    4. soll ich an developer schicken...
    SOLVED soll ich an developer schicken...
    • a200
      a200 last edited by
      Moin,
      habe heute folgende Meldung erhalten. Kann jemand was damit anfangen?
      2019-04-10 21:16:26.565  - warn: hm-rpc.2 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SRH.MAINTENANCE.2"
      2019-04-10 21:16:26.565  - warn: hm-rpc.2 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"SABOTAGE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":
      "SABOTAGE","TYPE":"BOOL","DEFAULT":false},"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"D
      UTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"LOW_BAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"LOW_BAT","TYPE":"BOOL","DEFAULT":false},"INSTALL_TEST":{"MIN":false,"OPERATIONS":3,"MAX":true,"FLAGS":2,"ID":"INSTALL_TEST"
      ,"TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"OPERATING_VOLTAGE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"O
      PERATING_VOLTAGE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"OPERATING_VOLTA
      GE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"ERROR_CODE":{"MIN":0,
      "OPERATIONS":5,"MAX":255,"FLAGS":9,"ID":"ERROR_CODE","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false}}}
      2019-04-10 21:16:26.655  - warn: hm-rpc.2 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SRH.ROTARY_HANDLE_TRANSCEIVER.2"
      2019-04-10 21:16:26.655  - warn: hm-rpc.2 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"MIN":"CLOSED","OPERATIONS":5,"MAX":"OPEN","FLAGS":1,"ID
      ":"STATE","TYPE":"ENUM","DEFAULT":"CLOSED","VALUE_LIST":["CLOSED","TILTED","OPEN"],"CONTROL":"RHS.STATE"}}}
      • sigi234
        sigi234 Forum Testing Most Active last edited by sigi234
        @a200 sagte in soll ich an developer schicken...:
        hm-rpc.2
        Link Text
        Neu issue machen.......
        a200 1 Reply Last reply Reply Quote 0
        • sigi234
          hm-rpc.2
          Link Text
          • a200
            a200 @sigi234 last edited by
            @sigi234 danke, fertig.
            hm-rpc homematic info to developer
