    2. English
    3. ioBroker general
    4. iobroker - problem with the installation
      mguc last edited by
      Can someone help me with installation ibroker on my cubieboard?
      I try instal based on some information:
      1. Node.js
        [as user by sudo or as root]
      curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
      sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
      reboot
      1. iobroker
        [as user or as root]
      curl -sL https://iobroker.net/install.sh | bash -
      And.. administrator panel i see on http://192.168.10.xx:8081/
      But when i try to add some Instances from Adapters tabs then it's impossible. See on log bellow:
      $ ./iobroker add modbus --host cubietruck
      NPM version: 6.4.1
      npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
      Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'
      npm ERR! cb() never called!
      npm ERR! This is an error with npm itself. Please report this error at:
      npm ERR! https://npm.community
      host.cubietruck install adapter modbus
      NPM version: 6.4.1
      NPM version: 6.4.1npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
      ERROR: host.cubietruck Cannot install modbus
      ERROR: process exited with code 13
      iobroker 2019-06-20 13:11:07.736 info exit 13
      iobroker 2019-06-20 13:11:07.701 error host.cubietruck Cannot install modbus
      iobroker 2019-06-20 13:11:07.691 info host.cubietruck install adapter modbus
      iobroker 2019-06-20 13:11:07.651 info npm ERR! https://npm.community
      iobroker 2019-06-20 13:11:07.651 info npm ERR! This is an error with npm itself. Please report this error at:
      iobroker 2019-06-20 13:11:07.640 info npm ERR! cb() never called!
      iobroker 2019-06-20 13:11:07.624 info Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'
      iobroker 2019-06-20 13:10:41.166 info npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
      iobroker 2019-06-20 13:10:41.156 info NPM version: 6.4.1
      iobroker 2019-06-20 13:10:37.983 info host.cubietruck install adapter modbus
      iobroker 2019-06-20 13:10:37.946 info npm ERR! https://npm.community
      iobroker 2019-06-20 13:10:37.946 info npm ERR! This is an error with npm itself. Please report this error at:
      iobroker 2019-06-20 13:10:37.932 info npm ERR! cb() never called!
      iobroker 2019-06-20 13:10:37.912 info Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'
      iobroker 2019-06-20 13:10:11.309 info npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
      iobroker 2019-06-20 13:10:11.305 info NPM version: 6.4.1
      iobroker 2019-06-20 13:10:07.994 info host.cubietruck install adapter modbus
      iobroker 2019-06-20 13:10:07.876 info npm ERR! https://npm.community
      iobroker 2019-06-20 13:10:07.876 info npm ERR! This is an error with npm itself. Please report this error at:
      iobroker 2019-06-20 13:10:07.876 info npm ERR! cb() never called!
      iobroker 2019-06-20 13:10:07.858 info Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'
      iobroker 2019-06-20 13:09:40.412 info npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
      iobroker 2019-06-20 13:09:38.369 info NPM version: 6.4.1
      iobroker 2019-06-20 13:09:31.903 info add modbus --host cubietruck
      I try with node6, 8 and 10 with the same effect. Where is my bug ?
        mguc @mguc last edited by
        Finally - I found the cause of my problem 😄
        The error is in the installation script (install.sh). He's creates the user "iobroker" but does not assume the home directory: / home / iobroker (at least for me).
        The installation process looks like this:
        1. Node.js installation (as user)
        sudo apt-get --purge remove node
        sudo apt-get --purge remove nodejs
        sudo apt-get autoremove
        sudo reboot
        sudo reboot
        2 iobroker installation (as user)
        iobroker stop
        sudo mkdir /home/iobroker
        sudo chown iobroker /home/iobroker
        iobroker start
        .. done.
        • AlCalzone
          AlCalzone Developer @mguc last edited by
          @mguc the install script executes a command that creates the user together with the home directory. If it didn't, something must have went wrong. Do you by any chance still have the output of the installer?
            mguc @AlCalzone last edited by
            @AlCalzone
            where can i find any installer log ?
              @AlCalzone
              I found my fault. Some days ago i removed this folder (removed folder than remove iobroker user 😉 )
              And when i try to install again - in system was iobroker user then (probably) install script not created it again.
              • AlCalzone
                @mguc Yes that makes sense
                  @AlCalzone
                  I reinstalled yesterday all iobroker system (now with remove user 😉 ).
                  After that install script works fine - then now i can confirm my mistake.
                  AlCalzone 1 Reply Last reply Reply Quote 1
                  • AlCalzone
                    @mguc I added an issue to the installer repo so we can catch this problem in the future. Thanks for reporting.
                    iobroker installation iobroker nodejs iobroker update
