          Phantomio `
          Es gibt neue Version 0.3.3.
          Hast damit auch Probleme?
            Hallo Bluefox,
            die 0.3.3 habe ich doch installiert (oder ist die 0.3.3. noch einmal gefixt?) Laut Datum auf Github nciht oder?
            Ich wollte am Sonntag Abend noch … mal eben :lol: :lol: :lol: ... von History auf MySQL umstellen.
            Folgendes Phänomen:
            Nach der installation von MySQL wieder die oben beschribene Endlosschleife (System.adapter.web.0 terminated with code 1).
            Also MYSQL wieder deinstalliert. Web Adapter neu installiert. läuft wieder "Gott sei Dank 😐 ".
            Hast Du dafür eine Erklärung?
            Ich habe das Gefühl das sich dieser Fehler nach jedem Adapter den ich installiere bzw. update wieder einschleicht.
            Ich habe alledings die nächsten Tage leider nicht so viel Zeit zum Experimentieren.
            Wahrscheinlich erst ab Sonntag wieder.
            Phantomio
