    5. Fehler im Log bei Fenster Aufzählung
      Fuga last edited by
      Hi All,
      ich habe leider von JS nicht viel Ahnung daher muss ich leider Frag. Ich verstehe diese Fehlermeldung leider nicht:
      javascript.0 2019-03-19 19:17:05.709 warn at TCP.onread (net.js:559:20)
      javascript.0 2019-03-19 19:17:05.709 warn at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0 2019-03-19 19:17:05.709 warn at readableAddChunk (_stream_readable.js:176:18)
      javascript.0 2019-03-19 19:17:05.709 warn at Socket.emit (events.js:188:7)
      javascript.0 2019-03-19 19:17:05.709 warn at emitOne (events.js:96:13)
      javascript.0 2019-03-19 19:17:05.709 warn at Socket._ultron.on (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:138:22)
      javascript.0 2019-03-19 19:17:05.709 warn at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:139:10)
      javascript.0 2019-03-19 19:17:05.709 warn at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:165:16)
      javascript.0 2019-03-19 19:17:05.708 warn at Receiver.getData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:330:12)
      javascript.0 2019-03-19 19:17:05.708 warn at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
      javascript.0 2019-03-19 19:17:05.708 warn at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
      javascript.0 2019-03-19 19:17:05.708 warn at WebSocket.emit (events.js:188:7)
      javascript.0 2019-03-19 19:17:05.708 warn at emitOne (events.js:96:13)
      javascript.0 2019-03-19 19:17:05.708 warn at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
      javascript.0 2019-03-19 19:17:05.708 warn at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
      javascript.0 2019-03-19 19:17:05.708 warn at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0 2019-03-19 19:17:05.708 warn at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0 2019-03-19 19:17:05.707 warn at WS.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
      javascript.0 2019-03-19 19:17:05.707 warn at WS.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
      javascript.0 2019-03-19 19:17:05.707 warn at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
      javascript.0 2019-03-19 19:17:05.707 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
      javascript.0 2019-03-19 19:17:05.707 warn at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0 2019-03-19 19:17:05.707 warn at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
      javascript.0 2019-03-19 19:17:05.707 warn at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
      javascript.0 2019-03-19 19:17:05.707 warn at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
      javascript.0 2019-03-19 19:17:05.707 warn at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0 2019-03-19 19:17:05.707 warn at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
      javascript.0 2019-03-19 19:17:05.706 warn at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
      javascript.0 2019-03-19 19:17:05.706 warn at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0 2019-03-19 19:17:05.706 warn at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      javascript.0 2019-03-19 19:17:05.706 warn at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
      javascript.0 2019-03-19 19:17:05.706 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
      javascript.0 2019-03-19 19:17:05.706 warn at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0 2019-03-19 19:17:05.706 warn at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0 2019-03-19 19:17:05.706 warn at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
      javascript.0 2019-03-19 19:17:05.706 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
      javascript.0 2019-03-19 19:17:05.702 warn at Object.<anonymous> (script.js.Aufzählung.countOpenWindowsDoors:38:3)
      javascript.0 2019-03-19 19:17:05.702 warn at countOpenWindowsDoors (script.js.Aufzählung.countOpenWindowsDoors:33:3)
      javascript.0 2019-03-19 19:17:05.702 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
      javascript.0 2019-03-19 19:17:05.696 warn Wrong type of Datenpunkte.0.StatusWindowOpen: "number". Please fix, while deprecated and will not work in next versions.
      Das Scribt dazu sieht so aus:
      function countOpenWindowsDoors()
      var openWindows = 0;
      var openDoors = 0;
      // Fenster
      var windows = getObject("enum.functions.windowstatus").common.members;
      for(let i = 0; i < windows.length; i++) {
      var Status = getState(windows[i]).val;
      if ( Status ) { openWindows = openWindows + 1; }
      // Türen
      var doors = getObject("enum.functions.doorstatus").common.members;
      for(let i = 0; i < doors.length; i++) {
      var Status = getState(doors[i]).val;
      if ( Status ) { openDoors = openDoors + 1; }
      var openWindowsText = "Kein Fenster geöffnet";
      var openDoorText = "Keine Tür geöffnet";
      if ( openWindows > 0 ) {
      openWindowsText = openWindows + " Fenster geöffnet";
      if ( openDoors > 0 ) {
      openDoorText = openDoors + " Türe(n) geöffnet";
      setState("Datenpunkte.0.StatusDoorOpenText", openDoorText);
      setState("Datenpunkte.0.StatusWindowOpenText", openWindowsText);
      setState("Datenpunkte.0.StatusDoorOpen", openDoors);
      setState("Datenpunkte.0.StatusWindowOpen", openWindows);
      $('state(functions=windowstatus)').on(function(obj) {
      countOpenWindowsDoors();
      $('state(functions=doorstatus)').on(function(obj) {
      Hoffe mir kann wer helfen. Vielen Dank
        paul53 @Fuga last edited by
        @Fuga sagte:
        Die Datenpunkt-Art von "Datenpunkte.0.StatusWindowOpen" in Zahl (number) ändern !
          Fuga last edited by
          Das hatte ich schon gemacht. Musste den Daten Punkt nochmal Löschen und neu erstellen. Jetzt geht es. vielen Danke
