    4. Scriptseite nur drehendes Zeichen
    UNSOLVED Scriptseite nur drehendes Zeichen
      stephan61 last edited by
      Hallo habe folgendes Problem wenn ich auf die Seite script möchte erscheint nur das drehende Symbol
      Js controller 1.5.12 admin 3.6.3
      javascript 4.1.13
      in der console kommt folgende Meldung
      Subscribe logs
      blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_EQ}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_NEQ}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_LT}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_LTE}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_GT}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_GTE}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_OPERATION_TOOLTIP_AND}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_OPERATION_TOOLTIP_OR}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_WHILEUNTIL_TOOLTIP_WHILE}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_WHILEUNTIL_TOOLTIP_UNTIL}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FLOW_STATEMENTS_TOOLTIP_BREAK}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FLOW_STATEMENTS_TOOLTIP_CONTINUE}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FOR_TOOLTIP}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FOREACH_TOOLTIP}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_ADD}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_MINUS}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_MULTIPLY}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_DIVIDE}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_POWER}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_ROOT}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_ABS}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_NEG}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_LN}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_LOG10}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_EXP}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_POW10}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_SIN}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_COS}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_TAN}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ASIN}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ACOS}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ATAN}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_SUM}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MIN}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MAX}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_AVERAGE}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MEDIAN}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MODE}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_STD_DEV}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_RANDOM}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_CHANGE_TOOLTIP}.
      blockly_compressed.js:893 WARNING: No message string for %{BKY_TEXT_APPEND_TOOLTIP}.
      manchmal offnet sich die Seite
      Gruß Stephan
      • Spegeli
        Spegeli last edited by Spegeli
        Hab das Problem seit heute selber und konnte es etwas einschränken:
        Ist im Admin.0 Adapter bei "Ausführen als" der Standard "Admin" ausgewählt funktioniert alles ohne Probleme.
        Wählt man dort aber einen anderen User bzw. selbst angelegten Admin aus dann lässt sich der Skripte Tab nicht mehr öffnen.
        Auch wenn man die Authentifikation beim Admin.0 einschaltet und sich dann per Standard Admin einloggt geht es, mit dem selbst angelegten Admin allerdings nicht.
        Das Problem existiert wohl schon eine weile: https://github.com/ioBroker/ioBroker.javascript/issues/373
        Eine Fix, eine Lösung oder ein Workaround dafür wären schön.
        nkleber78 created this issue in ioBroker/ioBroker.javascript
        closed Javascript Script Tab öffnet nur manchmal #373
          Homoran Global Moderator Administrators @stephan61 last edited by
          @stephan61
          Bitte hier weitemachen
          https://forum.iobroker.net/topic/23145/scriptseite-nur-drehendes-zeichen
          fehler script seite
