    4. Helios KWL mit Easy Controls über HTTP auslesen
      mabas last edited by Jey Cee
      hat doch noch geklappt. Ich bekomme alle Infos aus der Anlage heraus. Alles ziemlich quick´n dirty. Verbesserungs- und Optimierungsvorschläge jederzeit und gerne.
      Es müssen die NPM Module needle und xml2js bei dem Javascript-Adapter hinzugefügt werden.
      createState('KWL.stufe', 0, {type : "number"});
      createState('KWL.stufeProzent', 0, {type : "number"});
      createState('KWL.bypass', false, {type : "boolean"});
      createState('KWL.off', false, {type : "boolean"});
      createState('KWL.bad.temperature', 0, {type : "number"});
      createState('KWL.bad.humitity', 0, {type : "number"});
      createState('KWL.arbeitszimmer.temperature', 0, {type : "number"});
      createState('KWL.arbeitszimmer.humitity', 0, {type : "number"});
      createState('KWL.studio.airQuality', 0, {type : "number"});
      createState('KWL.temperatur.außenluft', 0, {type : "number"});
      createState('KWL.temperatur.zuluft', 0, {type : "number"});
      createState('KWL.temperatur.fortluft', 0, {type : "number"});
      createState('KWL.temperatur.abluft', 0, {type : "number"});
      var needle = require('needle');
      function loginByNeedle() {
      var options = {
      headers: {
      "Host" : "[http://HeliosKWL](http://HeliosKWL)",
      "User-Agent": "Mozilla/5.0 (Windows NT 6.2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/44.0.2403.89 Safari/537.36",
      "Accept": "text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8",
      "Accept-Language": "de,en-US;q=0.7,en;q=0.3",
      "Accept-Encoding": "gzip, deflate",
       "Referer": "[http://HeliosKWL/](http://HeliosKWL/)",
       "Content-Length": "15",
       "Connection": "keep-alive"}
      needle.post('[http://HeliosKWL/info.htm](http://HeliosKWL/info.htm)', "v00402=****KENNWORT****", options, function(err, response) {
      if (err) {
      log('Shoot! Something is wrong: ' + err.message);
      } else {
      readWithNeedle();
      function readWithNeedle() {
      var options = {
      headers: {
      "Host": "HeliosKWL",
      "User-Agent": "Mozilla/5.0 (Windows NT 6.1; WOW64; rv:44.0) Gecko/20100101 Firefox/44.0",
      "Referer": "[http://HeliosKWL/anzeig.htm](http://HeliosKWL/anzeig.htm)",
      "Content-Length": "20",
      "Content-Type": "text/plain;charset=UTF-8",
      needle.post('[http://HeliosKWL/data/werte8.xml](http://HeliosKWL/data/werte8.xml)', "xml=/data/werte8.xml", options, function(err, response, body) {
      if (err) {
      } else {
      var idsAsString;
      var valuesAsString;
      idsAsString = JSON.stringify(body.PARAMETER.ID);
      valuesAsString = JSON.stringify(body.PARAMETER.VA);
      var keys = idsAsString.split(/,/);
      var values = valuesAsString.split(/,/);
      var temp = String(values[keys.indexOf("\"v00104\"")]);
      setState("javascript.1.KWL.temperatur.außenluft"/*KWL.außentemperatur*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00105\"")]);
      setState("javascript.1.KWL.temperatur.zuluft"/*KWL.temperatur.zuluft*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00106\"")]);
      setState("javascript.1.KWL.temperatur.fortluft"/*KWL.temperatur.fortluft*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00107\"")]);
      setState("javascript.1.KWL.temperatur.abluft"/*KWL.temperatur.abluft*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00111\"")]);
      setState("javascript.1.KWL.bad.humitity"/*KWL.bad.humitity*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00112\"")]);
      setState("javascript.1.KWL.arbeitszimmer.humitity"/*KWL.arbeitszimmer.humitity*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00119\"")]);
      setState("javascript.1.KWL.bad.temperature"/*KWL.bad.temperature*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00120\"")]);
      setState("javascript.1.KWL.arbeitszimmer.temperature"/*KWL.arbeitszimmer.temperature*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00136\"")]);
      setState("javascript.1.KWL.studio.airQuality"/*KWL.studio.airQuality*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00102\"")]);
      setState("javascript.1.KWL.stufe"/*KWL.stufe*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[keys.indexOf("\"v00103\"")]);
      setState("javascript.1.KWL.stufeProzent"/*KWL.stufeProzent*/, parseFloat(temp.slice(1, temp.length -1)));
      temp = String(values[95]); //die undokumentierte ID v02119
       if (temp === 0) {
       setState("javascript.1.KWL.bypass"/*KWL.bypass*/, false);
       } else {
       setState("javascript.1.KWL.bypass"/*KWL.bypass*/, true);
      loginByNeedle(); // bei Scriptstart
      schedule("* * * * *", loginByNeedle);
      ToDo:
      • es erfolgt unnötigerweise aktuell jede Minute ein Login; das kann optimiert werden
      • SET-Funktionen gewünscht: Anlage ausschalten, Bypass-Automatik übersteuern und Bypass via Iobroker öffnen/schließen
      • Timmerx
        Timmerx last edited by
        Hallo mbas,
        das sieht ja schon mal super aus.
        Hast du das Skript schon weiterentwickelt? Bzg. Login und der Bypassfunktion?
        MfG TimmerX
        • V
          Viper3500 @Timmerx last edited by
          wo muß ich das Script einsetzen um die Werte bzw. die Variablen in Blocky weiter zu verarbeiten?
          javascript
