    5. Schaltzeiten Addieren, Gesamt "An" in Minuten ..
      Mento last edited by Mento
      ich habe ein Objekt welches in einem Zeitraum von 11:45Uhr - 18:15Uhr je nach Bedingungen mal Länger mal kürzer in diesem Zeitraum "An" ist.
      Soweit alles OK.
        <block type="on_ext" id="wNNWp~Y_FZe|v#%-dVwx" x="-162" y="-513">
          <value name="OID0">
            <shadow type="field_oid" id="~?t}50$cE*vhNwt/9d{k">
              <field name="oid">sonoff.0.creationx-1023.DS18B20_Temperature</field>
          <value name="OID1">
            <shadow type="field_oid" id="Hpa0]B73T)Sl=V{evgz2">
              <field name="oid">fritzdect.0.DECT200_087610178347.temp</field>
            <block type="controls_if" id="RtbEZklb).NV+Z98Gef:">
                <block type="time_compare" id="hH9U#G+TH0pk@~BgyC^A">
                  <mutation end_time="true"></mutation>
                  <field name="START_TIME">11:45</field>
                  <field name="END_TIME">18:15</field>
                <block type="controls_if" id="f`]_ZnrJPO+/s2gj8/sr">
                    <block type="logic_operation" id="Ay:;6+j:q;d8n/9*)VQC" inline="false">
                      <field name="OP">AND</field>
                        <block type="logic_compare" id="uLfZ.8ij68Im%Zp4D[K^">
                          <field name="OP">GT</field>
                            <block type="get_value" id="0MF^84cfN$rvZt-sMm7V">
                              <field name="OID">sonoff.0.creationx-1023.DS18B20_Temperature</field>
                            <block type="math_arithmetic" id="kO*{.nQyNy]#0AQMs^@E">
                              <field name="OP">ADD</field>
                                <shadow type="math_number" id="S-?[ltaJSwGg=L^bp!Mh">
                                  <field name="NUM">1</field>
                                <block type="get_value" id="fUzf0{W!S.r?tCW2os-8">
                                  <field name="OID">fritzdect.0.DECT200_087610178347.temp</field>
                                <shadow type="math_number" id="MuGm=)+OJsJ.%A.7J70)">
                                <block type="math_number" id="u9EWK?-EMe(imqdeoX54">
                                  <field name="NUM">4</field>
                        <block type="logic_compare" id=":bVQVcrIL(YDY32VCsAp">
                          <field name="OP">EQ</field>
                            <block type="get_value" id="Qq4-:mE3r.sA9^D{Luee">
                              <field name="OID">fritzdect.0.DECT200_087610178347.state</field>
                            <block type="logic_boolean" id="%C|:bx-oZCzz_A7vqcWK">
                    <block type="control" id="/-2XhHkBmKey*R%[!n?d">
                        <block type="logic_boolean" id="q7t)HORVod)v9]3W}jo2">
                  <value name="IF1">
                    <block type="logic_operation" id="Yy~I1gw@#1s|eb*^QU]s" inline="false">
                        <block type="logic_compare" id="gJ(-S([ECw`S;(0i=r+M">
                          <field name="OP">LT</field>
                            <block type="get_value" id=":;OaqB@6DgEvHKMx[Z/=">
                            <block type="math_arithmetic" id="!,vG%j$6J{Ikzg:x~x?U">
                                <block type="get_value" id="C-xfh:R`9N#Rsvj7?gaz">
                                <block type="math_number" id="B5/nTLNzT9]2HGKj)k=M">
                        <block type="logic_compare" id="fsEVLCKjDeTnXQO4viQs">
                            <block type="get_value" id="G2%KCoV,9q)w;P-cWe8F">
                            <block type="logic_boolean" id="T#4?AUYpx3)^tR)foJe(">
                  <statement name="DO1">
                    <block type="control" id="gG{^EIio~OS*1nMq(CEu">
                      <mutation delay_input="true"></mutation>
                      <field name="DELAY_MS">50</field>
                        <block type="logic_boolean" id="C_xtJ}B3Z+oFPE:v?=+w">
                <block type="controls_if" id="-%l-D?i;KD83Qi8{S#u0">
                    <block type="logic_operation" id="Y56yfZwbe-u2O0CTTO,-" inline="false">
                        <block type="time_compare_ex" id="1i9lU97W+J-eLC`CGBNw">
                          <mutation end_time="false" actual_time="true"></mutation>
                          <field name="OPTION">&gt;</field>
                          <value name="START_TIME">
                            <shadow type="text" id="Eq9Cu/~/=7d(jR!4`3Pm">
                              <field name="TEXT">18:20</field>
                        <block type="logic_compare" id="dnF}Dk^~5RI+e)g:O1oN">
                            <block type="get_value" id="-zW/+Lp3:})J^MF;sIMQ">
                            <block type="logic_boolean" id="^d[x-)l*1:/VIr3=kVyi">
                    <block type="control" id="Jm3z*dMhXRRf!Our3?ne">
                      <field name="DELAY_MS">20</field>
                        <block type="logic_boolean" id="iraX-caBHny?Py:,|Xe{">
      Nun möchte ich gerne noch wissen, wie Lange war das Objekt Switch on/off in diesem Zeitraum gesamt "an"?
      Mir fehlt die Idee wie ich das hier einbauen könnte, bzw. berechnet werden kann.🙄
      Wenn dieser Wert dann unter zb. unter 60 Minuten war, würde ich den Switch dann später nochmal für eine Fixen Wert von zb, 90 Minuten "An" schalten.
      • BBTown
        BBTown last edited by
        Vielleicht hilft dir ein Beispiel von einer Anwesenheits/Abwesenheitsberechnung als Ansatz weiter?!
        Im Grunde wird die Zeit zwischen 2 Änderungszeitpunkten eines Datenpunktes betrachtet.
        <block xmlns="http://www.w3.org/1999/xhtml" type="on" id="Qz}94ICw?Qb!u)3Mbg3)" x="-362" y="13">
         <field name="OID">javascript.0.Anwesenheitssteuerung.Userlist.Liste</field>
           <block type="variables_set" id="0BX5n})*`i)1e{V-@a_M">
             <field name="VAR" id="[voY[W,a!1c!rszK{*#/" variabletype="">Einschaltdauer</field>
               <block type="math_round" id="e4VQa~mlI/fiZ9?vYHN/">
                 <field name="OP">ROUND</field>
                 <value name="NUM">
                   <shadow type="math_number" id="H6fTxzKQCY-v}.:FtS3w">
                     <field name="NUM">3.1</field>
                   <block type="math_arithmetic" id="Pw_Sx~8U(B8e1Ia#c,Ep">
                     <field name="OP">DIVIDE</field>
                       <shadow type="math_number" id="F-7_uuh6=|vE~lWx_ZXk">
                       <block type="math_arithmetic" id="](K{~?udR%|Wx#E@TcwK">
                           <shadow type="math_number" id="-EL;Qei)s~g2xz=il8]+">
                           <block type="on_source" id="Dt7[Y1)%dJ}z~G0ndLGC">
                             <field name="ATTR">state.lc</field>
                           <shadow type="math_number" id="ON_1bTe;+MCx}oLi4-t@">
                           <block type="on_source" id="k2%f2N^bsOR%0EskI9*P">
                             <field name="ATTR">oldState.lc</field>
                       <shadow type="math_number" id="T%JQJD@,B:KE^}/n7]-Y">
                       <block type="math_number" id="lA^wH?;J?uJUa}EwNbcL">
                         <field name="NUM">60000</field>
               <block type="controls_if" id="ZdGo^TnKSt!b[H/5*mf^">
                   <block type="logic_compare" id="|v-|#[e^mW/@2ke6jU~v">
                       <block type="get_value" id="M[ny913|_H0~-q_c*Dbj">
                         <field name="OID">javascript.0.Anwesenheitssteuerung.Userlist.JemandDa</field>
                       <block type="logic_boolean" id="B^2){oE?P9]P[=4POR@M">
                   <block type="control" id="b:xQJp5ttIXPz7w55V=Q">
                     <field name="OID">Variablen.0.Abwesend_in_Minuten</field>
                       <block type="variables_get" id="g+YU9}_w_K0eQ;UmnN+]">
                       <block type="debug" id="pfsd^FJWCg,Z]%4*LZIu">
                         <value name="TEXT">
                           <shadow type="text" id="Y8uZc}op,^kGM({`9)iU">
                           <block type="text_join" id="1VwzC97MOmk=M5!,K9Mp">
                             <value name="ADD0">
                               <block type="text" id="hY[MhvdFGC;qss,.ViQI">
                                 <field name="TEXT">Ich war insgesamt </field>
                             <value name="ADD1">
                               <block type="variables_get" id="up(Y`Rb.%,A|xg5/Yq58">
                             <value name="ADD2">
                               <block type="text" id="_mvLRQibC1OFlOw,z??1">
                                 <field name="TEXT"> Minuten abwesend</field>
                 <value name="IF1">
                   <block type="logic_compare" id="`zw@};1fn9D+`fP]{dfV">
                       <block type="get_value" id="ZWSc:]nROWNjYS;p:(wQ">
                       <block type="logic_boolean" id="LW]Y1Vj]2S3mg57%YGlF">
                   <block type="control" id="x%*n,-F-vRxJtZ/dc@)g">
                     <field name="OID">Variablen.0.Anwesend_in_Minuten</field>
                       <block type="variables_get" id="u(`{MQ@2,{x8J_q`P3@3">
                       <block type="debug" id="OLdN7[rb9;;i`O=-d2D7">
                         <value name="TEXT">
                           <block type="text_join" id="Qliz]JF[[bhCbRPXVR+|">
                             <value name="ADD0">
                               <block type="text" id="5?_=YWE||me7W!!p;UM6">
                             <value name="ADD1">
                               <block type="variables_get" id="zpp_cK4]-#PyF)LGJ/LF">
                             <value name="ADD2">
                               <block type="text" id="g:c;u/eO6q6E.OB!MN%p">
                                 <field name="TEXT"> Minuten anwesend</field>
        M 1 Reply Last reply Reply Quote 2
          Mento @BBTown last edited by
          @BBTown der Ansatz ist ok.
          Nur müssten die Zeiten der wechselnden Anwesenheiten über eine Zeitraum von x - y Addiert werden um meinen Wert zu erhalten.
          Hast du evt. den code für mich?
            paul53 @Mento last edited by paul53
            @Mento sagte:
            Die Variable ed enthält die Einschaltdauer in Minuten. Falls um 18:15 Uhr eingeschaltet ist, wird ausgeschaltet.
              Mento @paul53 last edited by
              @paul53 Danke das sieht für mich Anwendbar aus.
              Könntest du mir den code zur Verfügung stellen?
              Ich tu mich da ein wenig schwer ein teil der Blockys so nach zu bauen.
                @Mento sagte:
                  <variables>
                    <variable type="" id="E`qm`o|L-sO)k*04AxaC">ed</variable>
                  </variables>
                    <value name="OID0">
                    <value name="OID1">
                            <value name="IF1">
                      <block type="on_ext" id="(;}k#gj(B8O%:y(8J{,Q">
                        <value name="OID0">
                          <shadow type="field_oid" id="`5[f^5v.jLycf`Os(xgo">
                          <block type="text" id="OU}@/_}#NA1MbjgW;?WI">
                            <field name="TEXT">fritzdect.0.DECT200_087610178347.state</field>
                          <block type="controls_if" id="uUk?IXEtvd9ElEd.$0SH">
                              <block type="logic_negate" id="k;:UHp9Z.mOi;izEzD+;">
                                <value name="BOOL">
                                  <block type="on_source" id="UoXrzFXQ+Sr`_uYi6hY/">
                              <block type="math_change" id="9J3]oUsMBpmy:5SfkMw7">
                                <field name="VAR" id="E`qm`o|L-sO)k*04AxaC" variabletype="">ed</field>
                                <value name="DELTA">
                                  <shadow type="math_number" id="X6Z{c![3aM!ITT0Avf{C">
                                  <block type="math_arithmetic" id="xAfgjF{W$2Zp@.qr`0d)" inline="false">
                                      <shadow type="math_number" id="NqW1c)DE0+{w#SXlc~Fx">
                                      <block type="math_arithmetic" id="Qo)5)#AinD,NK__B?KkO" inline="false">
                                          <shadow type="math_number" id="2p!3#Py6}f]gNQ!:)Qbs">
                                          <block type="on_source" id="u(]b1pUwq=|#K1CPsVkT">
                                          <shadow type="math_number" id="+E[ka_P9UbE;!;Ok5PSr">
                                          <block type="on_source" id="Hi=n~,8B+M|TF[O[--$j">
                                      <shadow type="math_number" id="G`#C*jQB4@M-%w,1f*{p">
                                      <block type="math_number" id="T|.d0,3qdrH8boq[-?Z`">
                          <block type="schedule" id="XN~GXwqSPWyk}H~l~K)Z">
                            <field name="SCHEDULE">15 18 * * *</field>
                              <block type="controls_if" id="$6jH0BuAb(6@ztv)`f=+">
                                  <block type="get_value_var" id=".8go/3x}.@2hhCX}WSa|">
                                    <value name="OID">
                                      <shadow type="text" id="zW.J?}rJ;*,d0X(H!!AX">
                                  <block type="control" id="EZn@l+8n~g73=sP-6yMz">
                                      <block type="logic_boolean" id="k7,uN26l^YJk*x3mLWo]">
                              <block type="schedule" id="Kob;^Bz=rn6.aWoG=`([">
                                <field name="SCHEDULE">45 11 * * *</field>
                                  <block type="variables_set" id="Z#Q6h3XIg/#s!q9J5T?O">
                                      <block type="math_number" id="ULCi/5qJtJ=cV_EM^yK=">
                                        <field name="NUM">0</field>
