    4. Fehler nach Update Admin und Javascript-Adapter
    UNSOLVED Fehler nach Update Admin und Javascript-Adapter
      SegaPro last edited by
      am Wochenende habe ich ein Update des Admins und des Javascript-Adapters gemacht.
      Das Update selbst hat reibungslos funktioniert. Grundsätzlich scheint auch alles noch zu funktionieren. Allerdings bekomme ich alle paar Sekunden folgene Fehler in den Log um die Ohren gehauen:
      javascript.0	2019-03-18 10:28:06.929	warn	at TCP.onread (net.js:601:20)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket.Readable.push (_stream_readable.js:208:10)
      javascript.0	2019-03-18 10:28:06.929	warn	at readableAddChunk (_stream_readable.js:250:11)
      javascript.0	2019-03-18 10:28:06.929	warn	at addChunk (_stream_readable.js:263:12)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket.emit (events.js:211:7)
      javascript.0	2019-03-18 10:28:06.929	warn	at emitOne (events.js:116:13)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket._ultron.on (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:138:22)
      javascript.0	2019-03-18 10:28:06.929	warn	at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:139:10)
      javascript.0	2019-03-18 10:28:06.929	warn	at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:165:16)
      javascript.0	2019-03-18 10:28:06.929	warn	at Receiver.getData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:330:12)
      javascript.0	2019-03-18 10:28:06.929	warn	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
      javascript.0	2019-03-18 10:28:06.929	warn	at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
      javascript.0	2019-03-18 10:28:06.929	warn	at WebSocket.emit (events.js:211:7)
      javascript.0	2019-03-18 10:28:06.929	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
      javascript.0	2019-03-18 10:28:06.929	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
      javascript.0	2019-03-18 10:28:06.929	warn	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2019-03-18 10:28:06.929	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2019-03-18 10:28:06.929	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-18 10:28:06.929	warn	at WS.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-18 10:28:06.929	warn	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
      javascript.0	2019-03-18 10:28:06.929	warn	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
      javascript.0	2019-03-18 10:28:06.929	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-18 10:28:06.929	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-18 10:28:06.929	warn	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
      javascript.0	2019-03-18 10:28:06.929	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-18 10:28:06.929	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0	2019-03-18 10:28:06.929	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-03-18 10:28:06.929	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-03-18 10:28:06.929	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
      javascript.0	2019-03-18 10:28:06.929	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
      javascript.0	2019-03-18 10:28:06.929	warn	at Object.<anonymous> (script.js.Verbrauchswerte.Stromerzeugung:5:9)
      javascript.0	2019-03-18 10:28:06.929	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
      javascript.0	2019-03-18 10:28:06.929	warn	Wrong type of javascript.0.Verbrauchszaehler.Stromerzeugung: "number". Please fix, while deprecated and will not work in next versions.
      Leider kann ich damit absolut nichts anfangen. Etwas vergleichbares habe ich hier im Forum nicht gefunden. Kann mir jemand sagen, welche Ziege ich wo bei Vollmond opfern muss, damit diese Fehler der Vergangenheit angehören?
      Vielen Dank und liebe Grüße
      Miguel
      wendy2702 paul53 M 3 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @SegaPro last edited by
        @SegaPro sagte in Fehler nach Update Admin und Javascript-Adapter:
        Bin nicht der Javascript Experte aber hier könnte etwas mit dem Object nicht stimmen.
          paul53 @SegaPro last edited by
          @SegaPro sagte:
          Das Skript "Verbrauchswerte.Stromerzeugung" will eine Zahl in den Datenpunkt "javascript.0.Verbrauchszaehler.Stromerzeugung" schreiben, der nicht vom Typ "Zahl"(number) ist.
            Matze89 @SegaPro last edited by
            @SegaPro
            Habe auch Probleme, selbe fehlermeldungen wie du.
            Iobroker letztes wochenende neu aufgesetzt backup eingespielt im log ständige fehler meldungen von objekten/skripten die vorher funktioniert haben.
            Bei mir ist es teilweise so viel mit den warn logs das der JavaScript adapter kurz abstürzt und paar sek. später Neustartet
            Selbst ein downgrade von js adapter brachte kein erfolg.
            Aktuell bin ich auf :
            Node js 8.15.1
            Npm 6.4.1
            Js controller 1.4.2
            Java adapter 4.0.12
            Hab leider auch noch keine lösung dafür, selbst wenn ich die objekte abändere auf "zeichenkette,zahl,feld oder andere"
              Danke für eure Antworten. Das mit dem Fehler in dem Verbrauchsscript könnt ihr ignorieren - da hab ich einfach schlampig gearbeitet und muss noch etwas anpassen.
              Ich meinte eigentlich eher die anderen Fehler nicht nicht auf ein spezielles Script bezogen sind. Es liest sich ja fast so, als wäre das irgendwie ein Bug? Allerdings frage ich mich dann, wieso nur Matze89 und ich das Problem haben?
              Viele Grüße
              Miguel
              • wendy2702
                wendy2702 last edited by
                Kommen die anderen Fehler denn auch wenn du das Verbrauchsskript" mal deaktivierst?
                  Du hattest recht - ich habe den Zusammenhang nicht gesehen. Erst, als Du mich mit der Nase drauf gestossen hast.
                  Es war das Script - das habe ich nun gefixt, jetzt ist auch der Fehler weg.
                  Danke für den Schubs in die richtige Richtung. 🙂
                  81.1k
                  fehlermeldung update
