    4. Problem bei nodejs upgrade
    SOLVED Problem bei nodejs upgrade
      Smartuser last edited by
      Hallo Zusammen,
      ich wollte heute die nodejs v.6.x auf v.8. upgraden.
      Verwendet habe ich folgende Anleitung: klick
      Die neue Version wurde auch erfolgreich installiert.
      Leider crashed es beim Kompilieren der bereits installierten Adapter, also bei
      npm rebuild
      Hier fliegt er raus:
      In file included from ../src/poller.cpp:1:0:
      ../../nan/nan.h:1674:3: note: declared here
         Call(int argc, v8::Local<v8::Value> argv[]) const {
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm install iobroker.admin --production --prefix /opt/iobroker
      sh: 0: getcwd() failed: No such file or directory
      path.js:1165
              path = process.cwd();
      Error: ENOENT: no such file or directory, uv_cwd
          at Object.resolve (path.js:1165:24)
          at Function.Module._resolveLookupPaths (module.js:424:17)
          at Function.Module._resolveFilename (module.js:542:20)
          at Function.Module._load (module.js:475:25)
          at Module.require (module.js:597:17)
          at require (internal/module.js:11:18)
          at /usr/lib/node_modules/npm/bin/npm-cli.js:19:21
          at Object.<anonymous> (/usr/lib/node_modules/npm/bin/npm-cli.js:153:3)
          at Module._compile (module.js:653:30)
          at Object.Module._extensions..js (module.js:664:10)
      npm install iobroker.js-controller --production --prefix /opt/iobroker
      path.js:1165
      Could not find "/opt/iobroker/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
      Non-critical error: ENOENT: no such file or directory, mkdir '/opt/iobroker/node_modules/iobroker/lib/../../../log'
      npm ERR! path /opt/iobroker/node_modules/yargs/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/yargs/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /root/.npm/_logs/2019-05-11T12_12_34_461Z-debug.log
      root@ioBroker-Rock64:/opt/iobroker#
      System: Rock64
      Könnt ihr mir dabei weiterhelfen?
      Gruß Smartuser
        @Homoran
        Danke für die Rückmeldung.
        Ich glaube der Fehler lag darin, dass nach dem system reboot iobroker erneut gestopt werden muss.
        Ein erneutes Starten von
        npm rebuild
        ohne laufende iobroker instanze lief ohne probleme durch.
        Danke!
        Smartuser
          Homoran Global Moderator Administrators @Smartuser last edited by
          @Smartuser sagte in Problem bei nodejs upgrade:
          Wann wurde installiert?
          Ggf. Mit dem fixer bearbeitet?
            @Homoran
            npm rebuild
            Danke!
            Smartuser
            nodejs
