    2. English
    3. Visualization
    4. Controlling multiple objects by single widget
      ap2017 last edited by ap2017
      I would like to use a single JQUI widget Select Value List to enter value into several control objects (thermostats). If it is doable, what would be syntax of specifying multiple Object IDs within Select Value List widget?
      • Stephan Schleich
        Stephan Schleich last edited by
        @ap2017 sagte in Controlling multiple objects by single widget:
        Select Value List
        I have the same Problem, someone has a workaround?
        • E
          erwinberlin @ap2017 last edited by
          I guess the best approach is to make a new object, which sets the control value. Subsequently build a JS or blockly to read the value of the object and control multiple objects.
          vis
