    5. Bitte Hilfe bei Interpretation von Fehlermeldungen
      skorpil last edited by
      ich erhalte bei der Scriptausführung folgende Warnhinweise:
      javascript.0	2019-03-24 08:23:01.124	warn	at TCP.onread (net.js:601:20)
      javascript.0	2019-03-24 08:23:01.124	warn	at Socket.Readable.push (_stream_readable.js:208:10)
      javascript.0	2019-03-24 08:23:01.124	warn	at readableAddChunk (_stream_readable.js:250:11)
      javascript.0	2019-03-24 08:23:01.124	warn	at addChunk (_stream_readable.js:263:12)
      javascript.0	2019-03-24 08:23:01.124	warn	at Socket.emit (events.js:211:7)
      javascript.0	2019-03-24 08:23:01.124	warn	at emitOne (events.js:116:13)
      javascript.0	2019-03-24 08:23:01.124	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
      javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
      javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
      javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
      javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
      javascript.0	2019-03-24 08:23:01.124	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
      javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
      javascript.0	2019-03-24 08:23:01.124	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
      javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
      javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.emit (events.js:214:7)
      javascript.0	2019-03-24 08:23:01.124	warn	at emitTwo (events.js:126:13)
      javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
      javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      javascript.0	2019-03-24 08:23:01.124	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2019-03-24 08:23:01.123	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2019-03-24 08:23:01.123	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-24 08:23:01.123	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      javascript.0	2019-03-24 08:23:01.123	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-24 08:23:01.123	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-24 08:23:01.123	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-24 08:23:01.123	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      javascript.0	2019-03-24 08:23:01.123	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-24 08:23:01.123	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
      javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
      javascript.0	2019-03-24 08:23:01.123	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-03-24 08:23:01.123	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-03-24 08:23:01.123	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-03-24 08:23:01.123	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
      javascript.0	2019-03-24 08:23:01.123	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
      javascript.0	2019-03-24 08:23:01.123	warn	at Object.<anonymous> (script.js.common.Skripte_aktiviert.homematic_Variablen_aus_openweathermap:19:1)
      javascript.0	2019-03-24 08:23:01.123	warn	at Wetterdatenholenundsetzen (script.js.common.Skripte_aktiviert.homematic_Variablen_aus_openweathermap:123:5)
      javascript.0	2019-03-24 08:23:01.123	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
      javascript.0	2019-03-24 08:23:01.123	warn	Wrong type of hm-rega.0.29959: "object". Please fix, while deprecated and will not work in next versions.
      Was will mir de Adapter sagen?
      dslraser Homoran paul53 3 Replies Last reply Reply Quote 0
      • dslraser
        dslraser Forum Testing Most Active @skorpil last edited by
        @skorpil
        willst Du was in hm.rega schreiben ?
        (vielleicht mit dem falschen Angaben)
        Aber ohne das Script zu sehen....?
          Homoran Global Moderator Administrators @skorpil last edited by
          @skorpil sagte in Bitte Hilfe bei Interpretation von Fehlermeldungen:
          Steht doch da 😉
          Was liefert das Skript für einen Wert?
          Was ist der Datenpunkt für ein Typ?
          • sigi234
            Ich schätze er will von openweathermap eine Zahl in die CCU schreiben, diese ist wahrscheinlich als String und nicht als Zahl gesetzt.........
              Wow, seid Ihr schnell. Vielen Dank. sigi234 hat Recht. die Idee ist, aus openweathermap Werte in CCU Variablen zu schreiben.
              Hier mal das Script. Aber bitte nicht lachen. Ich bin kein JavaScript Profi. Dass kann man sicher alles effizienter und eleganter programmieren. Aber so entspricht das eben meinen Fähigkeiten.
              //    Wetterdaten aus openweathermap holen und in homematic Variable setzen
              // Aktualisierung der homematic Variable bei Aktualisierung openweathermap
              on ({id:'openweathermap.0.forecast.current.date'/*Actual date*/, change: 'any'}, function(data) {
              //Werte holen und setzen
              //Wetter Bedingung als String
              var idOpenWeater = 'openweathermap.0.forecast.current.state'/*Actual state*/;
              var idVariable = 'hm-rega.0.29954'/*Wetter Bedingungen*/;
              wetterdaten = getState(idOpenWeater).val
              if(wetterdaten == "null"){
                     wetterdaten = "windstill";
              setState(idVariable, wetterdaten);
              //Wetter Richtung als Zahl
              var idOpenWeater = 'openweathermap.0.forecast.current.windDirection'/*Forecast for wind direction*/;
              var idVariable = 'hm-rega.0.29959'/*Wetter Windrichtg*/;
              Wetterdatenholenundsetzen();
              //Wind Richtung als Angabe
              var idVariable = 'hm-rega.0.29958'/*Wetter Windrichtung*/;
                  //******************* Windrichtung bestimmen***************
                  //*******************Nord 339-23, Nordost 24-68, Ost 69-113, SüdOst 114-158, Süd 159-203, SüdWest 204-248, West 249-293, NordWest 394-338***************
                     wetterdaten = 0;
                  if (wetterdaten > 23 && wetterdaten <= 68){
                      wetterdaten = "NordOst";
                  if (wetterdaten > 68 && wetterdaten <= 113){
                      wetterdaten = "Ost";
                  if (wetterdaten > 113 && wetterdaten <= 158){
                      wetterdaten = "SüdOst";
                  if (wetterdaten > 158 && wetterdaten <= 203){
                      wetterdaten = "Süd";
                  if (wetterdaten > 203 && wetterdaten <= 248){
                      wetterdaten = "SüdWest";
                  if (wetterdaten > 248 && wetterdaten <= 293){
                      wetterdaten = "West";
                  if (wetterdaten > 293 && wetterdaten <= 338){
                      wetterdaten = "NordWest";
                  if (wetterdaten > 338 && wetterdaten <= 360){
                      wetterdaten = "Nord";
                  if (wetterdaten > 0 && wetterdaten <= 23){
              //Temperatur als Zahl
              var idOpenWeater = 'openweathermap.0.forecast.current.temperature'/*Actual temperature for today*/
              var idVariable = 'hm-rega.0.29955'/*Wetter Temperatur*/;
              //Luftfeuchtigkeit als Zahl
              var idOpenWeater = 'openweathermap.0.forecast.current.humidity'/*Actual humidity*/
              var idVariable = 'hm-rega.0.29956'/*Wetter Luftfeuchte*/;
              //Windgeschwindigkeit als Zahl
              var idOpenWeater = 'openweathermap.0.forecast.current.windSpeed'/*Forecast for wind speed*/
              var idVariable = 'hm-rega.0.29960'/*Wetter Windgeschwindigkeit*/;
              //Aktualisierung (Zeit)
              var idOpenWeater = 'openweathermap.0.forecast.current.date'/*Actual date*/;
              var idVariable = 'hm-rega.0.29953'/*Wetter Aktualisierung*/;
              wetterdaten = getState(idOpenWeater).val;
              var date = new Date(wetterdaten);
              // Umwandeln in deutsches Format
                  //Tagesdatum ermitteln
                  var tag = date.getDate();
                  //Monat ermitteln
                  var month = new Array("1","2","3","4","5","6","7","8","9","10","11","12");
                  var monat = month[date.getMonth()];
                  //Jahr ermitteln
                  var jahr = date.getFullYear();
                  //Stunde ermitteln
                  var stunde = date.getHours();
                  //Minute ermitteln
                  var minute = date.getMinutes();
                  //Sekunde ermitteln
                  var sekunde = date.getSeconds();
              var ausgabe = tag + "." + monat + "." + jahr + "   " + stunde + ":" + minute + ":" + sekunde;
              setState(idVariable, ausgabe);
              //                  FUNKTION Holen und setzen
               function Wetterdatenholenundsetzen() {
              Nun aber zur Frage: das mit String und Zahl hatte ich mir auch schon überlegt. Aber wie ich das löse, das weiß ich nicht und benötige Hilfe.
              Homoran sigi234 2 Replies Last reply Reply Quote 0
                @skorpil
                Dazu gibt es zwei Möglichkeiten
                Daher bitte meine Fragen beantworten
                • sigi234
                  sigi234 Forum Testing Most Active @skorpil last edited by sigi234
                  @skorpil
                  Bespiel Duty Cycle in CCU schreiben:
                  // DP in SV schreiben
                  const idDP = "hm-rega.0.NEQ1531999.0.DUTY_CYCLE";
                  const idSV = "hm-rega.0.30785";
                  setState(idSV, parseFloat(getState(idDP).val)); // Skriptstart
                  on(idDP, function(dp) {  // Wertänderung
                     setState(idSV, parseFloat(dp.state.val));
                    Homoran Global Moderator Administrators @Homoran last edited by
                    @Homoran sagte in Bitte Hilfe bei Interpretation von Fehlermeldungen:
                      @Homoran, hm-rega.0.29959 ist vom Typ Zahl. Und eigentlich sollte das Script auch eine Zahl liefern.
                      @sigi234 muß ich immer mit "parseFloat" arbeiten?
                        da der Fehler nicht immer auftritt: es scheint, dass der Adapter "openweathermap" für den Fall, daß keine Werte vorhanden sind, statt einer "Zahl" eine "null" liefert. Und das kann mein Script dann nicht mehr verarbeiten. Ich bin auch nicht sicher, ob "null" ein string oder ein logikwert ist. Irritierend.
                          paul53 @skorpil last edited by
                          @skorpil sagte:
                          Wenn der Wert ein Object enthält, wird parseFloat() nicht helfen. Schau Dir den Wert mal mit einem zusätzlichen Log an.
                          log(JSON.stringify(getState(idOpenWeather).val));
                          Variablen nur einmal deklarieren (var nur in den Zeilen 12, 13) !
                            @skorpil sagte:
                            Dann ist das der Grund für die Warnung: null ist ein Objekt !
                            S sigi234 2 Replies Last reply Reply Quote 1
                              skorpil @paul53 last edited by
                              @paul53 Danke. Und wie könnte ich das abfangen? Also, irgendwas wie "wenn objekt, dann....."
                              • sigi234
                                sigi234 Forum Testing Most Active @paul53 last edited by sigi234
                                @paul53 sagte in Bitte Hilfe bei Interpretation von Fehlermeldungen:
                                Und wieder was gelernt....
                                Zitat:
                                parseFloat kann zudem Objekte parsen, wenn diese eine toString- oder valueOf-Methode haben. Das Ergebnis ist dasselbe, als wenn parseFloat mit dem Ergebnis einer dieser beiden Methoden ausgerufen wurde.
                                  @skorpil sagte:
                                      if(wetterdaten) setState(idVariable, wetterdaten);
                                    skorpil last edited by skorpil
                                    merci, ich werde testen und berichten
                                      @paul53 dankeschön, das war es: "if (wetterdaten)". Denn augenscheinlich liefert der Adapter manchmal eben leere Objekte.
                                        @paul53 noch eine Frage: jetzt reagiert das Script ja nur, wenn ein Wert vorhanden ist. Eben durch die Abfrage if(Variable). Wie würde man das Gegenteil programmieren, also wenn „kein“ Wert vorhanden, dann.... ich würde nämlich gerne in meine CCU Variable noch schreiben, wenn kein Wert, dann „keine Angabe“.
                                          paul53 @skorpil last edited by paul53
                                          @skorpil sagte:
                                              if(wetterdaten === null) wetterdaten = 'keine Angabe';
                                          EDIT: Vergleich geändert, da Wert 0 ein gültiger Wert ist, der vorkommen kann.
                                            @paul53 großartig! Vielen Dank u. nun ein schönes Wochenende.
                                            PS: ...wenn es dieses Forum nicht gäbe...
                                            javascript
                                            905
