    5. Blockly fhem Loop ?
    Blockly fhem Loop ?
      ChrisXY last edited by
      frage einfach nur einen Wert der per fhem adapter kommt ab.
      Present/abesent
      Aber er Spammt mich mit nachrichten zu .. verstehe nicht wieso.
      12:59:36.888	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.state, timerId=undefined) => {"val":"present","ack":true,"ts":1558436376871,"q":0,"from":"system.adapter.fhem.0","lc":1558436376871}
      12:59:36.889	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: sendTo(adapter=telegram, cmd=send, msg={"text":"Tanja DA FHEM UNIFI"})
      12:59:36.939	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.state, timerId=undefined) => {"val":"maybe absent","ack":true,"ts":1558436376927,"q":0,"from":"system.adapter.fhem.0","lc":1558436376927}
      12:59:36.940	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.presence, timerId=undefined) => {"val":"maybe absent","ack":true,"ts":1558436369215,"q":0,"from":"system.adapter.fhem.0","lc":1558436369215}
      12:59:44.198	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.state, timerId=undefined) => {"val":"present","ack":true,"ts":1558436384189,"q":0,"from":"system.adapter.fhem.0","lc":1558436384189}
      12:59:44.198	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: sendTo(adapter=telegram, cmd=send, msg={"text":"Tanja DA FHEM UNIFI"})
      12:59:44.246	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.state, timerId=undefined) => {"val":"maybe absent","ack":true,"ts":1558436384241,"q":0,"from":"system.adapter.fhem.0","lc":1558436384241}
      12:59:44.247	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.presence, timerId=undefined) => {"val":"maybe absent","ack":true,"ts":1558436377409,"q":0,"from":"system.adapter.fhem.0","lc":1558436377409}
      • LausiD
        LausiD last edited by LausiD
        @ChrisXY
        getState(id=fhem.0.handy_tanja_unifi.state) wechselt zwischen present und maybe absent.
        Und bei jeder Änderung wird dein Script neu gestartet.
        Solltest schauen in FHEM das "state" stabil bekommen
        LausiD
