    4. Cannot find module 'sax' seit letztem update vom hm-rega
    • G
      gogohome last edited by
      Habe seit dem letzten updated Probleme mit dem hm-rega adapter.
      Ich habe einige updates ausgelassen und gestern das letzte eingespielt.
      Seit dem habe ich folgenden Fehler siehe Spoiler, der Fehler wiederholt sich im log file immer wieder.
      Was kann das sein?
      Oder besser was muß ich machen das es weg ist?
      ! raspberrypi 2016-03-13 20:13:47 info host.raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled
      ! raspberrypi 2016-03-13 20:13:47 error host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 6 (uncaught exception)
      ! hm-rega.0 2016-03-13 20:13:47 error Error: Cannot find module 'sax' at Function.Module._resolveFilename (module.js:336:15) at Function.Module._load (module.js:278:25) at Module.require (module.js:365:17) at require (modu
      ! hm-rega.0 2016-03-13 20:13:47 error uncaught exception: Cannot find module 'sax'
      ! hm-rega.0 2016-03-13 20:13:47 info hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
      ! hm-rega.0 2016-03-13 20:13:47 info hm-rega.0 starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.hm-rega
      ! raspberrypi 2016-03-13 20:13:44 info host.raspberrypi instance system.adapter.hm-rega.0 started with pid 3518
      ! host-raspberrypi 2016-03-13 19:13:13 info Restart adapter system.adapter.hm-rega.0 because enabled
      ! host-raspberrypi 2016-03-13 19:13:13 error instance system.adapter.hm-rega.0 terminated with code 6 (uncaught exception)
      ! Error: 2016-03-13 19:13:13 error at Function.Module._load (module.js:310:12)
      ! Error: 2016-03-13 19:13:13 error at Module.load (module.js:355:32)
      ! Error: 2016-03-13 19:13:13 error at Object.Module._extensions..js (module.js:478:10)
      ! Error: 2016-03-13 19:13:13 error at Module._compile (module.js:460:26)
      ! Error: 2016-03-13 19:13:13 error at Object. (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/xml2js/lib/xml2js.js:538:4)
      ! Error: 2016-03-13 19:13:13 error at Object. (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/xml2js/lib/xml2js.js:9:9)
      ! Error: 2016-03-13 19:13:13 error at require (module.js:384:17)
      ! Error: 2016-03-13 19:13:13 error at Module.require (module.js:365:17)
      ! Error: 2016-03-13 19:13:13 error at Function.Module._load (module.js:278:25)
      ! Error: 2016-03-13 19:13:13 error at Function.Module._resolveFilename (module.js:336:15)
      ! Error: 2016-03-13 19:13:13 error Cannot find module 'sax'
      ! uncaught 2016-03-13 19:13:13 error exception: Cannot find module 'sax'
      ! hm-rega-0 2016-03-13 19:13:13 info subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
      ! hm-rega-0 2016-03-13 19:13:13 info starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.hm-rega
        @gogohome:
        Was kann das sein?
        ! hm-rega-0 2016-03-13 19:13:13 info starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.hm-rega `
        Beim Update ist was schiff gelaufen:
        cd /opt/iobroker
        iobroker hm-rega stop
        npm install iobroker.hm-rega --production
        iobroker hm-rega start
        • G
          Danke Problem gelöst, nach neu Installation von hm-rega ging es wieder.
