    4. Probleme bei Adapter Installation node-gyp
    UNSOLVED Probleme bei Adapter Installation node-gyp
      Denwo last edited by
      Hallo, ich habe Probleme bei der Adapter Installation, egal welcher.
      Hier ein Beispiel:
      $ ./iobroker add vis-justgage  --host iobroker
      NPM version: 6.9.0
      npm install iobroker.vis-justgage@1.0.0 --production --save --prefix "/opt/iobroker" (System call)
      ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
           Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      In file included from ../src/BluetoothHciSocket.cpp:8:0:
      ../../nan/nan.h:1045:46: note: declared here
         NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
      ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’
         Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
      In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
                       from /home/iobroker/.node-gyp/10.16.0/include/node/node_buffer.h:25,
                       from ../src/BluetoothHciSocket.cpp:7:
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
         V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
      ../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:395:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             devId = arg0->IntegerValue();
      In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,                 from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2476:46: note: declared here
         V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);
      /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:417:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR!
       stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR!
       System Linux 4.9.0-9-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
      gyp ERR! node -v v10.16.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      ../src/linux/DeviceINQ.cc:35:37: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden     #include <bluetooth/bluetooth.h>
      compilation terminated.
      make: *** [Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1
      gyp
       ERR! build error
      gyp
      ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp
       ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.9.0-9-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR!
       cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v10.16.0
      gyp ERR! not ok
      In file included from ../node_modules/nan/nan.h:190:0,                 from ../src/unix_dgram.cc:5:
      ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
      ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
         return obj->ForceSet(GetCurrentContext(), key, value, attribs);
      In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, func, argc, argv);
      In file included from ../node_modules/nan/nan.h:47:0,                 from ../src/unix_dgram.cc:5:
      /home/iobroker/.node-gyp/10.16.0/include/node/node.h:177:50: note: declared here
                       NODE_EXTERN v8::Local<v8::Value> MakeCallback(
      /home/iobroker/.node-gyp/10.16.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
           __attribute__((deprecated(message))) declarator
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, symbol, argc, argv);
      /home/iobroker/.node-gyp/10.16.0/include/node/node.h:170:50: note: declared here
      In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
      ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, method, argc, argv);
      /home/iobroker/.node-gyp/10.16.0/include/node/node.h:163:50: note: declared here
      In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
      ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         domain      = info[0]->Int32Value();
                       from ../node_modules/nan/nan.h:47,
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
         V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
      ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]   type        = info[1]->Int32Value();
      ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         protocol    = info[2]->Int32Value();
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         fd = info[0]->Int32Value();
      ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]   String::Utf8Value path(info[1]);
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2892:28: note: declared here
                         explicit Utf8Value(Local<v8::Value> obj));
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         buf = info[1]->ToObject();
      In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,                 from ../node_modules/nan/nan.h:47,
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
       Local<Object> Value::ToObject() const {
      ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]   offset = info[2]->Uint32Value();
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2477:47: note: declared here
         V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
      ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         length = info[3]->Uint32Value();
      ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[4]);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR!
       stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp
      ERR! cwd /opt/iobroker/node_modules/unix-dgramgyp ERR! node -v v10.16.0
       v3.8.0gyp ERR! not ok
      npm WARN
       ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker-react-components'npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm
       WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN
       optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/bluetooth-hci-socket):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 (node_modules/node-bluetooth):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 install: `node-gyp configure build`
      npm WARN
       optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
      npm WARN optional
       SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      host.iobroker install adapter vis-justgage
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.vis-justgage"
      npm
       WARN deprecated coffee-script@1.3.3: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN
      deprecated hawk@2.3.1: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
      npm
       WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm WARN
       deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
      npm
      WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN deprecated
       hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN
      deprecated hawk@1.1.1: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
      npm WARN
       deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated jscs-preset-wikimedia@1.0.1: Deprecated in favour of eslint-config-wikimedia. -- https://phabricator.wikimedia.org/T118941
      npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm
      WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm WARN deprecated hoek@0.9.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN deprecated boom@0.4.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN
       deprecated cryptiles@0.2.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN
      deprecated sntp@0.2.4: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
      npm WARN deprecated
       nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
      npm WARN
      deprecated node-uuid@1.4.8: Use uuid module instead
      npm WARN
      deprecated core-js@1.2.7: core-js@<2.6.5 is no longer maintained. Please, upgrade to core-js@3 or at least to actual version of core-js@2.
      npm notice created a lockfile as package-lock.json. You should commit this file.
      got /opt/iobroker/node_modules/iobroker.vis-justgage/admin
      upload [1] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/justgage.png justgage.png image/png
      upload [0] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index.html index.html text/html
      Adapter "system.adapter.vis.0" restarted.
      host.iobroker object system.adapter.vis-justgage created
      host.iobroker create instance vis-justgage
      host.iobroker object system.adapter.vis-justgage.0 created
      process exited with code 0
      Kennt das jemand?
      Ich sehe das da etwas fehlt bzw. es Probleme mit dem
      gibt. Nur wie bekomme ich das weg?
      sigi234 arteck 2 Replies Last reply Reply Quote 0
      • sigi234
        sigi234 Forum Testing Most Active @Denwo last edited by
        @Denwo
        Neustart vom Host.......
          Denwo @sigi234 last edited by Denwo
          @sigi234
          Das wäre nicht das erste mal mit dem Neustart. Die Meldung kommt trotzdem...
          Edit: Lösung gefunden, poste sie gleich wenn das System durch ist.
            charon @Denwo last edited by
            @Denwo said in Probleme bei Adapter Installation node-gyp:
            @sigi234
            Oh auf die Lösung bin ich gespannt. Ich habe das selbe Problem und bisher noch keine Lösung gefunden.
              arteck Developer Most Active @Denwo last edited by arteck
              @Denwo sagte in Probleme bei Adapter Installation node-gyp:
              wo ist das Problem.. ich sehe keinen ..
              euch ist schon klar dass die Adapter auch auf anderen System laufen und da werden auch andere Abhängikeiten gebraucht.. deshalb die Meldung
              wichtig ist nur das der am Ende
              meldet..
                Denwo @charon last edited by
                @charon said in Probleme bei Adapter Installation node-gyp:
                @sigi234
                Moin, bisschen spät aber besser als nie 🙂
                Auf die Lösung war ich auch gespannt aber...
                Ich dachte es lag daran das ich die Pakete für Bluetooth nicht installiert hatte... war aber nicht so 😕
                Der rebuild brachte dann kein Erfolg und reinstall auch nicht. Hatte vorher ein Snapshot gemacht, also zurückgespielt und es lief wieder.
                Was ich mich aber gewundert hat. Das war ein Snapshot wo der BLE Adapter installiert war, als ich dann einen Adapter installiert oder geupdatet habe, kamen diese Fehler nicht. Was jetzt noch anders war kann ich gerade nicht sagen.
                adapter node-gyp bluetooth
