    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Решение проблем при обновлении драйверов
      RDim last edited by
      Попытка обновить драйвер web Adapter приводила к ошибкам -
      $ ./iobroker upgrade web
      host.cubietruck Adapter "system.adapter.web.0" is stopped.
      npm install iobroker.web --production --prefix "/opt/iobroker" (System call)
      npm
      WARN enoent ENOENT, open '/opt/iobroker/package.json'
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      host.cubietruck Adapter "system.adapter.web.0" is started
      npm install --production --prefix "/opt/iobroker/node_modules/iobroker.web" (System call)
      npm
      ERR!
      Linux 3.4.106-cubietrucknpm
      ERR! argv "node" "/usr/bin/npm" "install" "--production" "--prefix"
      ! "/opt/iobroker/node_modules/iobroker.web"npm ERR! node v0.10.42
      npm ERR! npm v3.8.1
      ! npm ERR! Cannot read property 'target' of nullnpm
      ERR! npm ERR! If you need help, you may report this error at:
      npm ERR!
      <https: github.com/npm/issues="">
      ! npm ERR! Please include the following file with any support request:
      npm ERR! /npm-debug.log
      Cannot install iobroker.web: 1
      ERROR: process exited with code 25</https:>
      В закладке админа показывает, что обновил драйвер до новой версии 1.3.5, но в консоли при запросе````
      iobroker list adapters
      system.adapter.admin : admin - 0.8.6
      system.adapter.megad : megad - 1.1.2
      system.adapter.mqtt : mqtt - 0.4.1
      system.adapter.owfs : owfs - 0.0.2
      system.adapter.ping : ping - 0.1.4
      system.adapter.pushbullet : pushbullet - 0.0.11
      system.adapter.sayit : sayit - 0.3.17
      system.adapter.web : web - 1.3.4
      system.adapter.flot : flot - 0.2.6
      system.adapter.vis : vis - 0.9.2
      system.adapter.javascript : javascript - 2.0.3
      system.adapter.socketio : socketio - 1.2.3
      system.adapter.vis-bars : vis-bars - 0.1.1
      system.adapter.vis-colorpicker : vis-colorpicker - 0.1.3
      system.adapter.vis-google-fonts : vis-google-fonts - 0.1.0
      system.adapter.vis-hqwidgets : vis-hqwidgets - 0.2.5
      system.adapter.vis-jqui-mfd : vis-jqui-mfd - 0.1.0
      system.adapter.vis-keyboard : vis-keyboard - 0.0.2
      system.adapter.vis-lcars : vis-lcars - 0.1.6
      system.adapter.vis-metro : vis-metro - 0.2.1
      system.adapter.vis-rgraph : vis-rgraph - 0.0.2
      system.adapter.vis-timeandweather : vis-timeandweather - 0.1.0
      system.adapter.history : history - 0.2.1
      system.adapter.rickshaw : rickshaw - 0.3.1
      system.adapter.text2command : text2command - 0.1.7
      system.adapter.telegram : telegram - 0.1.0
      system.adapter.sql : sql - 0.1.2
      system.adapter.vis-fancyswitch : vis-fancyswitch - 0.1.0
      system.adapter.vis-justgage : vis-justgage - 0.4.0
      видно что адаптер web имеет старую версию 1.3.4
      Причина, типа устаревшая версия nodejs
      npm WARN deprecated latest stable version. To upgrade to npm@2, run:
      npm WARN deprecated
      npm WARN deprecated   npm -g install npm@latest-2
      npm WARN deprecated
      npm WARN deprecated To upgrade to the latest stable version, run:
      npm WARN deprecated
      npm WARN deprecated
      npm WARN deprecated (Depending on how Node.js was installed on your system, you
      npm WARN deprecated may need to prefix the preceding commands with `sudo`, or if
      npm WARN deprecated on Windows, run them from an Administrator prompt.)
      npm WARN deprecated
      npm WARN deprecated If you're running the version of npm bundled with
      npm WARN deprecated Node.js 0.10 LTS, be aware that the next version of 0.10 LTS
      npm
      Попытка обновить как рекомендуют````
      Решение было найдено здесь - [https://nodejs.org/en/download/package- … tributions](https://nodejs.org/en/download/package-manager/#debian-and-ubuntu-based-linux-distributions)
      Набираем
      curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
      apt-get install -y nodejs
      После сего шаманства, версии стали - npm 2.14.20, node v4.4.0
      Затем````
      reboot
      ````и возможно````
      iobroker restart
      Теперь с консоли можно обновить адаптер web -````
      iobroker upgrade web https://github.com/ioBroker/ioBroker.web.git
      Проверяем````
      ````видим обновленный адаптер web 1.3.5
      Может кому поможет, я долго бился.
      • V
        vtec last edited by
        По хорошему это косяк, в базе не должна была обновиться версия.
        А так спасибо, у себя 0.10 обновился на 4.4. Пойду обновлю инструкцию для Cubieboard.
