    4. Node-Red
    5. was mach ich falsch mit der node-red-contrib-color-convert Node???
      LJ-Mic last edited by
      Ich habe ein Problem mit der node-red-contrib-color-convert Node.
      Egal was ich rein schicke, es kommt nur Mist raus.
      Schicke ich HSV rein und sag er soll RGB als Object ausgeben, gibt er mir HSV Werte raus.
      Ich vermute aber das ich schon bei der Erstellung des Array aus den einzelnen Werte, das die Node haben will, einen Fehler gemacht habe.
      Kann mir wer helfen?
      Hier der Flow:
              "id": "471c23bb.2023c4",
              "type": "tab",
              "label": "RGB - HSV",
              "disabled": false,
              "info": ""
              "id": "e7872244.7a6f",
              "type": "ioBroker in",
              "z": "471c23bb.2023c4",
              "name": "Hue",
              "topic": "mqtt.0.home.01.Wohnzimmer.LED_Test.hue",
              "payloadType": "value",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 90,
              "y": 40,
              "wires": [
                      "1662ba98.dcddfd",
                      "2e667828.e40f1"
              "id": "efc741c1.17ed5",
              "name": "Saturation",
              "topic": "mqtt.0.home.01.Wohnzimmer.LED_Test.s",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 100,
              "y": 180,
              "wires": [
                      "d62c5f.9d7beba",
                      "41dfd43a.7133dc"
              "id": "79fd6e5b.249ab8",
              "type": "debug",
              "name": "RGB ?",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "x": 990,
              "y": 240,
              "wires": []
              "id": "31aa487b.f6ef28",
              "type": "debug",
              "name": "2.0",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "x": 530,
              "y": 40,
              "wires": []
              "id": "a9f6dc6c.5bdde",
              "type": "debug",
              "name": "3",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "x": 770,
              "y": 140,
              "wires": []
              "id": "1662ba98.dcddfd",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "index",
                      "pt": "msg",
                      "to": "0",
                      "tot": "num"
                      "t": "delete",
                      "p": "topic",
                      "pt": "msg"
                      "t": "delete",
                      "p": "from",
                      "pt": "msg"
                      "t": "delete",
                      "p": "acknowledged",
                      "pt": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 340,
              "y": 80,
              "wires": [
                      "31aa487b.f6ef28",
                      "ae2008c3.aef1a"
              "id": "ae2008c3.aef1a",
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "array",
              "property": "payload",
              "propertyType": "msg",
              "key": "num",
              "joiner": "\\n",
              "joinerType": "str",
              "accumulate": false,
              "timeout": "10",
              "count": "3",
              "reduceRight": false,
              "reduceExp": "",
              "reduceInit": "",
              "reduceInitType": "",
              "reduceFixup": "",
              "x": 750,
              "y": 220,
              "wires": [
                      "a06c525e.c9851",
                      "a9f6dc6c.5bdde"
              "id": "d62c5f.9d7beba",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "index",
                      "pt": "msg",
                      "to": "1",
                      "tot": "num"
                      "t": "delete",
                      "p": "topic",
                      "pt": "msg"
                      "t": "delete",
                      "p": "from",
                      "pt": "msg"
                      "t": "delete",
                      "pt": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 320,
              "y": 220,
              "wires": [
                      "ae2008c3.aef1a",
                      "ab43314c.e755d8"
              "id": "a06c525e.c9851",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "key",
                      "pt": "msg",
                      "to": "hsv",
                      "tot": "str"
                      "t": "delete",
                      "p": "topic",
                      "pt": "msg"
                      "t": "delete",
                      "p": "from",
                      "pt": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 720,
              "y": 420,
              "wires": [
                      "60512d19.d42fb4",
                      "7c6f19f1.9f6428"
              "id": "a5da25c5.2cdff8",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "index",
                      "pt": "msg",
                      "to": "2",
                      "tot": "num"
                      "t": "delete",
                      "p": "topic",
                      "pt": "msg"
                      "t": "delete",
                      "p": "from",
                      "pt": "msg"
                      "t": "delete",
                      "pt": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 320,
              "y": 340,
              "wires": [
                      "ae2008c3.aef1a",
                      "f71e6c2b.a8ea4"
              "id": "41dfd43a.7133dc",
              "type": "debug",
              "name": "1.1",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "x": 290,
              "y": 180,
              "wires": []
              "id": "f6e3ffcf.153d68",
              "type": "debug",
              "name": "1.2",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "x": 290,
              "y": 300,
              "wires": []
              "id": "f71e6c2b.a8ea4",
              "type": "debug",
              "name": "2.2",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "x": 530,
              "y": 300,
              "wires": []
              "id": "ab43314c.e755d8",
              "type": "debug",
              "name": "2.1",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "x": 530,
              "y": 180,
              "wires": []
              "id": "60512d19.d42fb4",
              "type": "debug",
              "name": "hsv",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "x": 970,
              "y": 420,
              "wires": []
              "id": "c5ea660e.2ca3e8",
              "name": "Prozent",
              "topic": "mqtt.0.home.01.Wohnzimmer.LED_Test.pro",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 90,
              "y": 300,
              "wires": [
                      "a5da25c5.2cdff8",
                      "f6e3ffcf.153d68"
              "id": "de4ce2c.634372",
              "type": "inject",
              "name": "Test 1",
              "topic": "",
              "payload": "",
              "payloadType": "date",
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "x": 110,
              "y": 460,
              "wires": [
                      "9878bb00.32ff88",
                      "2d35f4e9.74df94",
                      "8d6bae13.7fb988"
              "id": "9878bb00.32ff88",
              "type": "change",
              "name": "Test Hue 360",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "360",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 190,
              "y": 560,
              "wires": [
                      "1662ba98.dcddfd"
              "id": "2d35f4e9.74df94",
              "type": "change",
              "name": "Test Saturation 100",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "100",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 210,
              "y": 600,
              "wires": [
                      "d62c5f.9d7beba"
              "id": "8d6bae13.7fb988",
              "type": "change",
              "name": "Test Brightness 100",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "100",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 210,
              "y": 640,
              "wires": [
                      "a5da25c5.2cdff8"
              "id": "2e667828.e40f1",
              "type": "debug",
              "name": "1.0",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "x": 310,
              "y": 40,
              "wires": []
              "id": "7c6f19f1.9f6428",
              "type": "color-convert",
              "input": "hsv",
              "output": "rgb",
              "outputType": "object",
              "scaleInput": false,
              "x": 960,
              "y": 340,
              "wires": [
                      "79fd6e5b.249ab8"
              "id": "64817cc5.242d84",
              "type": "inject",
              "name": "Test 2",
              "topic": "",
              "payload": "",
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "x": 470,
              "y": 460,
              "wires": [
                      "2ca2aa7f.098f1e",
                      "9e0e1e91.cab01",
                      "32c490c7.198c2"
              "id": "2ca2aa7f.098f1e",
              "type": "change",
              "name": "Test Hue 122",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "122",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 550,
              "y": 560,
              "wires": [
                      "1662ba98.dcddfd"
              "id": "9e0e1e91.cab01",
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "100",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 570,
              "y": 600,
              "wires": [
                      "d62c5f.9d7beba"
              "id": "32c490c7.198c2",
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "100",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 570,
              "y": 640,
              "wires": [
                      "a5da25c5.2cdff8"
        rewenode @LJ-Mic last edited by
        @LJ-Mic Schau mal, ob dieser Thread hilfreich ist:
        Node-Red mit Alexa - Dimmer
          LJ-Mic @rewenode last edited by
          @rewenode
          Kann das von dir zwar kopieren, aber Blockly fängt damit nichts an.
            @LJ-Mic sagte in was mach ich falsch mit der node-red-contrib-color-convert Node???:
            Blockly? Was genau machst du? Was kopierst du?
            Ich hab jedenfalls nichts mit Blockly gemacht 😉 da kenn ich mich nicht mit aus.
