    4. RPI Adapter Fehlermeldung im Log
      webseb79 last edited by
      bei mir kommt sporadisch immer ein Fehler im Log verursacht vom RPI Adapter.
      Unter Einstellungen frage ich nur die Temperatur ab.
      rpi-0	2016-03-23 10:07:14	warn	Reconnection to DB.
      host-raspberrypi	2016-03-23 10:07:14	info	instance system.adapter.ical.0 terminated with code 0 (OK)
      rpi-0	2016-03-23 10:07:13	error	at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
      rpi-0	2016-03-23 10:07:13	error	at wrapper [as _onTimeout] (timers.js:252:14)
      rpi-0	2016-03-23 10:07:13	error	at parser (/opt/iobroker/node_modules/iobroker.rpi/main.js:112:34)
      rpi-0	2016-03-23 10:07:13	error	at module.exports (/opt/iobroker/node_modules/iobroker.rpi/node_modules/sync-exec/js/sync-exec.js:45:12)
      rpi-0	2016-03-23 10:07:13	error	at module.exports (/opt/iobroker/node_modules/iobroker.rpi/node_modules/sync-exec/js/lib/read-pipes.js:18:7)
      rpi-0	2016-03-23 10:07:13	error	at module.exports (/opt/iobroker/node_modules/iobroker.rpi/node_modules/sync-exec/js/lib/timeout.js:5:13)
      rpi-0	2016-03-23 10:07:13	error	Error: Process execution timeout or exit flag read failure
      Wäre nett wenn mir das jemand erklären könnte .
      Danke Sebastian
