    4. Web stürzt ab 2. Benutzer für VIS
    UNSOLVED Web stürzt ab 2. Benutzer für VIS
      ChrisXY last edited by
      seit ich eine 2. Gruppe gemacht habe ( Tablet ) ALLE RECHTE GEGEBEN. Und dort den User Tablet hinzugefügt habe, stürzt mein WEB Adapter rimmer ab.
      host.iobroker	2019-06-04 09:20:17.440	info	Restart adapter system.adapter.web.0 because enabled
      host.iobroker	2019-06-04 09:20:17.440	error	instance system.adapter.web.0 terminated with code 0 (OK)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
      host.iobroker	2019-06-04 09:20:17.440	error	Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
      host.iobroker	2019-06-04 09:20:17.439	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
      web.0	2019-06-04 09:20:17.407	error	uncaught exception: Maximum call stack size exceeded
      Ich öffne einmal Lokal zuhause per IP und 8082 eine VIS und zusätzlich bin ich draußen per reserve proxy vis.domain.de am versuchen zu arbeiten ...
      Bevor ich den tablet User angelegt habe und zuhause eingeloggt hatte ging es per Admin Problemlos
        also wenn ich im Tablet zuhause nichts aufrufe ( Browser zu ) ddann kkann ich extern wieder arbeiten ohne absturz...
        • apollon77
          apollon77 last edited by
          Welcher js-controller? Nodejs? Sonstige Adapterversionen?
            ChrisXY last edited by ChrisXY
            Node.js
            v8.16.0
            NPM
            6.4.1
            JS: 1.5.11
            Web: 2.4.1
            VIS: 1.2.0
            Gerade vom git WEB Update gemacht auf 2.4.3. Aktuell keine Probleme 🙂
            • apollon77
              Hast Du mehr logging oder Warnungen oberhalb der crash Meldung?
              • apollon77
                Und zeig bitte mal die Gruppendefinition und den neuen User
                  hatte ein edit gemacht 🙂
                  Nach neuste WEB Update scheint es ohne Fehler zu laufen
                  • apollon77
                    Ich verstehe die Aussagen gerade nicht? Was hast Du "edit gemacht"? Welche web Version nutzt du jetzt wo es wieder tut?
                      Homoran Global Moderator Administrators @ChrisXY last edited by Homoran
                      @ChrisXY sagte in Web stürzt ab 2. Benutzer für VIS:
                      Bitte auch als "EDIT" kennzeichnen!
                      benutzer vis web
