    4. ioBroker Objekte aus javascript object erzeugen
    • dewenni
      dewenni last edited by
      ich experimentiere gerade mir meinem WLAN Grillthermometer.
      Dieses sendet per MQTT einen Status im JSON Format.
      Hier ein Beispiel:
      {"system":{"time":"1555763739","unit":"C","soc":87,"charge":false,"rssi":-76,"online":2},"channel":[{"number":1,"name":"Smoker","typ":0,"temp":33.70,"min":95.00,"max":150.00,"alarm":0,"color":"#FFC100"},{"number":2,"name":"Fleisch Un","typ":0,"temp":999.00,"min":10.00,"max":94.00,"alarm":1,"color":"#22B14C"},{"number":3,"name":"Fleisch Ob","typ":10,"temp":999.00,"min":10.00,"max":94.00,"alarm":1,"color":"#EF562D"},{"number":4,"name":"Kanal 4","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#FFC100"},{"number":5,"name":"Kanal 5","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#A349A4"},{"number":6,"name":"Kanal 6","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#804000"},{"number":7,"name":"Kanal 7","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#5587A2"},{"number":8,"name":"Kanal 8","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#5C7148"}],"pitmaster":{"type":["off","manual","auto"],"pm":[{"id":0,"channel":1,"pid":2,"value":100,"set":110.00,"typ":"auto","set_color":"#ff0000","value_color":"#000000"}]}}
      Ich würde nun gerne daraus ein entsprechendes Objekt im ioBroker erzeugen.
      Dazu habe ich nun mittels javascript angefangen aus dem JSON ein Objekt zu erzeugen.
      Das klappt prima mittels JSON.parse recht elegant.
      // path to json data
      varJSON = 'mqtt.0.WLanThermo.Nanotherm.status.data';
      // get json data
      var rawJSON = getState(varJSON).val;
      // JSON to object
      obj = JSON.parse(rawJSON);
      // Test output
      console.log(obj.system.time);
      console.log(obj.system.unit);
      console.log(obj.system.soc);
      console.log(obj.system.charge);
      console.log(obj.system.rssi);
      console.log(obj.system.online);
      Wie erstelle ich denn jetzt am einfachsten aus dem bestehenden javascript Objekt ein Objekt im ioBroker?
      Muss ich das für jedes Element einzeln machen, oder gibt es sogar eine Möglichkeit das mit einem Befehl zu machen?
      Zu Fuß habe ich nun so angefangen:
              id = 'javascript.0.nanotherm.system.time'
              createState(id, false,{
                  type: 'number',
              id = 'javascript.0.nanotherm.nystem.unit'
                  type: 'string',
      Das wäre ok, da ich aber noch recht neu bin in ioBroker und javascript wollte ich lieber mal fragen ob das so der richtige Weg ist.
        paul53 @dewenni last edited by paul53
        @dewenni sagte:
        Nicht ganz. system.unit ist sicherlich konstant und gehört wohl zum Wert system.soc. Die Zeit in s seit 1.1.1970 darzustellen, ist sicherlich nicht so elegant.
        const path = 'nanotherm.system.';
        createState(path + 'soc', obj.system.soc, {
           type: 'number',
           unit: obj.system.unit,
        createState(path + 'time', formatDate(parseInt(obj.system.time), 'hh:mm:ss'), {
           type: 'string',
        EDIT: obj.system.time von String nach Zahl gewandelt
        • dewenni
          Danke für die Antwort. Mir ging es auch erstmal generell um die Frage ob man jedes Element einzeln erzeigen muss. Dies scheint ja so zu sein.
          Aber wo wir schon bei den Details sind. Das mit der Zeit klappt nicht. Ich hatte das auch schon probiert.
          Der Wert von time ist z.B. "time":"1555766679"
          mit formatDate(obj.system.time, 'hh:mm:ss') ergibt das aber NaN:NaN:NaN
          An anderer stelle habe ich auch schon mit formatDate() gearbeitet, aber hier passt irgendwas nicht.
            @dewenni sagte:
            Versuche es mal mit Wandlung in eine Zahl:
            • dewenni
              das passt!
              Danke!
              79.9k
              javascript
