    4. Adapter MiHome ständiger Neustart
    SOLVED Adapter MiHome ständiger Neustart
      lindi200000 last edited by
      Mein MiHome Adapter startet ständig neu.
      Wenn ich die Log richtig lese, dann gibt es Verbindungsprobleme (?), aber vom Handy gibt es keine Probleme und auch nicht die Sensoren dahinter auslesen macht keine Probleme. Hat jemand eine Idee?
      Hier der Log Eintrag:
      mihome.0	2019-06-11 11:27:36.552	info	starting. Version 1.2.6 in /opt/iobroker/node_modules/iobroker.mihome, node: v8.15.1
      host.raspberrypi	2019-06-11 11:27:33.803	info	instance system.adapter.mihome.0 started with pid 16268
      host.raspberrypi	2019-06-11 11:27:32.786	info	Restart adapter system.adapter.mihome.0 because enabled
      host.raspberrypi	2019-06-11 11:27:32.785	error	instance system.adapter.mihome.0 terminated with code 0 (OK)
      Caught	2019-06-11 11:27:32.785	error	by controller[0]: at Timer.listOnTimeout (timers.js:290:5)
      Caught	2019-06-11 11:27:32.785	error	by controller[0]: at tryOnTimeout (timers.js:323:5)
      Caught	2019-06-11 11:27:32.785	error	by controller[0]: at ontimeout (timers.js:498:11)
      Caught	2019-06-11 11:27:32.784	error	by controller[0]: at Timeout.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.mihome/lib/Sensors/Gateway.js:193:36)
      Caught	2019-06-11 11:27:32.784	error	by controller[0]: at Hub.getKey (/opt/iobroker/node_modules/iobroker.mihome/lib/Hub.js:144:31)
      Caught	2019-06-11 11:27:32.783	error	by controller[0]: at Object.createCipheriv (crypto.js:619:10)
      Caught	2019-06-11 11:27:32.763	error	by controller[0]: at new Cipheriv (crypto.js:219:16)
      Caught	2019-06-11 11:27:32.762	error	by controller[0]: Error: Invalid key length
      mihome.0	2019-06-11 11:27:32.740	info	terminating
      mihome.0	2019-06-11 11:27:32.692	error	at Timer.listOnTimeout (timers.js:290:5)
      mihome.0	2019-06-11 11:27:32.692	error	at tryOnTimeout (timers.js:323:5)
      mihome.0	2019-06-11 11:27:32.692	error	at ontimeout (timers.js:498:11)
      mihome.0	2019-06-11 11:27:32.692	error	at Timeout.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.mihome/lib/Sensors/Gateway.js:193:36)
      mihome.0	2019-06-11 11:27:32.692	error	at Hub.getKey (/opt/iobroker/node_modules/iobroker.mihome/lib/Hub.js:144:31)
      mihome.0	2019-06-11 11:27:32.692	error	at Object.createCipheriv (crypto.js:619:10)
      mihome.0	2019-06-11 11:27:32.692	error	at new Cipheriv (crypto.js:219:16)
      mihome.0	2019-06-11 11:27:32.692	error	Error: Invalid key length
      mihome.0	2019-06-11 11:27:32.689	error	uncaught exception: Invalid key length
      mihome.0	2019-06-11 11:25:06.325	info	Change connection status: true
      mihome.0	2019-06-11 11:25:06.227	info	Change connection status: false
      mihome.0	2019-06-11 11:25:05.615	info	starting. Version 1.2.6 in /opt/iobroker/node_modules/iobroker.mihome, node: v8.15.1
      host.raspberrypi	2019-06-11 11:25:02.857	info	instance system.adapter.mihome.0 started with pid 15671
      host.raspberrypi	2019-06-11 11:25:01.839	info	Restart adapter system.adapter.mihome.0 because enabled
      Ich hoffe mir kann da wer helfen. Durch den Neustart kann ich keine Befehle an den Gateway senden.
      VG
      Lindi
        danke für den Hint. Der Key war richtig, aber die IP Adresse hat sich geändert, muss mal schauen wo ich die fix machen kann.
        • crunchip
          crunchip Forum Testing Most Active @lindi200000 last edited by
          @lindi200000 dein Key richtig eingetragen?
            mihome error restart
