    2. English
    3. Scripting / Logic
    5. ASTRO function. Does not work again
      ap2017 last edited by ap2017
      Re: Is there problem with Blockly after last update?
      After testing for many weeks I came to a conclusion that ASTRO function does not work continuously, meaning it works ones after controller physical reboot and then never execute, see my simple Blockly script in reference post. I use all latest Linux, controller and adapters updates and 8.16.0 Node.js. Any idea what is going on?
        Please show your Blockly Script here, i think there is an errror in it.
        The Astro funktion works fine in my Blocklys.
        Enrico
            What does not work, set the control level to 99 or 0, or the telegram message, or both?
            You can use debug-blocks to control the trigger-blocks.
            Enrico
            A 2 Replies Last reply Reply Quote 0
              ap2017 @RappiRN last edited by ap2017
              @RappiRN As you see, I use telegram for debugging, so schedule block works all the time (the light goes on, then off and I am getting notification from telegram), while astro works only once in a while, it works for sure once after restarting RPI by interrupting the power
                @RappiRN May be I was not clear in my response. In ASTRO block, both telegram and setting level do not work (to be precise, work once after resetting power to Raspberry PI). In SCHEDULE block telegram and level setting work fine all the time.
                  Ok, in the settings from the javascript-Adapter you must set your location, or check to use the ioBroker location.
                  Enrico
                    @RappiRN I am aware of this and it was done. Don't forget, in my case ASTRO work right once after fresh power up, it turns up the light in expected time.
                      The right once working, is it also at the right time?
                      Which location settings you are using, from the adapter or from ioBroker? Sometimes it was a problem to use the ioBroker settings instead the adapter settings.
                      Sorry i have not really an idea what the matter with your astro-function.
                      Enrico
                        @RappiRN Yes, when I say it works right once, it means the timing is right. I tried both location settings, from the adapter as well as from system with same result.
                          Have brand new ioBroker installation on different platform (x64) with same script as show above, the Astro function still does not work. What am I doing wrong?
                          • iomountain
                            iomountain last edited by iomountain
                            @ap2017 for debuging use debug, not telegram.
                            substitute telegram whith debug to see what's going on.
                            Look at the LOG.
                            mine works:
                            c8d8d908-8721-440c-b8e0-f1d21907f888-image.png ,
                            Do you wanna Post an export of your Blockly?
                              ap2017 @iomountain last edited by
                              @iomountain Thank you for your response. I changed my script as you suggested, where do I find debugging log?
                              • iomountain
                                Try Log at main screen Admin
                                There you will find your "debug output" Messages
                                  @iomountain I think that after long time of straggling I am getting close to resolving the issue with ASTRO function that I am experiencing. It looks like ASTRO algorithm does not like GEO coordinates in North America since it started to work fine after I set ASTRO for Berlin, Germany. Maybe negative value of Longitude confuses the algorithm?
                                  Could you do me a favor and try your script with GEO set to Hartford CT in USA? Thank you.
                                  • iomountain
                                    It works, United States Hartford 41.76 -72.68
                                    If you wanna see all astro times try the Script
                                    // Astrotime for today - V2.0
                                    console.log("=====================");
                                    console.log("Astro time for today");
                                    var nightEnd = getAstroDate("nightEnd");
                                    console.log(" (0) nightEnd (End of night)........................: " + nightEnd.toLocaleTimeString());
                                    var nauticalDawn = getAstroDate("nauticalDawn");
                                    console.log(" (1) nauticalDawn (naut. Dämmerung Morgens)...........: " + nauticalDawn.toLocaleTimeString());
                                    var dawn = getAstroDate("dawn");
                                    console.log(" (2) dawn (Dämmerung Morgens).........................: " + dawn.toLocaleTimeString());
                                    var sunrise = getAstroDate("sunrise");
                                    console.log(" (3) sunrise (Sonnenaufgang)..........................: " + sunrise.toLocaleTimeString());
                                    var sunriseEnd = getAstroDate("sunriseEnd");
                                    console.log(" (4) sunriseEnd (Ende des Sonnenaufgangs).............: " + sunriseEnd.toLocaleTimeString());
                                    var goldenHourEnd = getAstroDate("goldenHourEnd");
                                    console.log(" (5) goldenHourEnd (Ende der Golden Hour VM)..........: " + goldenHourEnd.toLocaleTimeString());
                                    var solarNoon = getAstroDate("solarNoon");
                                    console.log(" (6) solarNoon (Mittag)...............................: " + solarNoon.toLocaleTimeString());
                                    var goldenHour = getAstroDate("goldenHour");
                                    console.log(" (7) goldenHour (Start der Golden Hour NM)............: " + goldenHour.toLocaleTimeString());
                                    var sunsetStart = getAstroDate("sunsetStart");
                                    console.log(" (8) sunsetStart (Start des Sonnenuntergangs).........: " + sunsetStart.toLocaleTimeString());
                                    var sunset = getAstroDate("sunset");
                                    console.log(" (9) sunset (Sonnenuntergang).........................: " + sunset.toLocaleTimeString());
                                    var dusk = getAstroDate("dusk");
                                    console.log("(10) dusk (Dämmerung Abends)..........................: " + dusk.toLocaleTimeString());
                                    var nauticalDusk = getAstroDate("nauticalDusk");
                                    console.log("(11) nauticalDusk (naut. Dämmerung Abends)............: " + nauticalDusk.toLocaleTimeString());
                                    var night = getAstroDate("night");
                                    console.log("(12) night (Start of night)..........................: " + night.toLocaleTimeString());
                                    var nadir = getAstroDate("nadir");
                                    console.log("(13) nadir (midnight)..............................: " + nadir.toLocaleTimeString());
                                    var today = new Date();
                                    var tomorrow = today.setDate(today.getDate()+1);
                                    var tomorrowNight = getAstroDate("night", tomorrow);
                                    console.log("Night starts tomorrow at " + tomorrowNight.toLocaleTimeString());
                                    console.log(obj.id);
                                    @ap2017
                                      @iomountain I will try to set ASTRO back to US, thanks
                                      • iomountain
                                        @ap2017 don't forget to restart iobroker. Like "iobroker stop" and "iobroker start"
                                          @iomountain Day I switched to US the ASTRO stopped working (no ASTRO string in LOG file). I restarted computer after I made a change. I will try your ASTRO script
                                          Here is my script:
                                          // Living Room Light
                                          schedule({astro: "goldenHour", shift: 0}, function () {
                                          console.log('astro_on');
                                          setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                                          schedule("0 18 * * *", function () {
                                          console.log('schedule_on');
                                          schedule("30 23 * * *", function () {
                                          console.log('schedule_off');
                                          setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                                            @iomountain Here is the log from running your script Astro Time for Today, if it helps. So, script runs but shows error code at the end of each run.
                                            2019-10-19 18:48:42.414 - info: mysensors.0 (18452) STARTED
                                            2019-10-19 18:48:42.415 - info: mysensors.0 (18452) STARTED
                                            2019-10-19 18:48:55.725 - info: javascript.0 (18920) Stop script script.js.ASTRO
                                            2019-10-19 18:48:55.770 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                                            2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: =====================
                                            2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: Astro time for today
                                            2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: (0) nightEnd (End of night)........................: 5:36:06 AM
                                            2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (1) nauticalDawn (naut. Dämmerung Morgens)...........: 6:08:18 AM
                                            2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (2) dawn (Dämmerung Morgens).........................: 6:40:39 AM
                                            2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (3) sunrise (Sonnenaufgang)..........................: 7:08:50 AM
                                            2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (4) sunriseEnd (Ende des Sonnenaufgangs).............: 7:11:46 AM
                                            2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (5) goldenHourEnd (Ende der Golden Hour VM)..........: 7:46:57 AM
                                            2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (6) solarNoon (Mittag)...............................: 12:37:25 PM
                                            2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (7) goldenHour (Start der Golden Hour NM)............: 5:27:52 PM
                                            2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (8) sunsetStart (Start des Sonnenuntergangs).........: 6:03:04 PM
                                            2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (9) sunset (Sonnenuntergang).........................: 6:06:00 PM
                                            2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (10) dusk (Dämmerung Abends)..........................: 6:34:11 PM
                                            2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (11) nauticalDusk (naut. Dämmerung Abends)............: 7:06:31 PM
                                            2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (12) night (Start of night)..........................: 7:38:44 PM
                                            2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (13) nadir (midnight)..............................: 12:37:25 AM
                                            2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: =====================
                                            2019-10-19 18:48:55.777 - info: javascript.0 (18920) script.js.ASTRO: Night starts tomorrow at 7:37:17 PM
                                            2019-10-19 18:48:55.777 - error: javascript.0 (18920) script.js.ASTRO: script.js.ASTRO:41
                                            2019-10-19 18:48:55.777 - error: javascript.0 (18920) console.log(obj.id);
                                            2019-10-19 18:48:55.778 - error: javascript.0 (18920) ^
                                            2019-10-19 18:48:55.778 - error: javascript.0 (18920) ReferenceError: obj is not defined
                                            2019-10-19 18:48:55.778 - error: javascript.0 (18920) at script.js.ASTRO:41:13
                                            2019-10-19 18:48:55.778 - error: javascript.0 (18920) at Script.runInContext (vm.js:133:20)
                                            iomountain 1 Reply Last reply Reply Quote 0
                                            blockly
                                            6843
