    4. [gelöst] DWD Adapter - Error exception: Cannot read property 'match' of undefined
      pusemuckel last edited by
      seit dem Umzug von Raspian und meiner alten installtion auf Debian Jessie habe ich ein Problem mit dem DWD Adapter. Er bricht mit code 6 ab.
      ich habe den Adapter schon neu installiert, das bringt aber auch nicht. Da er vorher ohne PRoblem gelaufen ist, vermute ich es fehlt noch was auf dem neuen System. Aber was ? Jemand eine Idee?
      Danke Euch
      js-controller: 0.8.7
      node.js: v4.4.1
      npm: 2.14.20
      linux: Debian (jessie)
      DWD: 2.0.2
      host-nuc	2016-03-24 20:00:02	error	instance system.adapter.dwd.0 terminated with code 6 (uncaught exception)
      TypeError:	2016-03-24 20:00:02	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError:	2016-03-24 20:00:02	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2016-03-24 20:00:02	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
      TypeError:	2016-03-24 20:00:02	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
      TypeError:	2016-03-24 20:00:02	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:638:35)
      TypeError:	2016-03-24 20:00:02	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:704:21
      TypeError:	2016-03-24 20:00:02	error	at /opt/iobroker/node_modules/iobroker.dwd/dwd.js:69:13
      TypeError:	2016-03-24 20:00:02	error	at checkNames (/opt/iobroker/node_modules/iobroker.dwd/dwd.js:154:11)
      TypeError:	2016-03-24 20:00:02	error	at ready (/opt/iobroker/node_modules/iobroker.dwd/dwd.js:158:11)
      TypeError:	2016-03-24 20:00:02	error	at Object.getFile (/opt/iobroker/node_modules/iobroker.dwd/lib/tools.js:34:13)
      TypeError:	2016-03-24 20:00:02	error	Cannot read property 'match' of undefined
      uncaught	2016-03-24 20:00:02	error	exception: Cannot read property 'match' of undefined
        @pusemuckel:
        Danke Euch
        node.js: v4.4.1
        npm: 2.14.20
        DWD: 2.0.2
        Habe neue Version gemacht.
          Danke Bluefox!
          Die neue Version hat das Problem gelöst!
          Schöne Ostern!
          81.0k
