    4. [gelöst]Meross Adapter Gelb
    SOLVED [gelöst]Meross Adapter Gelb
    • sigi234
      sigi234 Forum Testing Most Active last edited by sigi234
      Hallo, Adapter bleibt Gelb.....wurde schon von einigen User berichtet. Auch in Facebook.
      Via Handy geht es aber.
      Edit: Geht wieder!
      Debug Log
      undefined2019-03-20 01:18:46.421  - info: host.Medion object change system.adapter.meross.0
      2019-03-20 01:18:46.467  - info: host.Medion instance system.adapter.meross.0 started with pid 4080
      2019-03-20 01:18:47.135  - debug: meross.0 objectDB connected
      2019-03-20 01:18:47.150  - debug: meross.0 statesDB connected
      2019-03-20 01:18:47.150  - info: meross.0 starting. Version 1.0.0 in C:/ioBroker/node_modules/iobroker.meross, node: v8.15.1
      2019-03-20 01:18:47.221  - debug: meross.0 connected set to false
      2019-03-20 01:18:52.918  - info: host.Medion object change system.adapter.meross.0
      2019-03-20 01:18:52.918  - info: host.Medion stopInstance system.adapter.meross.0
      2019-03-20 01:18:52.918  - info: host.Medion stopInstance system.adapter.meross.0 killing pid 4080
      2019-03-20 01:18:52.939  - warn: host.Medion instance system.adapter.meross.0 terminated due to SIGTERM
      2019-03-20 01:18:52.939  - info: host.Medion instance system.adapter.meross.0 terminated with code null ()
      2019-03-20 01:18:55.472  - info: host.Medion instance system.adapter.meross.0 started with pid 11832
      2019-03-20 01:18:55.986  - debug: meross.0 objectDB connected
      2019-03-20 01:18:55.994  - debug: meross.0 statesDB connected
      2019-03-20 01:18:56.009  - info: meross.0 starting. Version 1.0.0 in C:/ioBroker/node_modules/iobroker.meross, node: v8.15.1
      2019-03-20 01:18:56.082  - debug: meross.0 connected set to false
      2019-03-20 01:19:00.128  - info: javascript.0 script.js.Sigi.UWZ: []
      2019-03-20 01:19:09.323  - error: meross.0 Meross Connection Error: Error: 1402: A
      Jens Bräunel 1 Reply Last reply Reply Quote 0
      • Jens Bräunel
        Jens Bräunel @sigi234 last edited by
        @sigi234
        Hallo sigi,
        wie hat sich das Problem bei dir damals behoben?
        Ich hab aktuell das gleiche Problem und irgendwie hilft nichts. (Neuinstallation des Adapter, Passwortänderung bei Meross, usw.)
        Viel Grüße
        • sigi234
          sigi234 Forum Testing Most Active @Jens Bräunel last edited by
          @Jens-Bräunel
          Welche Version?
          • Jens Bräunel
            @sigi234
            ich hab jetzt die 1.5.0 installiert.
            Mit der Handy app geht alles.
            meross gelb
