    4. SensorTag Ti CC2650STK
    • ruhr70
      ruhr70 last edited by
      Da es hier Off-Topic wurde http://forum.iobroker.net/viewtopic.php … =40#p23784
      Zum SensorTag CC2650STK von Ti habe ich das Skript https://github.com/sandeepmistry/node-s … er/test.js für iobroker angepasst (log() statt console.log()).
      Damit erhält man folgende Ausgabe:
      2016-04-15 07:29:56	info	script.js.SensorTag-2: disconnected!
      2016-04-15 07:29:56	info	script.js.SensorTag-2: reed relay: false
      2016-04-15 07:29:56	info	script.js.SensorTag-2: right: true
      2016-04-15 07:29:56	info	script.js.SensorTag-2: left: false
      2016-04-15 07:29:50	info	script.js.SensorTag-2: readSimpleRead - waiting for button press ...
      2016-04-15 07:29:50	info	script.js.SensorTag-2: disableLuxometer
      2016-04-15 07:29:50	info	script.js.SensorTag-2: lux = 3.7
      2016-04-15 07:29:50	info	script.js.SensorTag-2: readLuxometer
      2016-04-15 07:29:48	info	script.js.SensorTag-2: enableLuxometer
      2016-04-15 07:29:47	info	script.js.SensorTag-2: writeIoConfig
      2016-04-15 07:29:47	info	script.js.SensorTag-2: config = 0
      2016-04-15 07:29:47	info	script.js.SensorTag-2: readIoConfig
      2016-04-15 07:29:47	info	script.js.SensorTag-2: writeIoData
      2016-04-15 07:29:47	info	script.js.SensorTag-2: data = 127
      2016-04-15 07:29:47	info	script.js.SensorTag-2: readIoData
      2016-04-15 07:29:47	info	script.js.SensorTag-2: disableGyroscope
      2016-04-15 07:29:47	info	script.js.SensorTag-2: z = 0.4°/s
      2016-04-15 07:29:47	info	script.js.SensorTag-2: y = -37.3°/s
      2016-04-15 07:29:47	info	script.js.SensorTag-2: x = -0.4°/s
      2016-04-15 07:29:47	info	script.js.SensorTag-2: readGyroscope
      2016-04-15 07:29:45	info	script.js.SensorTag-2: enableGyroscope
      2016-04-15 07:29:45	info	script.js.SensorTag-2: disableBarometricPressure
      2016-04-15 07:29:45	info	script.js.SensorTag-2: pressure = 998.3 mBar
      2016-04-15 07:29:44	info	script.js.SensorTag-2: readBarometricPressure
      2016-04-15 07:29:42	info	script.js.SensorTag-2: enableBarometricPressure
      2016-04-15 07:29:42	info	script.js.SensorTag-2: disableMagnetometer
      2016-04-15 07:29:42	info	script.js.SensorTag-2: z = 68.4μT
      2016-04-15 07:29:42	info	script.js.SensorTag-2: y = 89.2μT
      2016-04-15 07:29:42	info	script.js.SensorTag-2: x = 150.4μT
      2016-04-15 07:29:42	info	script.js.SensorTag-2: readMagnetometer
      2016-04-15 07:29:40	info	script.js.SensorTag-2: enableMagnetometer
      2016-04-15 07:29:40	info	script.js.SensorTag-2: disableHumidity
      2016-04-15 07:29:40	info	script.js.SensorTag-2: humidity = 54.9 %
      2016-04-15 07:29:40	info	script.js.SensorTag-2: temperature = 24.7°C
      2016-04-15 07:29:40	info	script.js.SensorTag-2: readHumidity
      2016-04-15 07:29:38	info	script.js.SensorTag-2: enableHumidity
      2016-04-15 07:29:38	info	script.js.SensorTag-2: disableAccelerometer
      2016-04-15 07:29:38	info	script.js.SensorTag-2: z = 0.8 G
      2016-04-15 07:29:38	info	script.js.SensorTag-2: y = -0.5 G
      2016-04-15 07:29:38	info	script.js.SensorTag-2: x = -0.0 G
      2016-04-15 07:29:38	info	script.js.SensorTag-2: readAccelerometer
      2016-04-15 07:29:35	info	script.js.SensorTag-2: enableAccelerometer
      2016-04-15 07:29:35	info	script.js.SensorTag-2: disableIrTemperature
      2016-04-15 07:29:35	info	script.js.SensorTag-2: ambient temperature = 24.6°C
      2016-04-15 07:29:35	info	script.js.SensorTag-2: object temperature = 21.4°C
      2016-04-15 07:29:35	info	script.js.SensorTag-2: readIrTemperature
      2016-04-15 07:29:33	info	script.js.SensorTag-2: enableIrTemperature
      2016-04-15 07:29:33	info	script.js.SensorTag-2: manufacturer name = Texas Instruments
      2016-04-15 07:29:33	info	script.js.SensorTag-2: readManufacturerName
      2016-04-15 07:29:33	info	script.js.SensorTag-2: software revision = PCB 1.2/1.3
      2016-04-15 07:29:33	info	script.js.SensorTag-2: readSoftwareRevision
      2016-04-15 07:29:33	info	script.js.SensorTag-2: hardware revision = PCB 1.2/1.3
      2016-04-15 07:29:33	info	script.js.SensorTag-2: readHardwareRevision
      2016-04-15 07:29:33	info	script.js.SensorTag-2: firmware revision = 1.20 (Jul 20 2015)
      2016-04-15 07:29:33	info	script.js.SensorTag-2: readFirmwareRevision
      2016-04-15 07:29:33	info	script.js.SensorTag-2: serial number = N.A.
      2016-04-15 07:29:32	info	script.js.SensorTag-2: readSerialNumber
      2016-04-15 07:29:32	info	script.js.SensorTag-2: system id = b0:b4:48:00:00:bd:a8:04
      2016-04-15 07:29:32	info	script.js.SensorTag-2: readSystemId
      2016-04-15 07:29:32	info	script.js.SensorTag-2: device name = SensorTag 2.0
      2016-04-15 07:29:32	info	script.js.SensorTag-2: readDeviceName
      2016-04-15 07:29:28	info	script.js.SensorTag-2: connectAndSetUp
      2016-04-15 07:29:28	info	script.js.SensorTag-2: discovered: {"id":"b0b448bda804","type":"cc2650"}
      2016-04-15 07:29:19	info	script.js.SensorTag-2: registered 0 subscriptions and 0 schedules
      2016-04-15 07:29:19	info	Start javascript script.js.SensorTag-2
      Ich glaube darauf kann man aufsetzen 🙂
      Laut Verpackung kann man den SensorTag auch als iBeacon verwenden. Dazu habe ich noch nichts gefunden. Das wäre dann noch ein weiterer Anwendungsfall mit dem Geofency-Adapter.
      Das BLE Scanner Skript findet den SensorTag auch.
        Solear last edited by
        Sieht gut aus!
        Ich weiß, du bist gerade mit dem Wiffi beschäftigt :lol:
        Wird daraus irgendwann ein Adapter? Vielleicht? Eventuell? Dann warte ich nämlich noch :oops:
