    4. [Vorlage] Konfigurierte Script um States zu zahlen [lowbat, dimmer, shutter, chromecast, etc]
    • V
      vegetto last edited by
      da ich nicht für jede Status Abfragen, ein eigenes Script schreiben wollte, habe ich eine geschrieben, das konfiguriert ist. Es ist bassiert auf dem LOWBAT Script hier in Forum aber mit Zahlreiche Anpassungen.
      Falls es jemand hilft, hier ist es:
      //Add device rules
      addDeviceCounter("lowbat",         $('channel[state.id=*.LOWBAT]'),                      true);
      addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
      addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
      addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
      addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
      addDeviceCounter("on_lights",      $('channel{TYPE=DIMMER}[state.id=*.LEVEL]'),          function(state){return state>0;});
      addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
      addDeviceCounter("playing_music",  $('channel[state.id=*audio-*.playing]'),              true);
       * Code - do not change anything bellow this line *
      function addDeviceCounter(name, selector, val_to_count) {
          //Total amount of devices found by selector
          var state_total = 'deviceCounter.' + name + '.total';
          createState(state_total, 0);
          //List of devices that match condition
          var state_list = 'deviceCounter.' + name + '.list';
          createState(state_list, "");
          //Number of devices that match condition
          var state_counter = 'deviceCounter.' + name + '.counter';
          createState(state_counter, 0);
          function countDevs(obj) {
              var d_count = 0;
              var d_list  = [];
              selector.each(function (id, i) {
                  var status = getState(id).val;
                  var obj    = getObject(id);
                  if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                      (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                      //Get parent object
                      var parentChannelId = id.slice(id.lastIndexOf("."));
                      var parentDevicelId = id.split(".").slice(0,-2).join(".");
                      var deviceObject = getObject(parentDevicelId);
                      //remember device name
                      d_list.push(deviceObject.common.name);
                  ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
              log(name + "(" + d_count + "): " + d_list);
              setState(state_list,     d_list.join('
              setState(state_counter,  d_list.length);
              setState(state_total,    d_count);
          //Re-evaluate when a device status changes
          selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
              countDevs(obj);
          //Re-evaluate each hour
          schedule("*/60 * * * *", countDevs);
          //Evaluate for the first time
          countDevs();
      • ruhr70
        ruhr70 last edited by
        Sehr brauchbar. Danke!
        • E
          Elitepain77 last edited by
          Hallo!
          Super Script! Habe bei den Dimmern noch über .state die Lichter eingebaut.
          Gibt es eine Möglichkeit, explizite Geräte vom Zählen auszuschließen?
          Habe einen Magnetkontakt als Impulsgeber für den Zähler meiner Ölheizung umgebaut und habe nun leider nicht die MÖglichkeit diesen vom Tür/Fenster Zähler auszuklammern.
          Würde mich über Unterstützung freuen.
          VG
          Chris
            Smartuser last edited by
            ich habe eben dieses Script getestet. Vielen Dank dafür!
            Ich muss aber diese Frage nochmal aufgreifen:
            @Elitepain77:
            Gibt es eine Möglichkeit, explizite Geräte vom Zählen auszuschließen? `
            Ich besitze ein "3-Kanal-Funk-Schließerkontakt"
            filename="Schließer.jpg" index="0">~~
            Dieser wird leider bei den Fenstern mitgezählt. Kann man das ausschließen?
              pix last edited by
              Hallo Smartuser,
              du kannst den Gerätetyp eines Objektes in einer Subscription (on())so abfragen
              getObject(obj.deviceId).native.TYPE
              Dein Geräte ist ein HM-SCI-3-FM
              Angepasst auf das Skript also musst du an entsprechender Stelle einfügen:
              var device_shortname = getObject(id.deviceId).native.TYPE;
              if (device_shortname !== "HM-SCI-3-FM") {
                // Zählung ausführen
              Pix
              • kmxak
                @Elitepain77:
                Hallo!
                VG
                Chris `
                Gibt es da schon was neues? Habe auch ein paar Geräte die 'falsch' erkannt werden und die ich gerne irgendwie ausschließen würde
                  tempestas last edited by
                  Als Idee, ungetestet:
                  du könntest die auszuschließenden Geräte einem "room" zuordnen, die du z.B. "exclude" nennst.
                  Ich weiß nicht genau, ob in dem Skript "ungleich" / <> geht, aber dann könnte man es so versuchen:
                  addDeviceCounter("lowbat", $('channel[state.id=*.LOWBAT](rooms <> exclude) ' ), true);
                    @pix:
                    Hallo Smartuser,
                    Pix `
                    Hallo Pix,
                    vielen danke für deine Hilfe.
                    Leider komme ich damit nicht weiter.
                    Kannst du das bitte etwas ausführlicher erklären, bzw. wie ich das ins script einbaue.
                      Ich push den Beitrag nochmal … 😉
                      Vielleicht kann doch noch jemand helfen.
                        pix last edited by
                        Ich nutze das Skript (noch) nicht, aber versuche mal diesen Teil der Funktion
                                        //Get parent object
                        durch diese Zeilen zu ersetzen:
                                    // zum debug, kann später gelöscht werden
                                    log(getObject(id.deviceId).native.TYPE);
                                    // Ende debug kann gelöscht werden
                                    if (getObject(id.deviceId).native.TYPE !=="HM-SCI-3-FM") {
                                           //Get parent object
                                    } else log('Gerät "HM-SCI-3-FM" wird nicht mitgezählt');
                        Pix
                        EDIT 17.7.17: Diese Änderung funktioniert nicht.
                        Dieses Skript funktioniert (aber nur bei Änderungen in dem benannten Gerät):
                        // http://forum.iobroker.net/viewtopic.php?f=21&t=2651#p23393
                        ! //Add device rules
                        addDeviceCounter("lowbat", $('channel[state.id=.LOWBAT]'), true);
                        addDeviceCounter("unreach", $('channel[state.id=.UNREACH]'), true);
                        addDeviceCounter("open_windows", $('channel{TYPE=SHUTTER_CONTACT}[state.id=.STATE]'), true);
                        addDeviceCounter("open_shutters", $('channel{TYPE=BLIND}[state.id=.LEVEL]'), function(state){return state>0;});
                        addDeviceCounter("playing_music", $('channel[state.id=audio-.playing]'), true);
                        • Code - do not change anything bellow this line *
                        ! function addDeviceCounter(name, selector, val_to_count) {
                        ! //Total amount of devices found by selector
                        ! function countDevs(obj) {
                        var d_count = 0;
                        var d_list = [];
                        ! selector.each(function (id, i) {
                        //Get parent object
                        ! log(name + "(" + d_count + "): " + d_list);
                        ! setState(state_list, d_list.join('
                        ! //Re-evaluate when a device status changes
                        selector.on(function(obj) { // bei Zustandänderung . LOWBAT in allen Gewerken
                        log(getObject(obj.deviceId).native.TYPE);
                        if (getObject(obj.deviceId).native.TYPE !=="HM-SCI-3-FM") { //
                        countDevs(obj);
                        ! //Re-evaluate each hour
                        schedule("
                        countDevs();
                          @pix:
                          Ich nutze das Skript (noch) nicht, aber versuche mal diesen Teil der Funktion `
                          Danke für deine Hilfe.
                          Mit der Anpassung des Scriptes erhalte ich folgende Fehlermeldung:
                          Log im script-editor:
                          > javascript.0 script.js.Scripte.States_zaehlen_neu: TypeError: Cannot read property 'native' of null at script.js.Scripte.States_zaehlen_neu:37:39 at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1212:33) at countDevs (script.js.Scripte.States_zaehlen_neu:32:18) at addDeviceCounter (script.js.Scripte.States_zaehlen_neu:70:5) at script.js.Scripte.States_zaehlen_neu:2:1
                          iobroker console:
                          ` > javascript.0 2017-07-16 15:47:20.950 error at script.js.Scripte.States_zaehlen_neu:2:1
                          javascript.0 2017-07-16 15:47:20.950 error at addDeviceCounter (script.js.Scripte.States_zaehlen_neu:70:5)
                          javascript.0 2017-07-16 15:47:20.950 error at countDevs (script.js.Scripte.States_zaehlen_neu:32:18)
                          javascript.0 2017-07-16 15:47:20.950 error at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1212:33)
                          javascript.0 2017-07-16 15:47:20.950 error at script.js.Scripte.States_zaehlen_neu:37:39
                          javascript.0 2017-07-16 15:47:20.950 error script.js.Scripte.States_zaehlen_neu: TypeError: Cannot read property 'native' of null
                          javascript.0 2017-07-16 15:47:20.909 warn Object "undefined" does not exist
                          javascript.0 2017-07-16 15:47:20.757 info Start javascript script.js.Scripte.States_zaehlen_neu `
                          • BBTown
                            BBTown last edited by
                            @Elitepain77:
                            Habe bei den Dimmern noch über .state die Lichter eingebaut. `
                            Moin Chris,
                            magst Du die von dir erwähnte Erweiterung hier noch posten?
                              pix last edited by
                              hab mir das Skript nun auch installiert und bin sehr zufrieden. Gutes Skript!
                              Ich habe die Ausklammerung eines HM-Geräts jetzt auch hinbekommen. Oben habe ich's schon editiert, der Abfangcode funktioniert nur in der Subscription ( selektor.on() ).
                              Hier das neue Skript:
                              var d_count = 0;
                              var d_list = [];
                              //Get parent object
                              if (getObject(obj.deviceId).native.TYPE !=="HM-SCI-3-FM") { // Hier ggf. mit OR || weitere Geräte einfügen
                              countDevs(obj);
                              } else log('Gerät ' + getObject(obj.deviceId).native.TYPE + ' wird nicht mitgezählt');
                              schedule("
                              countDevs();
                              Pix
                                @pix:
                                var d_count = 0;
                                var d_list = [];
                                //Get parent object
                                countDevs(obj);
                                schedule("
                                countDevs();
                                Pix `
                                Pix … danke für deine Arbeit.
                                Leider wird das "HM-SCI-3-FM - Device" bei mir immer noch mit gezählt.
                                Muss ich noch etwas beachten?
                                  tesso last edited by
                                  Schönes Skript.
                                  Mir fehlen die Fensterdrehgriffkontakte HM-Sec-RHS.
                                  Ich sehe im Skript die Abfrage
                                  Woher weiß ich welche Geräte vom Type Shutter_Contact sind und welcher Typ der Drehgriff ist?
                                  Dann würde ich versuchen das Skript zu erweitern.
                                    @Smartuser:
                                    @pix:
                                    var d_count = 0;
                                    var d_list = [];
                                    //Get parent object
                                    countDevs(obj);
                                    schedule("
                                    countDevs();
                                    Pix `
                                    Gruß `
                                    Hallo Pix,
                                    könntest du da bitte nochmal drüberschauen?
                                    Bei mir funktioniert das "ausklammern" nicht.
                                      pix last edited by
                                      hier dann noch eine angepasste Version des Skriptes. Es werden nun für den Fenster-Zähler nur RHS (Rotate-Handle-Sensor) berücksichtigt, <u>keine</u> optischen oder magnetischen Tür-Fenster-Kontakte (TFK, Typen: HM-Sec-SCo, HM-Sec- SC2, HM-Sec- SC).
                                      Ausserdem gibt es nun eine Blacklist, in welcher die nicht zu beachtenden Typen aufgelistet werden (bitte selbst editieren). Zum Test ist hier der Typ HM-Sec-RHS auch eingetragen. Es macht natürlich keinen Sinn, erst das Skript auf RHS umzubiegen und diese Sensoren dann auszuklammern. "HM-Sec-RHS" steht also nur zum Debug in der Blacklist. Also bitte nach den ersten Test rausnehmen…
                                      /* Test Zähler
                                      ! http://forum.iobroker.net/viewtopic.php?f=21&t=2651#p23393
                                      ! von Vegetto
                                      ! 17.07.2017 eingebaut
                                      30.07.2017 Blacklist
                                      RHS Typ
                                      ! const logging = true;
                                      ! const blacklist = ['HM-SCI-3-FM', 'HM-Sec-RHS']; //Hier Gerätetyp eintragen, der nicht beachtet werden soll
                                      .LOWBAT]'), true);
                                      addDeviceCounter("sticky_unreach", $('channel[state.id=.STICKY_UNREACH]'), true);
                                      .UNREACH]'), true);
                                      addDeviceCounter("config_pending", $('channel[state.id=.CONFIG_PENDING]'), true);
                                      //addDeviceCounter("open_windows", $('channel{TYPE=SHUTTER_CONTACT}[state.id=
                                      .STATE]'), true);
                                      addDeviceCounter("open_windows", $('channel{TYPE=ROTARY_HANDLE_SENSOR}[state.id=.STATE]'), function(state){return state>0;}); // liefert 0,1,2
                                      var state_total = 'System.deviceCounter.' + name + '.total';
                                      var state_list = 'System.deviceCounter.' + name + '.list';
                                      var state_counter = 'System.deviceCounter.' + name + '.counter';
                                      var d_count = 0;
                                      var d_list = [];
                                      //Get parent object
                                      ! if (logging) log(name + "(" + d_count + "): " + d_list);
                                      var device_type = getObject(obj.deviceId).native.TYPE;
                                      if (logging) log('Zähler Skript - Auslösender Aktor vom Typ: ' + device_type);
                                      var dontcount = (blacklist.indexOf(device_type) != -1) ? true : false;
                                      if (dontcount) log('Geräte vom Typ ' + device_type + ' stehen in der Blacklist und werden nicht gezählt');
                                      else countDevs(obj);
                                      schedule("
                                      countDevs();
                                      ! Edit: logging nach den ersten Tests bitte auf false stellen
                                      Pix
                                        @pix:
                                        /* Test Zähler
                                        ! von Vegetto
                                        RHS Typ
                                        .LOWBAT]'), true);
                                        .UNREACH]'), true);
                                        .STATE]'), true);
                                        var d_count = 0;
                                        var d_list = [];
                                        //Get parent object
                                        schedule("
                                        countDevs();
                                        Pix `
                                        Hallo Pix,
                                        keine Ahnung woran es liegt, aber bei mir wird auch mit dem aktellen Script das "HM-SCI-3-FM - Device" mitgezählt 😐
                                        Sonst funktioniert das Script 1a.
                                        Hier der Log beim Starten:
                                        18:38:00.088	[info]	javascript.0 Stop script script.js.Scripte.State_Counter
                                        18:38:00.971	[info]	javascript.0 Start javascript script.js.Scripte.State_Counter
                                        18:38:00.972	[info]	javascript.0 script.js.Scripte.State_Counter: lowbat(42):
                                        18:38:00.973	[info]	javascript.0 script.js.Scripte.State_Counter: sticky_unreach(32):
                                        18:38:00.973	[info]	javascript.0 script.js.Scripte.State_Counter: unreach(32):
                                        18:38:00.974	[info]	javascript.0 script.js.Scripte.State_Counter: config_pending(32):
                                        18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: open_windows(17): Eingangstür,Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder,Fenster Badezimmer,Fenster Ben,Fenster Gäste-WC,Fenster Partyzimmer 2
                                        18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: on_lights(0):
                                        18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: open_shutters(6): Rollladen Küche,Rollladen Schlafzimmer,Rollladen Wohnzimmer,Rollladen Gäste-WC,Rollladen Esszimmer,Rollladen Partyzimmer
                                        18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: playing_music(0):
                                        18:38:00.976	[info]	javascript.0 script.js.Scripte.State_Counter: registered 161 subscriptions and 8 schedules
                                        Hier noch beim Öffnen eines zusätzlichen Fensters
                                        18:38:42.327	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-Sec-SCo
                                        18:38:42.328	[info]	javascript.0 script.js.Scripte.State_Counter: open_windows(17): Eingangstür,Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder,Fenster Badezimmer,Fenster Ben,Fenster Gäste-WC,Fenster Wohnzimmer 1,Fenster Partyzimmer 2
                                        Wie du siehst werden immer die 3 Kanäle des "HM-SCI-3-FM - Device" mitgezählt (Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder)
                                          pix last edited by
                                          kann es denn sein, dass der Typ evtl nicht HM-SCI-3-FM ist? Ich kann nirgends eine Debugausgabe sehen. Kannst du den Alarmanlagenmelder mal den Status wechseln lassen?
                                          Pix
                                            @pix:
                                            Pix `
                                            hab ich eben etwa 4x gemacht.
                                            Hier der Log:
                                            22:58:00.110	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
                                            22:58:00.112	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
                                            22:58:00.838	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
                                            22:58:00.839	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
                                            22:58:02.345	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
                                            22:58:02.347	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
                                            22:58:03.852	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
                                            22:58:03.853	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
                                            45
                                            9405
