    4. Update JS-Adapter 4.0.12 auf 4.1.12
    UNSOLVED Update JS-Adapter 4.0.12 auf 4.1.12
    • Negalein
      Negalein Global Moderator last edited by Jey Cee
      Nachdem ich durch was auch immer (vermute Blockly mit einem falschen Baustein) einen Fehler im JS-Adapter bekommen habe, wollte ich wiedermal den Adapter von 4.0.12 auf 4.1.12 updaten.
      Node.js ist auf 8.15.1 und NPM auf 6.4.1
      Beim Update kommt folgende Fehlermeldung:
      $ ./iobroker upgrade javascript
      Update javascript from @4.0.12 to @4.1.12
      NPM version: 6.4.1
      npm install iobroker.javascript@4.1.12 --production --save --prefix "/opt/iobroker" (System call)
      module.js:550    throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js'
          at Function.Module._resolveFilename (module.js:548:15)
          at Function.Module._load (module.js:475:25)
          at Function.Module.runMain (module.js:694:10)
          at startup (bootstrap_node.js:204:16)
          at bootstrap_node.js:625:3
      npm
       WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN
       optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm ERR! code ELIFECYCLEnpm ERR! errno 1
      npm ERR! iobroker.javascript@4.1.12 postinstall: `node ./install/installTypings.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.javascript@4.1.12 postinstall script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2019-04-03T12_43_46_728Z-debug.log
      ERROR: Cannot find io-package.json in null
      ERROR: process exited with code 10
      Dann startet sich der JS-Adapter immer wieder neu.
      host.ioBroker	2019-04-03 14:45:51.393	info	iobroker exit 0
      host.ioBroker	2019-04-03 14:45:51.385	error	iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
      host.ioBroker	2019-04-03 14:45:51.365	error	iobroker host.ioBroker Adapter directory "null" does not exists
      host.ioBroker	2019-04-03 14:45:51.322	info	iobroker /root/.npm/_logs/2019-04-03T12_45_45_625Z-debug.log
      host.ioBroker	2019-04-03 14:45:51.322	info	iobroker ERR!
      host.ioBroker	2019-04-03 14:45:51.321	info	iobroker npm ERR! A complete log of this run can be found in:npm
      host.ioBroker	2019-04-03 14:45:51.319	info	iobroker
      host.ioBroker	2019-04-03 14:45:45.614	info	iobroker ERR! npm ERR! Failed at the iobroker.javascript@4.1.12 postinstall script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      host.ioBroker	2019-04-03 14:45:45.614	info	iobroker ERR! iobroker.javascript@4.1.12 postinstall: `node ./install/installTypings.js`npm ERR! Exit status 1 npm
      host.ioBroker	2019-04-03 14:45:45.610	info	iobroker
      host.ioBroker	2019-04-03 14:45:45.610	info	iobroker npm
      host.ioBroker	2019-04-03 14:45:45.610	info	iobroker 1
      host.ioBroker	2019-04-03 14:45:45.608	info	iobroker npm ERR! code ELIFECYCLEnpm ERR! errno
      host.ioBroker	2019-04-03 14:45:45.602	info	iobroker SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      host.ioBroker	2019-04-03 14:45:45.601	info	iobroker notsup
      host.ioBroker	2019-04-03 14:45:45.601	info	iobroker WARN
      host.ioBroker	2019-04-03 14:45:45.601	info	iobroker npm
      host.ioBroker	2019-04-03 14:45:45.601	info	iobroker optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      host.ioBroker	2019-04-03 14:45:45.601	info	iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN
      host.ioBroker	2019-04-03 14:45:45.600	info	iobroker WARN
      host.ioBroker	2019-04-03 14:45:45.595	info	iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm
      host.ioBroker	2019-04-03 14:45:45.595	info	iobroker npm
      host.ioBroker	2019-04-03 14:45:39.167	info	iobroker module.js:550 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js' at Function.Module._resolveFilename (module.js:548:
      host.ioBroker	2019-04-03 14:44:45.198	info	iobroker npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
      host.ioBroker	2019-04-03 14:44:44.805	info	iobroker NPM version: 6.4.1
      iobroker	2019-04-03 14:44:43.308	info	install javascript
      host.ioBroker	2019-04-03 14:44:43.307	warn	startInstance cannot find adapter "javascript". Try to install it... 2 attempt
      Dann dachte ich, ok, starte ich mal ioBroker neu.
      Brachte auch nichts, ausser dass der JS-Adapter nun garnicht mehr da war.
      Konnte auch nicht installiert werden.
      Ok, dann hab ich das Backup von heute Nacht eingespielt und ich bin wieder auf 4.0.12
      Aber, warum kann ich nicht auf 4.1.12 updaten?
      Liest von euch wer was raus?
        w00dy @Negalein last edited by w00dy
        @Negalein
        Hi, hast du mal versucht den Adapter über die Konsole zu installieren:
        cd /opt/iobroker
        iobroker update javascript
        Ich hatte auch mal das Problem mit einer jüngeren Version und so ging es dann bei mir.
        Negalein 2 Replies Last reply Reply Quote 0
        • Negalein
          Negalein Global Moderator @w00dy last edited by
          @Hicks sagte in Update JS-Adapter 4.0.12 auf 4.1.12:
          Danke, werd ich morgen versuchen.
          Muss blad weg und da hätte ich keine Zeit für noch einen Restore.
          • Negalein
            Sorry für die Verspätung!
            Dies hat leider auch nicht funktioniert.
            • MyzerAT
              MyzerAT last edited by
              mach mal "upload" beim JS Adapter
              • Negalein
                Negalein Global Moderator @MyzerAT last edited by
                @MyzerAT sagte in Update JS-Adapter 4.0.12 auf 4.1.12:
                ist ohne Fehler durchgelaufen.
                $ ./iobroker upload javascript
                got /opt/iobroker/node_modules/iobroker.javascript/admin
                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/redshift/redshift.js vs/basic-languages/redshift/redshift.js application/javascript
                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/objective-c/objective-c.js vs/basic-languages/objective-c/objective-c.js application/javascript
                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/go/go.js vs/basic-languages/go/go.js application/javascript
                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/main.071206b3.chunk.css static/css/main.071206b3.chunk.css text/css
                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_timeout.js google-blockly/own/blocks_timeout.js application/javascript
                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                process exited with code 0
                Meinst, ich kann jetzt ein Update auf 4.1.12 wagen?
                • MyzerAT
                  leider kenn ich mich da zu wenig aus, was ich rauslese, das er als error angibt die datei "io-package.json" nicht zu finden, mach mal eine suche nach dieser datei, bei mir liegt die unter
                  \\DS216II\docker\iobroker_mount\node_modules\iobroker.milight-smart-light\io-package.json
                  paul53 Negalein 2 Replies Last reply Reply Quote 0
                    paul53 @MyzerAT last edited by
                    @MyzerAT sagte:
                    Das ist eine andere io-package.json. Jeder Adapter hat eine Datei io-package.json. Die für den JS-Adapter ist /opt/iobroker/node_modules/iobroker.javascript/io-package.json.
                    • Negalein
                      die io-package.json liegt bei mir in jedem Adapterverzeichnis.
                      Unter anderem auch in /docker/iobroker_mount/node_modules/iobroker.javascript
                        @Negalein
                        Ich würde den JS-Adapter über den Expertenmodus komplett löschen, dann neu installieren und danach uploaden.
                        Ist evtl. einen Versuch wert.
                        • Negalein
                          Danke, werde ich auch versuchen.
                          • Negalein
                            Da mich bis jetzt nichts weitergebracht hat, möchte ich fragen, ob noch jemand einen Tipp hat.
                            error javascript adapter update
                            1191
