    4. [gelöst] Homekit: hilfe bei Installation
    • I
      iben last edited by
      beim Versuch Homekit auf Ubuntu zu installieren erhalte ich folgende Meldung:
      root@ubuntu2cpu:/opt/iobroker# ./iobroker add homekit
      host.ubuntu2cpu install adapter homekit
      npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call)
      npm http GET https://registry.npmjs.org/iobroker.homekit
      npm http 304 https://registry.npmjs.org/iobroker.homekit
      npm http GET https://registry.npmjs.org/hap-nodejs/0.2.6
      npm http GET https://registry.npmjs.org/yalm
      npm http GET https://registry.npmjs.org/yargs
      npm http 200 https://registry.npmjs.org/yargs
      npm http 304 https://registry.npmjs.org/yalm
      npm http 304 https://registry.npmjs.org/hap-nodejs/0.2.6
      npm http GET https://registry.npmjs.org/ansi-styles
      npm http GET https://registry.npmjs.org/camelcase
      npm http GET https://registry.npmjs.org/cliui
      npm http GET https://registry.npmjs.org/decamelize
      npm http GET https://registry.npmjs.org/os-locale
      npm http GET https://registry.npmjs.org/string-width
      npm http GET https://registry.npmjs.org/window-size
      npm http GET https://registry.npmjs.org/y18n
      npm http GET https://registry.npmjs.org/debug
      npm http GET https://registry.npmjs.org/node-persist
      npm ERR! not found: git
      npm ERR!
      npm ERR! Failed using git.
      npm ERR! This is most likely not a problem with npm itself.
      npm ERR! Please check if you have git installed and in your PATH.
      npm ERR! System Linux 3.19.0-25-generic
      npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "--production" "--prefix" "/opt/iobroker"
      npm ERR! cwd /opt/iobroker
      npm ERR! node -v v0.10.25
      npm ERR! npm -v 1.3.10
      npm ERR! code ENOGIT
      npm http 304 https://registry.npmjs.org/ansi-styles
      npm http GET https://registry.npmjs.org/color-convert
      npm http 304 https://registry.npmjs.org/camelcase
      npm http 304 https://registry.npmjs.org/y18n
      npm http 304 https://registry.npmjs.org/string-width
      npm http 304 https://registry.npmjs.org/decamelize
      npm http 304 https://registry.npmjs.org/window-size
      npm http 304 https://registry.npmjs.org/cliui
      npm http 304 https://registry.npmjs.org/os-locale
      npm http 304 https://registry.npmjs.org/debug
      npm http 304 https://registry.npmjs.org/color-convert
      npm http GET https://registry.npmjs.org/strip-ansi
      npm http GET https://registry.npmjs.org/code-point-at
      npm http GET https://registry.npmjs.org/is-fullwidth-code-point
      npm http GET https://registry.npmjs.org/lcid
      npm http GET https://registry.npmjs.org/wrap-ansi
      npm http 304 https://registry.npmjs.org/strip-ansi
      npm http 304 https://registry.npmjs.org/code-point-at
      npm http 304 https://registry.npmjs.org/lcid
      npm http 304 https://registry.npmjs.org/is-fullwidth-code-point
      npm http 304 https://registry.npmjs.org/wrap-ansi
      npm http GET https://registry.npmjs.org/invert-kv
      npm http GET https://registry.npmjs.org/ansi-regex
      npm http GET https://registry.npmjs.org/number-is-nan
      npm http 304 https://registry.npmjs.org/invert-kv
      npm http 304 https://registry.npmjs.org/ansi-regex
      npm http 304 https://registry.npmjs.org/number-is-nan
      npm http 304 https://registry.npmjs.org/node-persist
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /opt/iobroker/npm-debug.log
      npm ERR! not ok code 0
      host.ubuntu2cpu Cannot install iobroker.homekit: 1
      Kann mir da jemand helfen?
      Danke,
      Marco
      • N
        nobody last edited by
        Hallo iben,
        ich hab selbst Debian und nicht ubuntu aber wenn git (Versionsmanagementsystem) nicht installiert ist, würde ich es einfach installieren.
        Das geht bei diesen beiden beiden Linux-Distributionen gleich:
        sudo apt-get install git
          aquapro last edited by
          Ohne git kann man git nicht verwenden. 😉
          War die tage schon mal die gleiche Frage, dabei steht es doch genau in der Meldung.
          Wie nobody schon schrieb, git installieren und noch einmal probieren.
          Tino
          • I
            iben last edited by
            Oh, Brett vorm Kopf, da ich einige Adapter am laufen habe, bin ich nicht davon ausgegangen das hinsichtlich einer Installation, etwas fehlen könnte.
            Dankeschön.
              Super!
              Aber genau für sowas sollte auch ein Forum da sein, wenn mal das Brett vor dem Kopf im Weg ist. :lol:
