    4. Update Javascript-Adapter schlägt fehl
    UNSOLVED Update Javascript-Adapter schlägt fehl
      Kylo Ren last edited by Jey Cee
      Hallo Zusammen,
      beim Update des Javascript-Adapters kommt folgende Fehlermeldung:
      $ ./iobroker upgrade javascript
      Update javascript from @4.0.11 to @4.1.12
      NPM version: 6.9.0
      npm install iobroker.javascript@4.1.12 --production --save --prefix "/opt/iobroker" (System call)
      npm
      WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm
      WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@types
      npm
      WARN
       enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/bufferutil/package.json'
      npm WARN
      enoent
       ENOENT: no such file or directory, open '/opt/iobroker/node_modules/utf-8-validate/package.json'
      npm
      WARN
       enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/build/package.json'npm
      WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/kodi-ws/node_modules/build/package.json'
      npm WARN
       babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
      npm
      ERR! path
       /opt/iobroker/node_modules/@typesnpm
      ERR! code EACCES
      npm ERR!
      errno -13
      npm ERR! syscall access
      npm
      ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@types'npm
       ERR!
        { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@types'npm ERR!
         stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/@types\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',npm ERR!   syscall: 'access',
      npm ERR!
         path: '/opt/iobroker/node_modules/@types' }npm
      ERR! npm
       ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR!
       A complete log of this run can be found in:
      npm
       ERR!     /home/iobroker/.npm/_logs/2019-03-15T23_31_34_360Z-debug.log
      ERROR: host.iobroker Cannot install iobroker.javascript@4.1.12: 243
      ERROR: process exited with code 25
      • htrecksler
        Der meckert fehlende Berechtigungen an und sagt du sollst es nochmal als root/Adminstrator versuchen
        81.1k
        error javascript adapter
