    2. English
    3. ioBroker general
    4. Telegram SOLVED
    Telegram SOLVED
      ap2017 last edited by ap2017
      I use telegram to send notifications in case of any issues in the house, but telegram has very annoying feature - every morning at 5.04 am it sends notifications: Restarting and then Started! Is there a way to disable it?
      SOLVED thanks to community. To get rid of starting messages go to telegram instance properties, then go to messages tab and delete "-" in the message body. Apparently, "-" means default message instead of expected no message.
        Michaelnorge last edited by
        No problem, here you can turn off....
        alt text
          ap2017 @Michaelnorge last edited by
          @Michaelnorge In my system schedule for telegram is disabled
            Adnim last edited by
              Adnim last edited by Adnim
              Goto Telegramm Options, Messages, Delete Start and Stop Messages ->as in German PIC above
              I suggest to get that Schedule on, to avoid Problems with Adapter...
              A 2 Replies Last reply Reply Quote 0
                ap2017 @Adnim last edited by ap2017
                @Adnim I don't have start/stop messages configured within telegram adapter configuration
                But, when I switch to Expert mode, I started to see scheduler setting for telegram as suggested by Michaelnorge. I reset the setting, hopefully it will work.
                  @Adnim I don't have start and stop messages setup, so why I am receiving them?
                  X 1 Reply Last reply Reply Quote 0
                  • X
                    Xyolyp @ap2017 last edited by
                    @ap2017 the "-" does not mean no message but default message. If you completely empty out the input fields you won't get any messages.
                      Michaelnorge @ap2017 last edited by
                      @ap2017 But your expert-mode is turned on?
                      alt text
                        ap2017 @Xyolyp last edited by
                        @Xyolyp Thank you!
                        1.0k
                        telegram
                        1350
