    4. Homekit Anfängerfrage
    • V
      venni last edited by
      ich bin durch die Forensuche durch die Installation von homekit gekommen.
      Sollte nach der Installation der Status nicht mit Host verbunden sein?
      LG
      venni
      • V
        Dashier steht noch im Log:
        2016-03-12 19:14:51.664 - debug: homekit.0 objectDB connected
        2016-03-12 19:14:51.739 - error: host.raspberrypi instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
        2016-03-12 19:14:51.741 - info: host.raspberrypi Restart adapter system.adapter.homekit.0 because enabled
        2016-03-12 19:15:21.820 - info: host.raspberrypi instance system.adapter.homekit.0 started with pid 17813
        2016-03-12 19:15:25.396 - error: uncaught exception: Cannot find module './build/Release/bignum'
        2016-03-12 19:15:25.442 - error: Error: Cannot find module './build/Release/bignum'
        at Function.Module._resolveFilename (module.js:336:15)
        at Function.Module._load (module.js:278:25)
        at Module.require (module.js:365:17)
        at new require (module.js:384:17)
        at Object. <anonymous>(/opt/iobroker/node_modules/bignum/index.js:4:14)
        at Module._compile (module.js:460:26)
        at Object.Module._extensions..js (module.js:478:10)
        at Module.load (module.js:355:32)
        at Function.Module._load (module.js:310:12)
        at Module.require (module.js:365:17)</anonymous>
        • V
          bignum konnte ich nachinstallieren.
          Danach kam das hier:
          2016-03-12 19:45:46.194 - info: homekit.0 starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
          2016-03-12 19:45:46.231 - debug: homekit.0 requesting all states
          2016-03-12 19:45:46.259 - debug: homekit.0 requesting all objects
          2016-03-12 19:45:49.311 - debug: homekit.0 received all objects
          2016-03-12 19:45:49.422 - debug: homekit.0 received all states
          2016-03-12 19:45:49.432 - info: homekit.0 hap-nodejs starting…
          2016-03-12 19:45:49.458 - error: uncaught exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
          2016-03-12 19:45:49.467 - error: Error: Cannot find module 'hap-nodejs/node_modules/node-persist'
          at require (module.js:384:17)
          at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:215:19)
          at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
          at /opt/iobroker/node_modules/iobroker.homekit/main.js:168:61
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2473:60
          at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:151:27)
          at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
          Also hap-nodejs auch noch installiert.
          Dann aber das:
          2016-03-12 19:46:17.383 - info: homekit.0 hap-nodejs starting...
          2016-03-12 19:46:17.402 - error: uncaught exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
          2016-03-12 19:46:17.409 - error: Error: Cannot find module 'hap-nodejs/node_modules/node-persist'
          Der Pfad stimmte nicht.
          also "node-persist" zum Test mal von "/opt/iobroker/node_modules/node-persist" nach "/opt/iobroker/node_modules/hap-nodejs/node_modules/node-persist" kopiert.
          Nun wieder was neues (fängt an und bricht dann wieder mit einer Exception ab):
          2016-03-12 20:58:50.764 - debug: homekit.0 objectDB connected
          2016-03-12 20:58:50.817 - debug: homekit.0 statesDB connected
          2016-03-12 20:58:50.972 - info: homekit.0 starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
          2016-03-12 20:58:50.987 - debug: homekit.0 requesting all states
          2016-03-12 20:58:50.993 - debug: homekit.0 requesting all objects
          2016-03-12 20:58:52.244 - info: host.raspberrypi instance system.adapter.web.0 started with pid 29146
          2016-03-12 20:58:53.421 - debug: homekit.0 received all states
          2016-03-12 20:58:54.114 - debug: homekit.0 received all objects
          2016-03-12 20:58:54.125 - info: homekit.0 hap-nodejs starting...
          2016-03-12 20:58:54.294 - debug: homekit.0 < hap Type for Humidity = HM-TC-IT-WM-W-EU
          2016-03-12 20:58:54.316 - debug: homekit.0 > iobroker subscribe Humidity hm-rpc.0.LEQ0441129.1.HUMIDITY
          2016-03-12 20:58:54.321 - error: uncaught exception: Cannot read property 'CurrentRelativeHumidity' of undefined
          2016-03-12 20:58:54.330 - error: TypeError: Cannot read property 'CurrentRelativeHumidity' of undefined
          at Object.createAccessory_Humidity [as Humidity] (/opt/iobroker/node_modules/iobroker.homekit/main.js:511:41)
          at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:280:67)
          at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
          at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
          at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
          at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
          at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          Ich gebs jetzt langsam auf 😢</anonymous></anonymous></anonymous></anonymous></anonymous>
          • V
            versteckt last edited by
            Hallo venni!
            Für mich klingt das stark nach Problemen, die bereits bei der Installation aufgetreten sind.
            Welche node bzw. npm Version bzw. welches Betriebssystem hast du im Einsatz?
            LG Christian
