    4. [Fehler] Adapter deaktiviert # Adapter started (Yr, DWD)
    • derAuge
      derAuge last edited by
      Habe die beiden Adapter (YR,DWD) deaktiviert.
      Es wird trotzdem versucht den Adapter zu starten
      • host-RPi2-2 2016-04-04 07:06:03 error instance system.adapter.yr.0 terminated with code 3 (Adapter disabled or invalid config)
      host-RPi2-2 2016-04-04 07:06:00 info instance system.adapter.yr.0 started with pid 4460
      host-RPi2-2 2016-04-04 07:03:04 error instance system.adapter.dwd.0 terminated with code 3 (Adapter disabled or invalid config)
      host-RPi2-2 2016-04-04 07:03:00 info instance system.adapter.dwd.0 started with pid 4450
      host-RPi2-2 2016-04-04 06:06:03 error instance system.adapter.yr.0 terminated with code 3 (Adapter disabled or invalid config)
      host-RPi2-2 2016-04-04 06:06:00 info instance system.adapter.yr.0 started with pid 4234
      host-RPi2-2 2016-04-04 06:03:04 error instance system.adapter.dwd.0 terminated with code 3 (Adapter disabled or invalid config)
      host-RPi2-2 2016-04-04 06:03:00 info instance system.adapter.dwd.0 started with pid 4224
      host-RPi2-2 2016-04-04 05:06:03 error instance system.adapter.yr.0 terminated with code 3 (Adapter disabled or invalid config)
      host-RPi2-2 2016-04-04 05:06:00 info instance system.adapter.yr.0 started with pid 4173
      host-RPi2-2 2016-04-04 05:03:04 error instance system.adapter.dwd.0 terminated with code 3 (Adapter disabled or invalid config)
      host-RPi2-2 2016-04-04 05:03:00 info instance system.adapter.dwd.0 started with pid 4163
      host-RPi2-2 2016-04-04 04:06:03 error instance system.adapter.yr.0 terminated with code 3 (Adapter disabled or invalid config)
      host-RPi2-2 2016-04-04 04:06:00 info instance system.adapter.yr.0 started with pid 4108
      host-RPi2-2 2016-04-04 04:03:04 error instance system.adapter.dwd.0 terminated with code 3 (Adapter disabled or invalid config)
      host-RPi2-2 2016-04-04 04:03:00 info instance system.adapter.dwd.0 started with pid 4099
      Glaube das es nicht so gewollt ist
      Jürgen
