    4. Update VIS 1.1.10 auf 1.2.0 Error 10
    UNSOLVED Update VIS 1.1.10 auf 1.2.0 Error 10
    • Negalein
      Negalein Global Moderator last edited by Jey Cee
      Nachdem ich heute mein VIS von 1.1.10 auf 1.2.0 updaten wollte, wurde das Update mit Code 10 beendet.
      An was könnte das liegen und was könnte ich machen, damit es durchläuft?
      VIS und VIS-Edit funktionieren weiterhin.
      $ ./iobroker upgrade vis
      Update vis from @1.1.10 to @1.2.0
      NPM version: 6.4.1
      npm install iobroker.vis@1.2.0 --production --save --prefix "/opt/iobroker" (System call)
      module.js:550    throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.vis/main.js'
          at Function.Module._resolveFilename (module.js:548:15)
          at Function.Module._load (module.js:475:25)
          at Function.Module.runMain (module.js:694:10)
          at startup (bootstrap_node.js:204:16)
          at bootstrap_node.js:625:3
      npm
       WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.npm
       WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm ERR! code ELIFECYCLEnpm ERR! errno 1
      npm ERR! iobroker.vis@1.2.0 install: `node main.js --install`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.vis@1.2.0 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-05-08T20_35_35_493Z-debug.log
      ERROR: Cannot find io-package.json in null
      ERROR: process exited with code 10
      Node.js: 8.15.1
      NPM: 6.4.1
      JS-Controller: 1.4.2
      installiert auf Synology im Docker
      • sigi234
        Mach mal einen Neustart............
        Negalein 2 Replies Last reply Reply Quote 0
        • Negalein
          Negalein Global Moderator @sigi234 last edited by
          @sigi234 sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
          Da trau ich mich wetten, dass VIS dann nicht mehr geht.
          Melde mich gleich zurück.
          • Negalein
            So, nach einem Neustart läuft VIS und VIS-Edit noch.
            Im VIS-Edit wird 1.1.10 angezeigt.
            Im Admin wird es jetzt komisch.
            Als verfügbar wird mir 1.2.0 angezeigt.
            Aber das Feld für installiert ist leer!
            Dann hätte ich über das + eine Instanz hinzugefügt.
            host.ioBroker error: this adapter does not allow multiple instances
            $ ./iobroker add vis  --host ioBroker
            NPM version: 6.4.1
            npm install iobroker.vis --production --save --prefix "/opt/iobroker" (System call)
            npm
            npm
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
            npm ERR! iobroker.vis@1.2.0 install: `node main.js --install`npm ERR! Exit status 1
            npm ERR!
            npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-05-08T21_06_05_301Z-debug.log
            ERROR: host.ioBroker error: this adapter does not allow multiple instances
            ERROR: process exited with code 19
            • sigi234
              sigi234 Forum Testing Most Active @Negalein last edited by
              @Negalein sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
              Das war Falsch, Vis geht nur eine Instanz!
              • Negalein
                das Verzeichnis iobroker.vis gibt es auch nicht.
                • Negalein
                  Negalein Global Moderator @sigi234 last edited by Negalein
                  Ja, aber es wird mir zwar unter Instanzen angezeigt, aber eben nicht unter Adapter.
                  Hätte jetzt versucht wieder 1.1.10 zu installieren.
                  Bricht mit Error 10 ab.
                  Und in der 1. Zeile sieht man, dass er von 0.0.0 auf 1.1.10 updaten möchte.
                  $ ./iobroker upgrade vis@1.1.10
                  Update vis from @0.0.0 to @1.1.10
                  NPM version: 6.4.1
                  npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker" (System call)
                  npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm
                   ERR! iobroker.vis@1.1.10 install: `node main.js --install`npm ERR! Exit status 1
                  npm ERR! npm ERR! Failed at the iobroker.vis@1.1.10 install script.
                  npm ERR!
                  npm ERR!     /root/.npm/_logs/2019-05-08T21_19_47_886Z-debug.log
                  sigi234 2 Replies Last reply Reply Quote 0
                  • sigi234
                    Hm...da muss ein Profi ran, ich bin mir nicht sicher ob Vis nicht einen höheren JS-Controller (du hast 1.4.2) braucht.
                    • sigi234
                      @Negalein
                      Kommst du noch in Vis rein?
                      • Negalein
                        @Negalein
                        Ja, geht einwandfrei.
                        Ist auch unter Instanzen immer grün
                        • sigi234
                          @Negalein
                          Mal Daten sichern..........
                          Ich hatte das auch, ging aber nach Neustart, Browser Cache geleert? Strg+F5?
                          • Negalein
                            @Negalein
                            Cache werde ich versuchen.
                            Backup wird sowieso täglich 4fach erstellt.
                            • Stabilostick
                              Stabilostick last edited by Stabilostick
                              Geh mal in den ioBroker-Ordner und führe
                              npm i stream-browserify
                              aus.
                              Dann nochmal das vis Update.
                              Wobei, da erklärt nicht die fehlende main.js .... hmm.
                              Was steht in /root/.npm/_logs/2019-05-08T21_19_47_886Z-debug.log?
                              sigi234 Negalein 2 Replies Last reply Reply Quote 0
                              • sigi234
                                sigi234 Forum Testing Most Active @Stabilostick last edited by
                                @Stabilostick sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
                                Hallo, das kenne ich noch nicht, kannst du mir erklären was das bewirkt? Um zu lernen...........
                                Stabilostick 1 Reply Last reply Reply Quote 0
                                • Stabilostick
                                  Stabilostick @sigi234 last edited by
                                  @sigi234
                                  Das ist für die erste Warnung aus dem Log.
                                  • apollon77
                                    apollon77 last edited by
                                    ich frage mal frech: Genug Plattenplatz ist frei und so?
                                    Also vis läuft aber es gibt kein /opt/iobroker/node_modules/iobroker-vis Verzeichnis ... ok das kann sein weil am Ende vis geuploaded wird und das das wichtige ist.
                                    Der Fehler sagt das er das installations-Kommando nicht ausführen konnte nach der npm Installation.
                                    Führe doch mal
                                    manuell an der Kommandozeile aus
                                    • Negalein
                                      Negalein Global Moderator @Stabilostick last edited by
                                      Du meinst in /opt/iobroker/ ?
                                      Ja, denn es existiert schon kein Verzeichnis iobroker.vis
                                      • Negalein
                                        Negalein Global Moderator @apollon77 last edited by Negalein
                                        @apollon77 sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
                                        Ja, mehrere TB 🙂
                                        Führe doch mal
                                        root@ioBroker:/opt/iobroker# npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker"
                                        > iobroker.vis@1.1.10 install /opt/iobroker/node_modules/iobroker.vis
                                        module.js:550
                                            throw err;
                                        npm ERR! errno 1
                                        npm ERR! iobroker.vis@1.1.10 install: `node main.js --install`
                                        npm ERR!
                                        npm ERR!     /root/.npm/_logs/2019-05-08T21_48_42_503Z-debug.log
                                        Log von /root/.npm/_logs/2019-05-08T21_48_42_503Z-debug.log
                                        • Stabilostick
                                          Hmm, da steht auch nur drin:
                                          108 silly lifecycle iobroker.vis@1.1.10~install: Args: [ '-c', 'node main.js --install' ]
                                          112 silly lifecycle iobroker.vis@1.1.10~install: Returned: code: 1  signal: null
                                          113 info lifecycle iobroker.vis@1.1.10~install: Failed to exec install script
                                          Vielleicht im iobroker Ordner
                                          npm i iobroker.vis@1.1.10 --production --force
                                          ausführen?
                                          • apollon77
                                            Bitte nicht mit alten Versionen dinge tun, die 1.2.0 ist aktuell.
                                            Also ich habe es bei mir manuell gemacht und bei mir ist alles da.
                                            Bei Dir scheint im Verzeichnis iobroker.is die main,js zu fehlen nach dem entpacken ... und das kann an sich nicht sein. Irgendwas st da bei dir gerade komisch. Kann da irgendwas mit Docker dazwischenfunken?
                                            1.0k
                                            81.1k
                                            error update vis
                                            3056
