    2. English
    3. ioBroker general
    4. Node.js update
    Node.js update
      ap2017 last edited by
      What is proper procedure to update Node.JS on Raspberry? I am running 6.14.3 and was advised to try 8 or 10 to troubleshoot Blockly astro command execution.
      • BBTown
        BBTown last edited by BBTown
        try this:
        1.) deinstall existing node & node.js versions
        sudo apt-get --purge remove node
        sudo apt-get --purge remove nodejs
        sudo apt-get autoremove
        sudo reboot
        2.) node.js new installation for für Linux und Raspberry 2/3
        curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
        sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
        sudo reboot
        german documentation for this, you`ll find here
          @BBTown I followed your instructions to update node, now have 8.15.1, restarted ioBroker, after update Z-Wave and mySensors adapter don't work. One of the error messages in log is that Z-Wave was compiled against different node. What do I need to do to make system operational?
          Log.txt
          • eric2905
            eric2905 last edited by
            You should start
            npm rebuild
            in /opt/iobroker (or the correct installation folder).
            See these part of the (German) installation instructions: Link
            Greetings,
            Eric
              I've noticed that all download images at http://www.iobroker.net/docu/?page_id=5139&lang=en are based on Node version 6 or lower. At what point it is recommended to update to newer version of Node?
                ap2017 @ap2017 last edited by
                @ap2017 Got it. English site is just outdated. German site has latest images with Node 8 http://www.iobroker.net/docu/?page_id=2563&lang=de
                node.js update
