    2. English
    3. ioBroker general
    4. Z-Wave Installation
    Z-Wave Installation
      ap2017 last edited by ap2017
      I updated NODE.JS to v10.16.0 on my X86 Linux Mint computer per following instructions:
      sudo apt-get --purge remove node
      sudo apt-get --purge remove nodejs
      sudo apt-get autoremove
      sudo reboot
      curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
      sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
      sudo reboot
      cd /opt/iobroker
      sudo npm rebuild
      iobroker start
      Now I am trying to install Z-Wave adapter, see below installation log with errors and permission denied messages. What am I doing wrong?
      $ ./iobroker add zwave --host ap-linux
      NPM version: 6.9.0
      npm install iobroker.zwave@1.4.1 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      npm WARN rollback Rolling back iobroker.zwave@1.4.1 failed (this is probably harmless): EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Makefile'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/clone-deep/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-base/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-utils/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/shallow-clone/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/window-size/package.json'
      npm ERR! path /opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLognpm ERR! code EACCES
      npm ERR! errno -13npm ERR! syscall unlink
      npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog'npm ERR! { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog']
      npm ERR! cause:
      npm ERR! { Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog'
      npm ERR! errno: -13,
      npm ERR! code: 'EACCES',
      npm ERR! syscall: 'unlink',
      npm ERR! path:
      npm ERR! '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog' },
      npm ERR! stack:
      npm ERR! 'Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog'',
      npm ERR! path:
      npm ERR! '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog',
      npm ERR! parent: 'iobroker' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR! /home/iobroker/.npm/_logs/2019-06-23T22_25_14_617Z-debug.log
      ERROR: host.ap-linux Cannot install iobroker.zwave@1.4.1: 243
      ERROR: process exited with code 25
      • AlCalzone
        AlCalzone Developer @ap2017 last edited by
        @ap2017
        You messed up the permissions when you ran sudo npm rebuild. sudo should (almost) never be used together with npm anymore. You might want to read this (although it is in german):
        https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo
        Please run the installer fixer
        curl -sL https://iobroker.net/fix.sh | bash -
        and try installing zwave again.
        A 2 Replies Last reply Reply Quote 0
          ap2017 @AlCalzone last edited by
          @AlCalzone Thank you. I am getting message
          bash: line 1: Moved: command not found
          In response to the fixing script
            ap2017 @ap2017 last edited by
            @ap2017 I am good, made an error is -sL, did not use capital L.
              ap2017 @AlCalzone last edited by ap2017
              @AlCalzone Hello, I am trying to install ZWave on X64 Intel platform with Linux, getting some errors during installation of adapter, then errors during adapter start. I have controller 1.5.12, Node.js 10.16.0 and NPM 6.9.0
              ZWave on X64 Intel.txt
              Never mind, after following https://github.com/ioBroker/ioBroker.zwave#known-issues everything starterd to work
              • AlCalzone
                @ap2017 Your adapter is still compiled against OZW 1.4:
                2019-07-06 21:10:51.257 - error: zwave.0 uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
                2019-07-06 21:10:51.257 - error: zwave.0 Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
                Please take a look at https://github.com/ioBroker/ioBroker.zwave/issues/57, specifically this comment:
                https://github.com/ioBroker/ioBroker.zwave/issues/57#issuecomment-510884233
                Anzic23 created this issue in ioBroker/ioBroker.zwave
                closed The problem with the libopenzwave of 1.6 #57
                z-wave
