    4. Error Javascript Adapter nach Sayit
    UNSOLVED Error Javascript Adapter nach Sayit
      muckel last edited by Jey Cee
      Habt ihr hierzu eine Idee warum er manchmal nach dem Sayit abstürzt?
      javascript.0 2019-03-16 16:49:33.843 info received all objects
      javascript.0 2019-03-16 16:49:33.197 info received all states
      javascript.0 2019-03-16 16:49:32.114 info requesting all objects
      javascript.0 2019-03-16 16:49:32.113 info requesting all states
      javascript.0 2019-03-16 16:49:32.087 info starting. Version 4.1.12 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.3
      host.SmartHome 2019-03-16 16:49:31.191 info instance system.adapter.javascript.0 started with pid 16796
      host.SmartHome 2019-03-16 16:49:01.171 info Restart adapter system.adapter.javascript.0 because enabled
      host.SmartHome 2019-03-16 16:49:01.171 error instance system.adapter.javascript.0 terminated with code null ()
      host.SmartHome 2019-03-16 16:49:01.171 warn instance system.adapter.javascript.0 terminated due to SIGABRT
      Caught 2019-03-16 16:49:01.171 error by controller[12]: 12: 0x15d084f042fd
      Caught 2019-03-16 16:49:01.171 error by controller[12]: v8::internal::Runtime_SetProperty(int, v8::internal::Object**, v8::internal::Isolate*) [io.javascript.0]
      Caught 2019-03-16 16:49:01.171 error by controller[11]: 11:
      Caught 2019-03-16 16:49:01.171 error by controller[11]: v8::internal::Object::SetProperty(v8::internal::LookupIterator*, v8::internal::Handlev8::internal::Object, v8::internal::LanguageMode, v8::internal::Object::StoreFromKeyed) [io.j
      Caught 2019-03-16 16:49:01.171 error by controller[10]: 10:
      Caught 2019-03-16 16:49:01.171 error by controller[10]: v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handlev8::internal::Object, v8::internal::PropertyAttributes, v8::internal::Object::ShouldThrow
      Caught 2019-03-16 16:49:01.171 error by controller[9]: 9:
      Caught 2019-03-16 16:49:01.170 error by controller[9]: v8::internal::JSObject::AddDataElement(v8::internal::Handlev8::internal::JSObject, unsigned int, v8::internal::Handlev8::internal::Object, v8::internal::PropertyAttributes, v8::
      Caught 2019-03-16 16:49:01.170 error by controller[8]: 8:
      Caught 2019-03-16 16:49:01.170 error by controller[8]: 0xd62fb5 [io.javascript.0]
      Caught 2019-03-16 16:49:01.170 error by controller[7]: 7:
      Caught 2019-03-16 16:49:01.170 error by controller[7]: 0xd4b6dc [io.javascript.0]
      Caught 2019-03-16 16:49:01.170 error by controller[6]: 6:
      Caught 2019-03-16 16:49:01.170 error by controller[6]: v8::internal::Factory::NewUninitializedFixedArray(int) [io.javascript.0]
      Caught 2019-03-16 16:49:01.170 error by controller[5]: 5:
      Caught 2019-03-16 16:49:01.170 error by controller[5]: v8::internal::V8::FatalProcessOutOfMemory(char const*, bool) [io.javascript.0]
      Caught 2019-03-16 16:49:01.170 error by controller[4]: 4:
      Caught 2019-03-16 16:49:01.170 error by controller[4]: v8::Utils::ReportOOMFailure(char const*, bool) [io.javascript.0]
      Caught 2019-03-16 16:49:01.170 error by controller[3]: 3:
      Caught 2019-03-16 16:49:01.170 error by controller[3]: 0x8c21ec [io.javascript.0]
      Caught 2019-03-16 16:49:01.170 error by controller[2]: 2:
      Caught 2019-03-16 16:49:01.170 error by controller[2]: node::Abort() [io.javascript.0]
      Caught 2019-03-16 16:49:01.170 error by controller[1]: 1:
      Caught 2019-03-16 16:49:01.170 error by controller[0]: FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
      sonos.0 2019-03-16 16:46:38.397 info try to control id sonos.0.root.192_168_0_100.tts with {"val":"25;http://192.168.0.230:8086/state/sayit.1.tts.mp3","ack":false,"ts":1552751198396,"q":0,"from":"system.adapter.sayit.1","user":"system.u
      sayit.1 2019-03-16 16:46:38.395 info Set "sonos.0.root.192_168_0_100.tts: 25;http://192.168.0.230:8086/state/sayit.1.tts.mp3
      Liebe Grüße
        paul53 @muckel last edited by
        @muckel sagte:
        Das sieht nach zu wenig RAM aus ?
          Denke nicht das es am Speicher liegt.
          Betriebssystem
          ubuntu 17.10
          Architektur x64
          CPUs 4
          Geschwindigkeit 935 MHz
          Modell Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
          RAM 15.5 GB
          Node.js v8.11.3 (Es gibt eine neuere Version: v8.15.1)
          NPM 6.7.0
          Festplatte Größe 163.5 GB
          Festplatte frei 141 GB
          Anzahl der Adapter 259
          Aktive Instanzen 36
            Homoran Global Moderator Administrators @muckel last edited by
            @muckel sagte in Error Javascript Adapter nach Sayit:
            Doch!
            weil:
            node v8 bis 8.12 ein Speicherleck hat
              @muckel sagte:
              RAM 15.5 GB
              Am verfügbaren RAM sicherlich nicht. Hier gibt es eine Lösung, falls Update auf Node 8.15.1 nicht helfen sollte.
                danke für die tipps! 🙂
                ich habs mal händisch gefixt. schau ma mal ob es nochmal kommt.
                update auf 8.15 oder 10.x macht auch mucken. 😞
                ich schau mir das morgen nochmals genauer an.
                  muckel last edited by muckel
                  der fix hat leider nichts gebracht. Wieder Absturz wg. memory
                  update auf 10.x:
                  Last login: Sat Mar 16 22:59:44 2019 from 192.168.0.4
                  erich@SmartHome:~$ sudo iobroker stop
                  Stopping iobroker controller daemon...
                  iobroker controller daemon stopped.
                  No "killall.sh" script found. Just stop.
                  erich@SmartHome:~$ sudo apt-get --purge remove node nodejs
                  Abhängigkeitsbaum wird aufgebaut.
                  Statusinformationen werden eingelesen.... Fertig
                  E: Paket node kann nicht gefunden werden.
                  erich@SmartHome:~$ sudo apt-get autoremove
                  0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                  erich@SmartHome:~$ node -v
                  v8.11.3
                  erich@SmartHome:~$ nodejs -v
                  v8.11.3
                  erich@SmartHome:~$ npm -v
                  6.7.0
                  was soll ich tun ohne alles zu schrotten?
                  Ubuntu 17.10
                  Liebe Grüße
                    So, Teilerfolg! 🙂
                    erich@SmartHome:/opt/iobroker$ npm -v
                    6.7.0
                    erich@SmartHome:/opt/iobroker$ node -v
                    v10.6.0
                    erich@SmartHome:/opt/iobroker$ nodejs -v
                    v10.6.0
                    Alles funktioniert außer MAXCUL. der findet den Serial Port nicht.
                    gelöscht und neu installiert hab ich den Adapter schon.
                    Gibt es da ein Problem mit V10.x?
                    RFLINK funktioniert!
                    Liebe Grüße
                      eine Frage hätte ich noch,
                      von V 10.6 auf die letzte V 10.15.x (ich glaube 3)
                      wie mache ich es richtig?
                      danke im voraus
                        node = 10.15.3
                        nodejs = 10.6
                        npm = 6.4.1
                        wie installiere ich die nodejs 10.15.3 damit die versionen gleich sind?
                        kann mir da wer einen Tip geben?
                        Homoran wendy2702 2 Replies Last reply Reply Quote 0
                        • wendy2702
                          wendy2702 last edited by
                          Linux?
                          Dann sollte dieser Sprung mit
                          apt update
                          apt upgrade
                          Gehen.
                          Nach dem ersten Befehl kann man sich mit
                          apt —upgradeable
                          Anzeigen lassen für welche Pakete es updates gibt.
                            @wendy2702 said in Error Javascript Adapter nach Sayit:
                            apt —upgradeable
                            ich habe ubuntu 17.10 installiert.
                            installiert er da nicht ubuntu 18.x?
                            • wendy2702
                              wendy2702 @wendy2702 last edited by
                              @wendy2702
                              Nein. Das wäre ein Distro update, der läuft anders.
                              Mache doch erstmal
                              apt update
                              Wenn du dir unsicher bist.
                              Was kommt dann?
                                apt -update ergibt:
                                erich@SmartHome:~$ sudo apt update
                                OK:1 http://at.archive.ubuntu.com/ubuntu artful InRelease
                                Holen:2 http://at.archive.ubuntu.com/ubuntu artful-updates InRelease [88,7 kB]
                                OK:3 https://deb.nodesource.com/node_10.x artful InRelease
                                Holen:4 http://at.archive.ubuntu.com/ubuntu artful-backports InRelease [74,6 kB]
                                OK:5 http://security.ubuntu.com/ubuntu artful-security InRelease
                                Es wurden 163 kB in 0 s geholt (216 kB/s).
                                Alle Pakete sind aktuell.
                                ich komme über 10.6 nicht hinaus
                                • wendy2702
                                  Scheinbar steht die neue Version noch nicht in drin:
                                  Link Text
                                  Dann wohl nur hiermit:
                                  Link Text
                                    genau:
                                    mit curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash - komme ich nur auf version 10.6
                                    17.10 ist nicht mehr supportet lt. UBUNTU. vielleicht liegt es daran?
                                    obwohl:
                                    https://deb.nodesource.com/node_10.x/pool/main/n/nodejs/https://deb.nodesource.com/node_10.x/pool/main/n/nodejs/nodejs_10.15.3-1nodesource1_arm64.deb
                                    • wendy2702
                                      wendy2702 @muckel last edited by
                                      Das wird es sein.
                                      Kannst es vielleicht noch über NVM
                                      Versuchen.
                                        Das traue ich mir nicht "probieren"
                                        Das "How To Install Node.js on Ubuntu "16.04"
                                        das ist für 16.04 und nicht für 17.10
                                        gerade mit nodejs node kann das System so zerschossen sein dass nichts mehr geht.
                                        meine reinstall.sh funktioniert auch seit Ewigkeiten nicht und die killall.sh meint er nicht zu finden, dabei sind beide Dateien im folder /opt/iobroker/ rechte auch OK.
                                        Momentan hab ich keine Idee mehr 😞
                                        • wendy2702
                                          Mach ein Backup... der Platte/SD Karte und von ioBroker.
                                          Oder lass es bei 10.6 oder hat es einen besonderen Grund für den Upgrade?
                                            Ja, viele WARN und ERR beim installieren von Adaptern.
                                            Ab und zu Abstürze vom Javascipt Adapter (1.5.7)
                                            Vielleicht geht das mit 10.15.3 weg. Das ist zumindest der Plan 😉
                                            Log vom heutigen Chromecast update.
                                            2019-03-19 17:13:24.219 - info: iobroker upgrade chromecast
                                            2019-03-19 17:13:24.743 - info: iobroker Update chromecast from @2.2.2 to @2.2.3
                                            2019-03-19 17:13:24.961 - info: iobroker NPM version: 6.4.1
                                            2019-03-19 17:13:25.182 - info: iobroker npm install iobroker.chromecast@2.2.3 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                                            2019-03-19 17:13:57.148 - info: iobroker ../src/contextify.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE ContextifyContext::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/contextify.cc:62:74: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                            ContextifyContext* ctx = new ContextifyContext(info[0]->ToObject());
                                            In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0,
                                            from ../src/contextify.cc:1:
                                            /home/erich/.node-gyp/10.15.3/include/node/v8.h:10046:15: note: declared here
                                            Local Value::ToObject() const {
                                            2019-03-19 17:13:57.152 - info: iobroker ../src/contextify.cc: In static member function ‘static v8::Local ContextWrap::createV8Context(v8::Local)’:../src/contextify.cc:131:68: error: no matching function for call to ‘v8::Function::NewInstance()’
                                            Local wrapper = Nan::New(constructor)->NewInstance();
                                            /home/erich/.node-gyp/10.15.3/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal v8::Function::NewInstance(v8::Local, int, v8::Local*) const
                                            V8_WARN_UNUSED_RESULT MaybeLocal NewInstance(
                                            2019-03-19 17:13:57.153 - info: iobroker /home/erich/.node-gyp/10.15.3/include/node/v8.h:3993:44: note: candidate expects 3 arguments, 0 provided/home/erich/.node-gyp/10.15.3/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal v8::Function::NewInstance(v8::Local) const
                                            /home/erich/.node-gyp/10.15.3/include/node/v8.h:3996:44: note: candidate expects 1 argument, 0 provided
                                            2019-03-19 17:13:57.154 - info: iobroker ../src/contextify.cc:150:16: error: ‘class v8::ObjectTemplate’ has no member named ‘SetAccessCheckCallbacks’; did you mean ‘SetAccessCheckCallback’? otmpl->SetAccessCheckCallbacks(GlobalPropertyNamedAccessCheck,
                                            2019-03-19 17:13:57.155 - info: iobroker ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertyGetter(v8::Local, const Nan::PropertyCallbackInfo&)’:../src/contextify.cc:176:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                            Local data = info.Data()->ToObject();
                                            2019-03-19 17:13:57.156 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                            2019-03-19 17:13:57.156 - info: iobroker ../src/contextify.cc:182:80: error: no matching function for call to ‘v8::Object::GetRealNamedProperty(v8::Local&)’ Local rv = Nan::New(ctx->sandbox)->GetRealNamedProperty(property);
                                            /home/erich/.node-gyp/10.15.3/include/node/v8.h:3562:43: note: candidate: v8::MaybeLocal v8::Object::GetRealNamedProperty(v8::Local, v8::Local)
                                            V8_WARN_UNUSED_RESULT MaybeLocal GetRealNamedProperty(
                                            /home/erich/.node-gyp/10.15.3/include/node/v8.h:3562:43: note: candidate expects 2 arguments, 1 provided
                                            ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertySetter(v8::Local, v8::Local, const Nan::PropertyCallbackInfo&)’:
                                            ../src/contextify.cc:192:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                            2019-03-19 17:13:57.157 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                            2019-03-19 17:13:57.157 - info: iobroker ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertyQuery(v8::Local, const Nan::PropertyCallbackInfo&)’:../src/contextify.cc:203:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                            2019-03-19 17:13:57.160 - info: iobroker ../src/contextify.cc:209:67: error: no matching function for call to ‘v8::Object::GetRealNamedProperty(v8::Local&)’ if (!Nan::New(ctx->sandbox)->GetRealNamedProperty(property).IsEmpty() ||
                                            2019-03-19 17:13:57.160 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                            ../src/contextify.cc:210:71: error: no matching function for call to ‘v8::Object::GetRealNamedProperty(v8::Local&)’
                                            !Nan::New(ctx->proxyGlobal)->GetRealNamedProperty(property).IsEmpty()) {
                                            2019-03-19 17:13:57.161 - info: iobroker ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertyDeleter(v8::Local, const Nan::PropertyCallbackInfo&)’:../src/contextify.cc:218:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                            2019-03-19 17:13:57.161 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                            2019-03-19 17:13:57.163 - info: iobroker ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertyEnumerator(const Nan::PropertyCallbackInfo&)’:../src/contextify.cc:229:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                            2019-03-19 17:13:57.163 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                            2019-03-19 17:13:57.169 - info: iobroker ../src/contextify.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE ContextifyScript::RunInContext(Nan::NAN_METHOD_ARGS_TYPE)’:../src/contextify.cc:319:62: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                            if (!ContextifyContext::InstanceOf(info[0]->ToObject()))
                                            2019-03-19 17:13:57.169 - info: iobroker ../src/contextify.cc:322:95: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] ContextifyContext* ctx = Nan::ObjectWrap::Unwrap(info[0]->ToObject());
                                            2019-03-19 17:13:57.297 - info: iobroker make: *** [Release/obj.target/contextify/src/contextify.o] Fehler 1
                                            2019-03-19 17:13:57.298 - info: iobroker gyp
                                            2019-03-19 17:13:57.299 - info: iobroker
                                            2019-03-19 17:13:57.299 - info: iobroker ERR! build error
                                            2019-03-19 17:13:57.299 - info: iobroker gyp
                                            2019-03-19 17:13:57.300 - info: iobroker ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                                            gyp ERR! stack at ChildProcess.emit (events.js:189:13)
                                            gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                            2019-03-19 17:13:57.300 - info: iobroker gyp ERR! System Linux 4.13.0-46-genericgyp
                                            2019-03-19 17:13:57.301 - info: iobroker ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/contextify
                                            gyp ERR! node -v v10.15.3
                                            gyp ERR!
                                            2019-03-19 17:13:57.301 - info: iobroker node-gyp -v v3.8.0gyp ERR! not ok
                                            2019-03-19 17:13:59.626 - info: iobroker npm
                                            2019-03-19 17:13:59.627 - info: iobroker WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/arraybuffer.slic/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/base64-arraybuff/package.json'
                                            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-schedule/node_modules/cron-parser/node_modules/is-nan/node_modules/define-properties/node_modules/obj/package.json'
                                            npm
                                            2019-03-19 17:13:59.627 - info: iobroker WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/node_modules/cliui/node_modules/wrap-ansi/node_modules/string-width/node_modules/is-fullwidth-code-p/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-/package.json'
                                            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_modules/cross-spawn/node_modules/which/node_modules/i/package.json'
                                            2019-03-19 17:13:59.628 - info: iobroker npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none is installed. You must install peer dependencies yourself.
                                            2019-03-19 17:13:59.628 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                            npm WARN
                                            2019-03-19 17:13:59.629 - info: iobroker optional SKIPPING OPTIONAL DEPENDENCY: contextify@0.1.15 (node_modules/contextify):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: contextify@0.1.15 install: node-gyp rebuild
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                            2019-03-19 17:13:59.630 - info: iobroker
                                            2019-03-19 17:13:59.657 - info: iobroker npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.chromecast"
                                            1.1k
                                            81.1k
                                            error javascript adapter
                                            3195
