    4. IoBroker simple web Adapter nach Update zerschossen
      LDSign last edited by
      Hi
      Seit vorhin ist ein Update für den simple Web Adapter verfügbar. Allerdings konnte man dieses nicht vollständig installieren und der Adapter war danach zerschossen.
      Eine Neuinstallation ist ebenfalls nicht mehr möglich:
      $ ./iobroker add web
      npm install iobroker.web --production --prefix "/opt/iobroker" (System call)
      npm
      ERR! notarget
       No compatible version found: iobroker.socketio@'>=1.3.0'npm
      ERR! notarget
       Valid install targets:npm
       ERR!
      notarget
       ["0.1.1","0.1.2","0.1.3","0.1.4","0.1.5","0.1.7","0.2.0","0.2.1","0.2.2","0.2.3","0.3.0","0.4.1","0.4.2","0.4.3","0.4.4","0.4.5","1.0.0","1.2.1","1.2.2","1.2.3"]
      npm
       ERR!
       notarget npm
      ERR! notarget This is most likely not a problem with npm itself.
      npm ERR!
      notarget
       In most cases you or one of your dependencies are requesting
      npm
       ERR!
      notarget a package version that doesn't exist.
      npm
       ERR! System
       Linux 4.2.0-35-generic
      npm
      ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.web" "--production" "--prefix" "/opt/iobroker"
      npm ERR!
       cwd /
      npm ERR!
       node -v v0.10.25npm
      ERR! npm -v 1.4.21npm ERR! code ETARGET
      npm ERR! npm ERR! Additional logging details can be found in:
      npm ERR!     /npm-debug.log
      npm ERR! not ok code 0
      ERROR: host.SmartHome Cannot install iobroker.web: 1
      ERROR: process exited with code 25
      Eine manuelle Installation (npm install iobroker.web) über die Konsole liefert folgendes:
      npm ERR! notarget No compatible version found: iobroker.socketio@'>=1.3.0'
      npm ERR! notarget Valid install targets:
      npm ERR! notarget ["0.1.1","0.1.2","0.1.3","0.1.4","0.1.5","0.1.7","0.2.0","0.2.1","0.2.2","0.2.3","0.3.0","0.4.1","0.4.2","0.4.3","0.4.4","0.4.5","1.0.0","1.2.1","1.2.2","1.2.3"]
      npm ERR! notarget
      npm ERR! notarget This is most likely not a problem with npm itself.
      npm ERR! notarget In most cases you or one of your dependencies are requesting
      npm ERR! notarget a package version that doesn't exist.
      npm ERR! System Linux 4.2.0-35-generic
      npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.web"
      npm ERR! cwd /opt/iobroker
      npm ERR! node -v v0.10.25
      npm ERR! npm -v 1.4.21
      npm ERR!
      npm ERR!     /opt/iobroker/npm-debug.log
      Was läuft hier schief?
      Viele Grüße,
      Frank
        Pman last edited by
        jup, socketio ist erst bei 1.2.3, der neue web verlangt aber nach 1.3.0
          looxer01 last edited by
          das gleiche hier.
          Könnte das mit dem ADMIN Adapter update zusammenhängen ?
          Github:
          1.0.2 (2016-04-07) - (bluefox) show npm errors of version
          vG
            Danke. Wie kann ich das kurzfristig lösen? Oder ist ein Update in Vorbereitung?
            Gruß,
            Frank
              @LDSign:
              Hi
              npm
              ERR! notarget
              ERR! notarget
               ERR!
              notarget
              npm
               ERR!
               notarget npm
              npm ERR!
              notarget
              npm
               ERR!
              npm
               ERR! System
              npm
              npm ERR!
               cwd /
              npm ERR!
               node -v v0.10.25npm
              npm ERR! notarget
              npm ERR!
              Viele Grüße,
              Frank `
              Probier noch mal.
                Läuft wieder 🙂 Danke für die schnelle Hilfe 🙂
                Gruß,
                Frank
                  hier auch.
                  vielen Dank
