    4. (Erledigt) Flot Adapter Installationsfehler
    UNSOLVED (Erledigt) Flot Adapter Installationsfehler
    • premo
      premo last edited by premo
      Hallo
      Bekomme es leider nicht hin den Flot Adapter zu installieren. Flot war aber schon am Laufen und konnte diesen nicht mehr unter Instanzen finden.
      Darauf habe ich den Adapter deinstalliert und bei Neuinstallation kommt dieser Error.
      iobroker.admin 3.6.3
      js-controller 1.5.11
      Platform: linux
      Architecture: arm
      CPUs: 4
      Speed: 1200 MHz
      Model: ARMv7 Processor rev 4 (v7l)
      RAM: 923.3 MB
      System uptime: 00:18:40
      Node.js: v8.15.1
      NPM: 6.4.1
      Disk size: 7.2 GiB
      Disk free: 2.4 GiB
      adapters count: 244
      Uptime: 00:18:16
      Active instances: 8
      Fehler Ausgabe sieht so aus.
      []Fertig mit Fehler: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json']
      $ ./iobroker add flot  --host raspberrypi
      host.raspberrypi install adapter flot
      got /opt/iobroker/node_modules/iobroker.flot/admin
      upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
      got /opt/iobroker/node_modules/iobroker.flot/www
      upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
      upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
      upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
      upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
      upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
      upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
      upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
      upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
      upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
      upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
      upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
      upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
      upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
      upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
      upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
      upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
      upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
      upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
      upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
      upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
      upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
      host.raspberrypi create instance web
      ERROR: host.raspberrypi error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
      ERROR: process exited with code 20
      MfG premo
      flot adapter
