    4. Fehler bei der Installation
      pcbasti last edited by
      wenn ich iobroker installieren möchte bekomme ich folgende Fehlermeldung und Abbruch der Installation.
      508 error SyntaxError: Unexpected token ^_
      508 error ^_�^H^@^@^@^@^@^D^C�Ymo^\�^Q�+̺���no�_T؍�^V��^F)�&(pg�H.����rKr%]^E���pW�S^Z�V�^H� @������p��ٙk﬩�^S�?��\uқygZ\�L:��BFy�H�r����KV�(�h �\&@�ѭ���^R�릷��`���^R�1=�$
      508 error 7^VԢ^F~z��^^t�^O��|?�;{���/^^D^Ddg�^CjC��A �AU4��ң;�^G�xNx�^P7^P^B��^K|!�<^A^_X�     ��_�^G^F��ei�g�^RQ^Ai^Cc<�2�Y"*�f�^_^U^M�0eএ^N�0vn������$-i^^'^@�i����^$
      508 error =^A�^H|c�8��45���M�o胧��-�2�2^R2-B)BȞ2��y�G^Y$�i�����^P^QǠ�ED��BTU^X&�HyY�1��"/�DD���2��@��*�aD�����^Y���f�   d�.��|��g��^P�3^@^Qs���^D���S^@�)^S�w�'@ܿ^B?^V@,$
      508 error ^Vr� �
      508 error �8    e^F0��RD���^T�Ɯ
      508 error ^QKV�(�,��V1��^K^ZD2^H��穌^BLM^^^W �C��^Bć�^P�O^AD�ԟ^��^@q^O�X��c     s��NL^Q�����A��=K�Y&^D�Q�$+h^RP�ќc��^F^Ad�i��y�>JXt/��^Û(���s(t�i�sN�^V^ZdTR(^X�*���HD^$
      508 error �f^^F�Kh��P�t4S�sl$�-V���a�^S^Z1(�Y��E        ��2/��,��8*�^P\2        �,�cL�~Y�����|�=#7eK��j��д^Uym�^]̛�������1s ��a�t/�o.��0M;�y��^F�8����U��^��Ь^Í߃|]M�R-1�$
      508 error y�_u���u_�̪^C��^N�y��'/�5�3@7���M�>?�3
      508 error ;Q^\=��z~���vG�s�x9���T+�V�Ӓ? ����^B(Gy���$����^?��I��,/i{n�[^?�R�����;^F��^B��^@�^H�_�BP�^O�q킁      �填f�^?^@^@^@���Z�n�@^P��Q�$^GV�^P^\VUOQN=T.�&��6��^Z�̦�$
      508 error �^R���0��H^Wqd��\�*�s^N^R�?^_�^W��Ԉ��45�V�|�P����M^\���ڤ�Ip7ɴ^O^YP�a��E^T�w^S�J'�a���('r�3��<
      508 error ������^A��Mڱ^S�^]$� $�r�D�/M�^Zy�_Y[-�^M��l.z~�       ����y&^@^@
      508 error     at Object.parse (native)
      508 error     at RegClient. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:238:23)
      508 error     at Request.self.callback (/usr/local/lib/node_modules/npm/node_modules/request/request.js:129:22)
      508 error     at Request.EventEmitter.emit (events.js:98:17)
      508 error     at Request. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/request/request.js:873:14)
      508 error     at Request.EventEmitter.emit (events.js:117:20)
      508 error     at IncomingMessage. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/request/request.js:824:12)
      508 error     at IncomingMessage.EventEmitter.emit (events.js:117:20)
      508 error     at _stream_readable.js:920:16
      508 error     at process._tickCallback (node.js:415:13)
      509 error If you need help, you may report this log at:
      509 error     <http: github.com/isaacs/npm/issues="">509 error or email it to:
      509 error     <npm-@googlegroups.com>510 error System Linux 3.18.11-v7+
      511 error command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker"
      512 error cwd /opt/iobroker
      513 error node -v v0.10.22
      514 error npm -v 1.3.14
      515 error type unexpected_token
      516 verbose exit [ 1, true ]</npm-@googlegroups.com></http:></anonymous></anonymous></anonymous>
      Das ist ein Auszug meiner npm-debug.log
      Meine Config:
      Raspberry Pi B2
      Debian Whreezy
      ich hoffe mir kann jemand helfen.
      vielen Dank
        @pcbasti:
        508 error ^Vr� �
        Meine Config:
        Raspberry Pi B2
        Debian Whreezy
        vielen Dank `
        Dein npm ist ziemlich alt.
        npm install -g npm@latest-2
        Kannst du node.js 4.x installieren?
          Hallo Bluefox,
          npm hab ich Aktualisiert nun bekommen ich das hier als Fehler.
          npm WARN cannot run in wd iobroker@0.7.1 node lib/setup.js (wd=/opt/iobroker/node_modules/iobroker)
          iobroker@0.7.1 node_modules/iobroker
          └── yargs@4.4.0 (decamelize@1.2.0, camelcase@2.1.1, y18n@3.2.1, window-size@0.2.0, require-main-filename@1.0.1, yargs-parser@2.2.0, lodash.assign@4.0.7, string-width@1.0.1, os-locale@1.4.0, cliui@3.1.2, pkg-conf@1.1.2, read-pkg-up@1.0.1)
          Nodejs ist die aktuellste bereits installiert sagt er mir.
          Seltsam ist auch das bei meinem Bruder genau die gleiche Installation gestern ohne Probleme durchgelaufen ist.
            @pcbasti:
            Hallo Bluefox,
            Seltsam ist auch das bei meinem Bruder genau die gleiche Installation gestern ohne Probleme durchgelaufen ist. `
            sudo benutzt?
              alles unter Root ausgeführt.
                @pcbasti:
                alles unter Root ausgeführt. `
                Laut http://stackoverflow.com/questions/1813 … -run-in-wd
                Sollte man das Kommando mit --unsafe-perm aufrufen.
                  @Bluefox:
                  @pcbasti:
                  Sollte man das Kommando mit --unsafe-perm aufrufen. `
                  Hallo Bluefox,
                  mit dem Kommando davor hat es funktioniert, vielen Dank dafür.
                  Ist es normal das ich das admin Password nicht ändern kann?
                  Wenn ich ein neues eingebe bekomme ich weder einer Bestätigung noch ändert er es, wenn ich es dann mit sudo iobroker passwd versuche sagt er mir immer folgendes:
                  error: Invalid input for Enter your password:
                  error: No " are allowed
                  versucht habe ich:
                  sudo iobroker passwd admin –mein gewähltes password
                  Egal wie ich es versuche es klappt nicht.
