    4. "npm ERR! pna.nextTick is not a function" bei Adapter Installation
    SOLVED "npm ERR! pna.nextTick is not a function" bei Adapter Installation
      mawin last edited by Negalein
      ich habe ein problem mit meiner iobroker Installation, besser gesagt mit NPM. Bei einer Adpater-Installation (egal welche) erscheint der Fehler :
      *******$ ./iobroker add bring  --host ioBroker-02
      NPM version: 6.4.1
      npm install iobroker.bring --production --save --prefix "/opt/iobroker" (System call)
      npm ERR! asyncWrite is not a function
      npm ERR! /home/iobroker/.npm/_logs/2019-03-27T10_34_01_614Z-debug.log
      host.ioBroker-02 install adapter bring
      NPM version: 6.4.1
      npm ERR! /home/iobroker/.npm/_logs/2019-03-27T10_34_09_415Z-debug.log
      NPM version: 6.4.1
      npm ERR! /home/iobroker/.npm/_logs/2019-03-27T10_34_17_043Z-debug.log
      ERROR: host.ioBroker-02 Cannot install bring
      ERROR: process exited with code 13*******
      Ein 'npm cache verify' bringt ein ähnliches Problem:
      Unhandled rejection TypeError: pna.nextTick is not a function
          at emitReadable (/usr/local/lib/node_modules/npm/node_modules/readable-stream/lib/_stream_readable.js:498:25)
          at onEofChunk (/usr/local/lib/node_modules/npm/node_modules/readable-stream/lib/_stream_readable.js:486:3)
          at readableAddChunk (/usr/local/lib/node_modules/npm/node_modules/readable-stream/lib/_stream_readable.js:257:5)
          at Class.Readable.push (/usr/local/lib/node_modules/npm/node_modules/readable-stream/lib/_stream_readable.js:245:10)
          at readdirOrEmpty.map.then (/usr/local/lib/node_modules/npm/node_modules/cacache/lib/entry-index.js:135:12)
          at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
          at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:512:31)
          at Promise._settlePromise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:569:18)
          at Promise._settlePromise0 (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
          at Promise._settlePromises (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
          at Promise._fulfill (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:638:18)
          at MappingPromiseArray.PromiseArray._resolve (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise_array.js:126:19)
          at MappingPromiseArray.init (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise_array.js:74:18)
          at Promise._settlePromise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
      npm ERR!     /root/.npm/_logs/2019-03-27T10_18_31_266Z-debug.log
      Das Problem kann erst seit ein paar Tagen bestehen. Ein npm, node oder nodejs Update habe ich nicht durchgeführt. Meine Versionen wie folgt :
      npm 6.4.1
      nodejs v8.15.1
      node v8.15.1
      Das Letzte an was ich mich erinnern kann, ich habe die Anleitung des radar-Adapters befolgt. Befehle darin sind :
      sudo apt-get install fping arp-scan
      sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
      sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
      Ob der Fehler damit zu tun hat kann ich aber nicht sagen.
      Vielen Dank für Eure Hilfe!
        Problem wurde wie folgt behoben :
        cd /usr/local/lib/node_modules
        sudo mv npm npmold
        sudo -H npm install -g npm@6
        Das soweit als Info, ohne Gewähr.
        • Dutchman
          @mawin sagte in "npm ERR! pna.nextTick is not a function" bei Adapter Installation:
          iobroker add bring
          ich kan den Fehler nicht reproduzieren, adapter mal komplett gelöscht und neu installiert ?
          iobroker add bring
          NPM version: 6.9.0
          npm install iobroker.bring@1.3.4 --production --save --prefix "/usr/local/iobroker" (System call)
          host.MacBook-Pro-van-Rafal.local install adapter bring
          npm install --production (System call) in "/usr/local/iobroker/node_modules/iobroker.bring"
          npm notice created a lockfile as package-lock.json. You should commit this file.
          got /usr/local/iobroker/node_modules/iobroker.bring/admin
          upload [2] bring.admin /usr/local/iobroker/node_modules/iobroker.bring/admin/words.js words.js application/javascript
          upload [1] bring.admin /usr/local/iobroker/node_modules/iobroker.bring/admin/index_m.html index_m.html text/html
          upload [0] bring.admin /usr/local/iobroker/node_modules/iobroker.bring/admin/bring.png bring.png image/png
          Adapter "system.adapter.vis.0" restarted.
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring created
          host.MacBook-Pro-van-Rafal.local create instance bring
          host.MacBook-Pro-van-Rafal.local object bring.0.info.user created
          host.MacBook-Pro-van-Rafal.local object bring.0.info.connection created
          host.MacBook-Pro-van-Rafal.local object bring.0.info created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.outputCount created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.inputCount created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.uptime created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.memRss created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.memHeapTotal created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.memHeapUsed created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.cputime created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.cpu created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.connected created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0.alive created
          host.MacBook-Pro-van-Rafal.local object system.adapter.bring.0 created
          MacBook-Pro:iobroker rafal$ npm -v
          6.9.0
          MacBook-Pro:iobroker rafal$ node -v
          v8.15.0
            Fehler tritt bei jeder Adapter Installation auf. Auch 'npm cache verify' bringt diesen Fehler.
            Ich denke die NPM-Installation ist zerschossen, tue mich aber schwer diese neu zu installieren. Ich kann NPM nicht über sich selbst updaten :
            mw@ioBroker-02:~$ sudo npm install -g npm@6
            npm ERR!     /root/.npm/_logs/2019-03-29T11_50_38_715Z-debug.log
            Da NPM eine Komponente von NodeJS ist, ich hoffe da liege ich richtig, könnte ein Update/Reinstall von NodeJS helfen? Ich möchte aber nur ungern eine Neukonfiguration meiner iobroker Installation durchführen müssen, im Moment läuft sie recht stabil und eigentlich ohne Fehler....bis auf diesen hier.
            Danke!
            • AlCalzone
              AlCalzone Developer @mawin last edited by
              Dürfte helfen. Wenn du bei der selben Major-Version bleibst (6/8/10), sollte keine Änderung an ioBroker nötig sein.
                Leider hat der folgende Aufruf keine Besserung gebracht :
                sudo apt-get install --reinstall nodejs
                Also, nur um sicher zu sein und nicht am Wochenende im Keller sitzen zu müssen zwecks kompletter Neuinstallation :-), ich würde jetzt Folgendes ausführen :
                sudo apt-get --purge remove node
                sudo apt-get --purge remove nodejs
                sudo apt-get autoremove
                sudo reboot
                curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                sudo reboot
                Gute Idee?
                • AlCalzone
                  sollten nicht nötig sein - der Rest sieht für mich sinnvoll aus.
                  Mal abgesehen davon: Ich finde bei Google Hinweise, dass das möglicherweise mit dem Versionsmanager n zu tun hat, hast du den zufällig im Einsatz?
                    Einen Versions-Manager, z.B. n, habe ich nicht im Einsatz.
                    Ich führe dann mal die Befehle aus....am Sonntag, da wird das Wetter schlechter.
                    Danke schonmal für die Hilfe!
                      So regnerisches Wetter, wollte nun die Gelegenheit nutzen und node/nodejs neu installieren. Erster Befehl bringt mich aber zum Grübeln :
                      $sudo apt-get --purge remove node
                      Abhängigkeitsbaum wird aufgebaut.
                      Statusinformationen werden eingelesen.... Fertig
                      Paket »node« ist nicht installiert, wird also auch nicht entfernt.
                      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                      $ node -v
                      v8.15.1
                      Ich habe jetzt nicht weiter gemacht, das scheint mir doch sonderbar. Wie kann node nicht installiert sein wenn node -v mir die Version anzeigt?
                        Homoran Global Moderator Administrators @mawin last edited by
                        @mawin
                        Was sagt
                        which node
                          $ which node
                          /usr/local/bin/node
                          Danke!
                            wenns hilft :
                            mw@ioBroker-02:~$ which node
                            /usr/local/bin/node
                            mw@ioBroker-02:~$ which npm
                            /usr/local/bin/npm
                            mw@ioBroker-02:~$ which nodejs
                            /usr/bin/nodejs
                              sudo mv npm npmold
                              81.1k
                              npm na.nexttick adapter
                              634
