    5. Blockly Error im Log aber script funktioniert
      Shepherd last edited by Shepherd
      Hallo an alle,
      Habe mein Blockly Script erstellt fürs Toilettenfenster damit ich es nicht vergesse zu zu machen.
      Das Script funktioniert aber im Log kommt immer nach dem Neustarten des Mi Home Adapter:
      javascript.0	2019-05-22 17:03:12.106	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2019-05-22 17:03:12.106	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
      javascript.0	2019-05-22 17:03:12.106	error	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
      javascript.0	2019-05-22 17:03:12.106	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      javascript.0	2019-05-22 17:03:12.106	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      javascript.0	2019-05-22 17:03:12.106	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-05-22 17:03:12.106	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
      javascript.0	2019-05-22 17:03:12.106	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
      javascript.0	2019-05-22 17:03:12.106	error	at Object.<anonymous> (script.js.Fenster.Toilettenfenster:19:75)
      javascript.0	2019-05-22 17:03:12.105	error	at script.js.Fenster.Toilettenfenster:19:17
      javascript.0	2019-05-22 17:03:12.104	error	Error in callback: ReferenceError: Auslösen is not defined
      Wenn ich das script stoppe und neustarte über die pause Button im Blockly kommt diese Meldung im LOG:
      javascript.0	2019-05-22 17:04:35.777	info	script.js.Fenster.Toilettenfenster: registered 2 subscriptions and 0 schedules
      javascript.0	2019-05-22 17:04:35.774	info	Start javascript script.js.Fenster.Toilettenfenster
      javascript.0	2019-05-22 17:03:34.180	info	Stop script script.js.Fenster.Toilettenfenster
      Wenn das script dann Auslöst kommt dies im Log:
      javascript.0	2019-05-22 17:04:57.320	warn	at Timer.listOnTimeout (timers.js:290:5)
      javascript.0	2019-05-22 17:04:57.320	warn	at tryOnTimeout (timers.js:323:5)
      javascript.0	2019-05-22 17:04:57.320	warn	at ontimeout (timers.js:511:34)
      javascript.0	2019-05-22 17:04:57.320	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1869:34)
      javascript.0	2019-05-22 17:04:57.320	warn	at Object.<anonymous> (script.js.Fenster.Toilettenfenster:8:5)
      javascript.0	2019-05-22 17:04:57.320	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
      javascript.0	2019-05-22 17:04:57.318	warn	Wrong type of mihome.0.devices.gateway_04cf8c9140a4.dimmer: "string". Please fix, while deprecated and will not work in next versions.
      Habe auch schon festgestellt dass das Pause Zeichen hinter dem script auch schon gelb war anstatt grün, aber script funktioniert.
      Kann mir dabei vielleicht jemand helfen was falsch ist?
      Grüsse Shepherd
